Page 11 of 12 FirstFirst ... 9101112 LastLast
Results 251 to 275 of 282
Thread: Operation: Pole barn/shop
  1. #251
    Feb 2019
    Snyder TX
    Re: Operation: Pole barn/shop
    I see a few things in the video that I would do different. Weld some cleats as steps on the jib pole so I could climb it better. Rig up a rope & pulley so I could slide the panel along the top beam easier.
    AND since I fell off the loading auger of a John Deere combine (about 12') I would use some fall protection. I have been climbing towers for 35 years & that is the only time I have slipped, but it can happen no matter how agile you are!
  2. Likes 52 Ford, _Weldman_, mcspeed liked this post
  3. #252
    Quote Originally Posted by cwby View Post
    There's something ironworkers say...........It's not the height, it's the landing........or something like that. It's sorta silly not to take every measure to protect yourself. Nobody really cares if you were a hero when they're shoveling dirt in your face. Makes for good conversation at the dinner, but it's forgotten once people go home..........meanwhile, you're pushin' up daisies.
  4. Likes 52 Ford, mcspeed liked this post
  5. #253
    Dec 2020
    Virginia, USA
    I don't mind working up high. Never had a harness or anything when I worked construction.
    I still get up on my roof and walk it when I clean the gutters.
    Recently a guy that worked with a friend of mine fell off of a 10 foot step ladder and ended up in a coma. That was about a month ago. I think they ended up taking him off life support a few weeks later. Pretty sure he passed away. I believe he had suffered serious brain damage. The bad part was, it wasn't his fault. Piece of duct work came loose and knocked the ladder out from under him. Apparently he was about to retire, too.
    I'm not saying you aught to leave the house wrapped in bubble wrap, but working in a harness really isn't that bad. Especially a nice one. Heck - my tower harness has a built in Bosuns chair. I can just move my positioning lanyard to a different set of D rings and I get to sit down and still look like I'm working
    It's REALLY not bad if you're used to wearing a toolbelt. Like I said, I worked construction, so I always had a toolbelt on and I ended up putting suspenders on my belt. Only thing different is the leg straps on the harness.
  6. Likes _Weldman_ liked this post
  7. #254
    I was roof my self Saturday replacement a capacitor.
    I have worked all life on roof and something you do with caution ⚠️ .
    My doctors have told say off the roof and l let professionals ripped off do work.
    But the last guy do not finish the job because he was ill too.
  8. #255
    Sep 2012
    Wheatland, Wyoming
    Bet you wish you would have made the boom a foot longer. When I was your age I walked steel beams a few stories up, walked trusses and and such. Back the I was 6' 2" and 170 lbs. I knew the risks and was always aware of the skills I had for when and how I would react. Never used a harness only because they can restrict your reach and balance. Never fell in all those years. I did use a large knotted rope when doing a 6/12 roof once. Rode street bikes for 40 years and quit as I knew my reflexes were deteriorating. All about knowing your limits. I'm sure you know the risks and your capabilities as well. Enjoying your shop build a lot.
    Chris
    Auction Addict
  9. Likes 52 Ford, _Weldman_, mcspeed liked this post
  10. #256
    May 2021
    45.97267, -106.27818
    All it is, is a 20' piece of 8 inch junior beam that I set in the bucket ran two chains across where you see hooked and a third chained wrapped around the base around the bucket teeth with a binder to pull tension on the two other chains and prevent it from flipping over backwards. Not everyday I have it hooked up to the loader since the loader has to be used, just think I had my rinky dink backhoe running that boom at first.
    Ordered a harness almost 6 months ago, never made it here though got a refund then life happened, never reordered it, can't just go in town and buy one either. It's like trying to order pair of boots without trying them on or knowing the size you wear, if someone could point me in the right direction that would be helpful. I'm 6' 130 lbs 32 inch inseam, 30 inch waist with 38-40 inch chest, need something that if I weld with it on doesn't catch fire.
  11. #257
    Feb 2019
    Snyder TX
    Cadillac is an ExoFit. That is what most tower guys use. Very adjustable & comfortable to wear. Elk River makes some good harnesses also.
    When I am welding on towers I use a cheap nylon body harness for fall protection & a leather linesman belt (customized with a butt strap) & a chain type rebar hook for positioning.
  12. Likes _Weldman_ liked this post
  13. #258
    May 2021
    The I beam you see will be what the door will hang off of, will be going with hydraulic ram door that swings upwards to shove snow away in the winter. It’s just sitting up there to be welded later, but will serve as a way to transition the wall above it over the door. I even welded the caps on the pipes to keep weather and animals out with small gap at bottom for any condensation to drip out. All 18 gauge sheets on the overhang ring on both ends.
    Thought about putting a small deck to lounge on over it to look out into the abyss over everything for miles…
Size:  169.9 KBName:  9A9BDBBF-EE4B-456F-8FBD-BFEBA79415A1.jpg
Size:  108.3 KBName:  40E80A58-70C9-466D-870C-36D27F8B45E8.jpg
  14. Likes whtbaron, N2 Welding, 12V71, Don52 liked this post
  15. #259
    Going with the rounded theme, you'll need a spiral staircase to the balcony... but having said that, don't do it unless you go large diameter. I have a friend with a really tight spiral staircase in his house and they never use it because the narrow steps in the center are death traps.
    Cut 50 Plasma
  16. Likes N2 Welding, 52 Ford, _Weldman_ liked this post
  17. #260
    May 2021
    Problem is the balcony would be over the garage door that opens upwards and blocking the side wings. Round seems to be a a powerful shape, namely the Euclidean eggs as will be incorporated into the roof design of my house to hold weight.
  18. Likes whtbaron liked this post
  19. #261
    I remember when pyramid power was a big thing and some of the hippies north of me were building houses that shape to tap into the secret powers. Guess they lost their connection to the extraterrestrials....
    Cut 50 Plasma
  20. Likes 52 Ford, _Weldman_ liked this post
  21. #262
    Dec 2020
    Virginia, USA
    LOL! You have all kinds of interesting folks up there.
    HelenDeGenererosonites were on thing... but hippies building pyramids in the snow to gather power from aliens. Next, youre gonna be talking about the colony of Big Foots that's on the neighbors property.
    By the way, Mythbusters did a Pyramid Power episode.
    Edit: Big Feet? Big Foots?
  22. #263
    May 2021
    I go by ones and zeros, not mythology, religion or ideological ideas when building a structure. This is based on isosceles triangles...
  23. Likes whtbaron liked this post
  24. #264
    Nah... Bigfoot likes mountainous terrain and lots of forest .... none of that around here. Maybe Weldman can keep an eye out for you...
    Cut 50 Plasma
    May 2021
    Only hills and sparse forestry out here. Noticed Bigfoot only has been spotted in humid climates too, too dry here.
  26. Likes whtbaron, 12V71 liked this post
  27. #266
    Apr 2013
    Tigerton, Wisconsin
    Bigfoot actually hates humidity it was 92 degrees here today finally got the central air hooked up this morning and now the power is out
    Sent from my SM-A515U1 using Tapatalk
  28. Likes whtbaron, 12V71, _Weldman_ liked this post
  29. #267
    LOL... now we've done it! Disturbed Bigfoot!
    Cut 50 Plasma
  30. Likes 12V71, _Weldman_ liked this post
  31. #268
    May 2021
    Still going...
    Up we go, 20’ sticks of 4 inch angle iron quarter inch thick. Going to support to quarter of a circle hoops that will be the side wings I need to roll with my pipe roller, also will give a flange for the grain bin sheets I’m bolting up there on top it all. Wasn’t enough surface area to weld the angle iron to the main poles and be strong enough, so I took 4 inch channel iron to straddle the 4.5 inch poles and welded those where the angle iron was going, then welded the angle to the channel iron. Will have about half inch offset that I can work with and iron out flat in the build.
    Name:  Angle iron 1.jpg
Size:  150.4 KBName:  Angle iron 2.jpg
Size:  129.1 KBName:  Angle iron 3.jpg
  32. Likes whtbaron liked this post
  33. #269
    May 2021
    Next up, time to sink these poles 4 ft in the ground to prevent frost upheaval for the side wings. Will look just like the main atrium when down and a pipe connects 5 of them on each side. Welded a pad on each of them to spread the load out in the concrete. Sunk each pole 7.5 inches deep in the bucket of concrete to give it support and a pad to sit on when buried.
    Name:  Side wing 1.jpg
Size:  123.9 KBName:  Side wing 2.jpg
  34. Likes 12V71, 52 Ford, whtbaron, jniolon liked this post
  35. #270
    I think we've talked about this before, but if it's not too late you need a foot of screened rock below the pails in the hole. If the water can't collect below the pillar, there's no ice to force to poles up. About time you quit playing with old trucks and got back to work... been lots of windy, too hot or too rainy days around here though...
    Cut 50 Plasma
  36. Likes _Weldman_ liked this post
  37. #271
    May 2021
    I don’t remember, I think you did. It’s what I did on the main atrium poles too. I have been back to work for a bit, just wanted to finish incomplete projects first before moving forward, projects that I started before I could work on the pole barn due to rain or snow or both!. Been too much rain here too, but seems to be lifting finally. Talks of a 3rd La Niña might be happening right after this one and is reason for so much rain. Will say it’s opposite for now on the heat than last year, feels nice at night. Here’s what I did with the main atrium poles…
  38. Likes whtbaron liked this post
  39. #272
    May 2021
    These next trench’s are going to go way faster now, I introduced grandpa to the 21st century. Who says you can’t train a old dog new tricks.Name:  1E86D193-FB67-4846-B747-8E952C9F3BE0.jpg
Size:  172.9 KBName:  4C090986-CFDE-48A4-92DB-0156CF790A40.jpeg
  40. Likes Lis2323, 12V71, whtbaron, 52 Ford, jniolon liked this post
  41. #273
    Here now... easy on the old dog jokes...
    Cut 50 Plasma
  42. Likes _Weldman_, 52 Ford liked this post
  43. #274
    yeah... truth hurts.
  44. Likes whtbaron, _Weldman_, 52 Ford liked this post
  45. #275
    Mar 2004
    hueytown, ala
    Weldman, love your projects and your approach to one man operation. Most all I do is by myself and have to think up solutions for holding that other end and such... I applaud your resourcefullness !!
  46. Likes _Weldman_, whtbaron liked this post
Page generated in 1,656,485,675.51662 seconds with 13 queries
