Results 1 to 3 of 3
Thread: Will a HF-251D-1 run on 115v 100hz ?
    NW New Jersey
    I have a AEAD-200, and was wondering if anybody has run a HF unit off of the 100hz outlet while welding. A HF-251d-1 is being offered for sale at a low price, would it be worth it ? Someday I might move up to a bobcat 250 , would it work on that as well? I don't do that much tig welding outside of the shop, but the price might worth not passing up. https://www.weldingweb.com/images/smilies/confused.gif
    Miller Synchrowave 180 sd
    Miller Econo Twin HF
    Lincoln 210 MP
    Dayton 225 ac/dc
    Victor torches
    Snap-On YA-212
    Lotos Cut60D
    Oct 2016
    Re: Will a HF-251D-1 run on 115v 100hz ?
    YES. My HF250D-1 actually says 50/60/100 hz on the front panel. I would bet the only difference is that your newer model is a 14 pin remote plug vs my older one with a 5 pin plug.
    I lucked out when this was given to me, it had the secondary contactor already installed, without one, your torch will be always hot, tho I think you could make something work.
    I went a bit over the top when I set mine up, just cant resist a challenging project.
    My tig setup on the 89 AEAD 200LE has the HF box, a RCF-23 foot pedal with amperage control, and a water cooler for the torch.
    And it idles up with the touch of the pedal, and back down just like stick welding.
    I could give you pointers about how to add a foot pedal, etc if interested.
    NW New Jersey
    Good to know. Was going to check it out to see what came with it. Yes it has a 14 pin plug. Looks like there is a torch also.
    Thanks for the Help.
    Lincoln 210 MP
    Dayton 225 ac/dc
    Victor torches
    Snap-On YA-212
    Lotos Cut60D
Page generated in 1,638,155,275.95349 seconds with 11 queries
