Page 2 of 2 FirstFirst 12
Results 26 to 44 of 44
Thread: Interesting info on lock washers
    Sep 2014
    Re: Interesting info on lock washers
    And if you look at the second test with the lock washer under the bolt, it did stop it from coming out that is what it is supposed to do. If it loosens the teeth are designed to grab and hold the bolt from coming out. You need to know what the application is for. Head bolts are designed to stretch and keep tension on the bolt so it does not come loose, you would not want a lock washer because of the high torque and because the engine would fail before the lock washer did its job.
    On a piece of machinery that runs all the time, you can get vibration that will loosen bolts, bolts will stretch bolts will wear, so they put a lock washer in there and they keep the bolt from coming out hopefully till the next maintenance cycle. If you really do not want a nut to come off you need to drill and cotter pin or you have to drill and wire tie it like they do on aircraft parts.
    Sincerely,
    William McCormick
    Sep 2014
    You have to admit that there's been a sea change in truck bearings. The old school approach was allowing for about .0015 endplay on a tapered roller bearing. Today, we're looking at pre assembled cartridge type stuff from what I hear. They took the skill out of the mix I guess.
    I don't find the locking methods on my Class 8 stuff anything to write home about. It's standard for the time it was built. The wheels don't fall off if you know what you're doing. Which is the rub............... a lot of morons don't know what they're doing.
    You are right sam, the young kids were not over-torquing the bearing spinning it at least a full turn, to get it to seat properly, and then backing off and putting it under proper torque. So a person would leave a service center and hit a bump and properly seat the bearing that was now extremely loose. That bearing would often take out the spindle in one trip if heavily loaded. It is the dark ages, lego land.
    Sincerely,
    William McCormick
    I gave up on split locks years ago when changing cultivator shovels... they would spit out and let the bolts come loose after a couple days in the field. Now I rarely use them unless it's a special situation like valve covers or manifold bolts that come with them on.
    Cut 50 Plasma
  4. Likes William McCormick liked this post
  5. #29
    Sep 2014
    The bolts were probably too small for a lock washer being exposed to the stress they were under.
    A double nut has never failed me. A nut and acorn nut has also never failed me.
    Sincerely,
    William McCormick
  6. #30
    Yes, in that application I've gone to flat washers and double nuts. The double nut serves 2 purposes. It locks the first nut from coming loose and protects the thread from damage so you can take them apart again when the shovels are worn out.
    Cut 50 Plasma
  7. Likes William McCormick, 12345678910 liked this post
  8. #31
    Sincerely,
    William McCormick
    Nothing says "I actually give a sh*t" more than using acorn nuts on a project.
  9. Likes whtbaron, William McCormick liked this post
  10. #32
    I don't think the cultivator shovels care that much...
    Cut 50 Plasma
  11. Likes John Baptist liked this post
  12. #33
    But the bolt threads would be protected from caked on dirt and abrasion
  13. Likes whtbaron, John Baptist liked this post
  14. #34
    May 2010
    ct.
    “Ny-locks when hot spin right off”…
    How hot?
    Some of the ones that hold raincaps on exhaust stacks
    of diesel driven equipment get pretty hot, with a lot of
    vibration and I’ve never seen one spin itself off.
    Miller a/c-d/c Thunderbolt XL
    Millermatic 180
    Purox O/A
    Smith Littletorch O/A
    Hobart Champion Elite
  15. #35
    Sep 2014
    When I make a trapeze out of Unistrut/Kindorf, to hang an air handler or piping, I quickly throw some stainless steel acorn nuts on the protruding threaded rod that supports the trapeze. It has saved me countless numbers of injury and probably others too. I have a scar on my back from a razor-sharp threaded rod, that I couldn't see because of a hard had the safety officer made me wear. After that, he didn't make us wear them anymore while we were walking under the units hung in a 6-foot high rotunda. With the hard hat, you couldn't see above you when you are hunched over. So although going under the unit you could see where the rods were coming out you could not. Since we had to do this perhaps 50 times I told him in a polite way that it would be more dangerous for him if we had to wear them. In ten minutes two guys had gotten cut up the rest of the day nothing.
    I used to get 3/8" acorn nuts for under $0.50 cents apiece. I used to get 1/2" acorn nuts for under $1.00 each. About two months ago I realized my stock had run out, so I went to ACE just to buy six of them until I could get a whole box from a friend. The 1/2" acorn nuts were $4.89 cents apiece. You would think if OSHA really cared they would make that a mandatory thing to do when hanging pipe and appliances with threaded rods. But they do not really care. Today with so much wiring in the ceilings you can no longer wear a hardhat it just won't fit through the small openings of crisscrossing pipe, control, fire alarm, and communication wiring, as well as the machinery. When in a drop ceiling you have the black iron and pencil rods to deal with, it is like mid-evil torture of the dark ages up there.
    I just checked on the internet and you can get 1/2" stainless steel acorn nuts for $1.10 apiece. They are probably not the deep ones that I normally get but to be honest they will work well.
    Sincerely,
    William McCormick
  16. Likes John Baptist liked this post
  17. #36
    Sep 2014
    Quote Originally Posted by jpump5 View Post
    How hot?
    Racing engines caused a couple of failures of the NY-locks. Some of that stuff glows red hot when they are going all out with some wild vibration.
    One time we were putting a part on, and no one knew how it went, so we put it on took it off put it on, and took it off the NY-locks were finished, the heat of using an impact taking them on and off toasted them nicely.
    Sincerely,
    William McCormick
  18. Likes John Baptist liked this post
  19. #37
    Aug 2019
    Personally, I've never had much use for split lockwashers except for "soft" joints using gaskets, etc. the spring tension seems to help hold the clamp load. In a "hard" joint even a properly torqued plain nut with hardened washers is better. Flange nuts and bolts are the stuff for truck frames, beaten down good and tight they will never loosen.
    In the 80's I worked for a company that did plenty of heavy equipment work, our shop manager was a guy with a degree and zero real time experience. He caught 3 of us installing cutting edges on a D9 dozer blade and flipped out because we weren't using split locks. I personally grabbed his azz by the lapel and dragged him to the front office to see the owner, "He goes or I go" was the discussion... I explained the problem we were having in an hour long powwow, The boss offered to let the guy try laying on his back torching out junk blade frogs but he wasn't having any of that, us guys with experience were the problem according to Mr. Degree. The real suck part was I had to do his job starting the next day.
    HAHA careful what you wish for! that's a great story
    Lincwelder 180As
    Communists have the highest body count in history and yet they are all over TV and politics.
  20. Dislikes OPUS FERRO disliked this post
  21. #38
    Jun 2008
    New Plymouth ID
    I have used these https://www.nord-lock.com/en-us/nord...SAAEgILfvD_BwE on i had tried everything to keep the bolts in this was on a tophead motor, it was vibrating loose, these have not came loose in 800 hours usually it was every few days up there tightening bolts
  22. Likes 12V71 liked this post
  23. #39
    Aug 2021
    May be worth the viewing...
    Sent from my SM-A426U using Tapatalk
  24. #40
    Sep 2014
    Quote Originally Posted by Slowxj View Post
    The torque has to do with the application, it will always be easier to open a bolt than tighten a bolt, that is just reality, baring corrosion, heat damage, deformation, or contamination. I am not sure what the guy is trying to prove. No lock nut or lock washer can keep a bolt or nut from coming loose. But a split lock washer can keep the bolt from falling out till the next maintenance cycle. The current maintenance cycle is created by noting when you find a loose bolt or nut, and then whatever the cycle was before you shorten it until you get a moderately safe maintenance cycle. If you are using any kind of locknut, or lock washer and it can come loose in your application, you are not dealing with anything critical. The right-sized bolt will keep things from coming loose, in racing and aircraft where you are trying to use lighter smaller fasteners, you cotter pin, you wire tie nuts and bolts so although they may loosen they will not fall out. but if you just use the right-sized bolt it would not come out. All the grade five and grade eight is to hide the bolts are too small for the application.
    Sincerely,
    William McCormick
  25. #41
    Sep 2005
    Cave Creek AZ
    They just need to use whatever brand split lock that is on my trailer ball mounts. Those thing are locked! They dig out some metal when they come apart!
  26. #42
    Jun 2008
    It probably would be, I've watch similar videos 'bout them but that guy Ave I think he calls himself, drives me up the wall with his voice, stupid names and attitude.............Mike
  27. #43
    Aug 2021
    I use 5/8s hardware every day and this happens to me every day just as you're describing...
  28. #44
    Dec 2005
    Midland, Texas
    I can't remember the last time I used a split lock washer. If I use a lock washer, I use an internal tooth shakeproof washer. My preference is a nylon or all-metal locknut, or Loctite.
    America Needs AMERICA'S Oil!!!
    "Global warming is the greatest scam in history ...There is no run away climate change. The impact of humans on climate is not catastrophic. Our planet is not in peril."--John Coleman, Founder of The Weather Channel
Page generated in 1,638,354,455.42656 seconds with 12 queries
