Page 2 of 2 FirstFirst 12
Results 26 to 36 of 36
Thread: Portable welding tables
    Mar 2021
    Near Roanoke, VA
    Re: Portable welding tables
    Move the wheels 5 or 6 inches away from the legs, then, the wheels can even be off the ground.
    As you lift the opposite end, the wheels will touch, and cause the legs to come off the ground.
    With the wheels spaced away from the legs, the table will work kinda like a wheelbarrow,
    stable on the original legs, until you are ready to move it, then the wheels come into play,,,,
    Might just use the handtruck for moving any distance ...
    Looks great and simple
    Feb 2009
    Coastal NC
    Quote Originally Posted by VaughnT View Post
    Dang. That's pretty nice. As for the base, I think putting that on top of a hydraulic lift cart would make pretty much the ideal welding table if you were looking for something that was movable and multi-function. https://www.northerntool.com/shop/to...6310_200696310
    I like this idea, definitely come in handy, especially for around the shop. Not sure how it would be for traveling though.
    Remove the top and replace it with a fab block and you have a pretty capable table that can carry a load.
    In most cases the handle could be removed and casters can be locked.
  5. #30
    My 55 year old portable weld table makeover is done.
    I ended up adding wheels and a swing up handle
    Not digging the paint ( soft iron) but it's all I had around last night.
  6. Likes tapwelder, whtbaron liked this post
  7. #31
    Good looking table.
  8. #32
    Good looking table.
    Here you go, Dave....
  9. Likes whtbaron liked this post
  10. #33
    Looks a lot better than when you started... the orange makes it pop, maybe a thin band around the table top and shelf?
    Cut 50 Plasma
    Like small print
    Also the stinger hook too.
  12. #35
    @whtbaron
    I thought about it, but didn't want to make it look like the circus was in town ...
  13. #36
    Avoid pink and yellow polka dots....
    Cut 50 Plasma
Page generated in 1,642,859,273.53610 seconds with 12 queries
