Results 1 to 25 of 36
Thread: Portable welding tables
    Southern California
    Good concepts to copy.
    This is something that is pretty cool, albeit overpriced. I never even knew it existed.
    Dewalt DXMF4618WT
    Name:  dewalt welding saw horse.jpg
    Another that looks good is the Grizzly T28931.
    Name:  grizzly table.jpg
  2. Likes whtbaron, VaughnT, John Baptist liked this post
  3. #2
    Jul 2021
    Re: Portable welding tables
    They look cool but I image the table top getting deformed pretty fast.
  4. Likes John Baptist liked this post
  5. #3
    Pensacola , Fla
    I think I would go for one from Certiflat first and make a base for it.
    https://weldtables.com/products/copy...ab-slot-u-weld
    Hypertherm 65
    Everlast PowerTig 255 EXT
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
  6. Likes whtbaron, VaughnT, John Baptist liked this post
  7. #4
    I like that idea
  8. Likes John Baptist liked this post
  9. #5
    Here’s my portable table I built in 1965.
    I still use it. Sits just outside my shop door.
  10. #6
    Dewalt DXMF4618WT
    That welding saw horse would be handy. No way you could build it yourself (easily) and keep it as lightweight though.
  11. Likes John Baptist liked this post
  12. #7
    I built this portable out one of scraps earlier this year but just sold it a week ago
  13. #8
    Dang. That's pretty nice. As for the base, I think putting that on top of a hydraulic lift cart would make pretty much the ideal welding table if you were looking for something that was movable and multi-function. https://www.northerntool.com/shop/to...6310_200696310
  14. Likes sqznby liked this post
  15. #9
    Oct 2016
    Delavan WI
    3'x4' 3/4" plywood is my portable.
  16. Likes Broccoli1, John Baptist, Louie1961 liked this post
  17. #10
    Southern California
    Those hydraulic lift carts are way too precious to be sacrificed for a welding table in my life, but I agree with a certiflat style top it would be near ideal!
  18. Likes John Baptist liked this post
  19. #11
    Southern California
    lis2323 that is beautiful, though I wouldn't exactly call it portable!
    One of the few examples of a completely functional (can be beat on) but still elegant and stylish welding tables I've seen.
  20. Likes John Baptist liked this post
  21. #12
    Aug 2019
    Did you make that? the leg design seems smart you can get in close from that side
    Lincwelder 180As
    Communists have the highest body count in history and yet they are all over TV and politics.
  22. #13
    Aug 2019
    dang the one you sold is outrageous
    Lincwelder 180As
  23. #14
    Quote Originally Posted by John Baptist View Post
    Yes I made it. I wish I could say I was smart but the design was probably dictated by the availability of angle iron I had on hand
  24. #15
    Looks great 👍
    All my welding table was out scrape
  25. #16
    Okay this table was getting a little embarrassing to look at.
    One leg wasn’t perpendicular, the top wasn’t square and had a few torched holes. Also it wasn’t flat because it was a section of scrap from a round water tank. Various weldments from juvenile “fixtures” rounded out the amateur farmshop vibe.
    First off the top got a trim (now 20”x28”)
    A kerf was cut and filled with a hot 7018 pass to take the bow out..
    Perimeter underside framed with 1”x1”x3/16” angle …
  26. Likes whtbaron liked this post
  27. #17
    Portable welding table makeover Day 2
    The holes in the top were filled and legs squared up somewhat.
    2"square receiver stock drilled and tapped three sides 5/16"NC
  28. Likes whtbaron liked this post
  29. #18
    Makeover Day 3 and 4, buts who's counting.
    2" square hole cut in top, square tube stub welded in place for vertical receiver.
    What I deemed a usable pattern of 5/8"d holes drilled in top.
    Cable hangers and rack for clamps added.
    I'll leave it for now. Still needs cleanup and anything else that occurs to me.
  30. #19
    Fredericksburg, VA
    Could you add some casters pointing backwards on the two back legs that are just above the floor? That way you only have to lift up the leg with one side to roll it around.
    You could also just drill the holes and have the casters removable.
    Miller Spectrum 625 Plasma
  31. #20
    I like the heater to warm up yer feets......
  32. Likes whtbaron, Roert42 liked this post
  33. #21
    That photo was taken after the ambulance left
  34. #22
    Mar 2021
    Near Roanoke, VA
    Hmmmmmmmm,, how long will it have to set outside to get the original patina back?? ` `
  35. Likes Lis2323, whtbaron liked this post
  36. #23
    Good option which I may do, Pat.
    atm I am thinking of using this axle setup to raise the table height an inch or two ( presently 35") which would also provide a more stable base. Either way I would add a fold up handle on the other end for lifting and steering.
  37. Likes whtbaron liked this post
  38. #24
    Bottom tray is going to need some drain holes if it's going back outside. I need to park a bunch of my stuff outside your shop door until it "bothers" you...
    Cut 50 Plasma
  39. Likes Lis2323 liked this post
  40. #25
    LOL.
    Yeah I just plunked that heavy steel tray there to see how the size and shape looked for perspective.
Page generated in 1,643,249,754.20662 seconds with 15 queries
