Results 1 to 3 of 3
Thread: Brake line bracket
    Jul 2021
    FL
    Brake line bracket
    Working on my 1975 Toyota FJ40 brakes Have to make a bracket to hold one of the brake flex lines in place It`s L shaped w 9/16 hole drilled and WELDED in place to the rear axle thx Buz K
    Dec 2003
    Fairfield,CT
    Re: Brake line bracket
    And Sooooooo......
    www.tjsperformance.com
    Dynasty 300 DX
    HTP 240
    HTP Microcut 380
    Hyperthem 85
    Bpt. Mill/DRO
    4' x 8' CNC Plasma Table
    Instagram: tjsperformance
  3. Likes _Weldman_ liked this post
    Morton, Washington
    Quote Originally Posted by buzkanzenbach View Post
    Drill or punch a hole in some flat bar. Bend it 90 degrees and cut to length. You can buy them pre-made, of course you could make one faster than you could enter your credit card number.
    Browse the selection and get some inspiration.
    https://www.summitracing.com/search/...-mounting-tabs
Page generated in 1,713,298,482.51074 seconds with 19 queries
