Results 1 to 17 of 17
Thread: Bandsaw - holding stock at angles in vise
    Jan 2011
    W. Wisc
    I know I saw photos of a simple jig for holding work in a bandsaw vise at angles to get better cuts. Like holding a square tube at a 45 so you aren't just cutting through flats. I tried searching but that is a needle in a haystack search so no luck. Anyone recall this and can point me to the photos or just re-post them? I am in need of similar and wanted to look at existing versions before I made one. Worst case, i will just give it a try and see how it works...
    Thanks,
    -Dave
    Fredericksburg, VA
    Re: Bandsaw - holding stock at angles in vise
    here are some v blocks I made and can use them with the chop saw or band saw.
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Miller Spectrum 625 Plasma
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
  3. Likes Lis2323, davec, whtbaron, Kevin_Essiambre liked this post
    Jan 2011
    W. Wisc
    Yeah that's the kind of thing I was thinking about. What is that like 1" or 1.5" angle? Did you do anything to weld them in the center? I could see how that would get in the way of holding things properly if you welded in the "valley", but perhaps you can plug weld from the back in a couple spots just to keep everything aligned and in place.
    Thanks!
    -Dave
    Dave, if you use psa's method, maybe place the angle irons off centered to make it a little easier to accommodate different size materials.
    For instance if you are doing mainly 4" square tube set it up for that on one side and 2" on the other. You may have to experiment.
    This is just a thought. Might be a dumb idea....
  6. Likes VaughnT, whtbaron, davec liked this post
  7. #5
    Fredericksburg, VA
    Thanks!
    You can plug weld from the bottom or drill a couple small holes or grind some divots in the edges of the angle that touch each other. Kind of like you see in one of my pieces. Do a quick weld and then use a cut off wheel to grind the weld flush.
    Millermatic 252 MIG
  8. Likes whtbaron, davec liked this post
  9. #6
    Los Angeles
    Why would you want to not cut on the flat side while using a bandsaw?
    MM211 (Sold)
    Klutch 120v Plasma cutter
  10. #7
    CT
    Because the pitch size of the blade needs to change...you only want 2-3 teeth in contact with the material at any point in time. Avoiding the flats makes it cut better/much faster
  11. Likes bfjou812 liked this post
  12. #8
    No, you want at least 2 , preferably 3 teeth in contact at all times with a band saw. Personally I don't see much use for holding something in a V block on a band saw, dry cut, yes.
  13. #9
    CT
    Well, Lennox would disagree with you. https://www.google.com/url?sa=t&sour...9KfocirAsL8o7W
  14. #10
    After looking on their chart for tpi recommendations, they recommend 5-8 for 1)2" and 3-4 tpi for 1". I'd say that's pretty close to at least 3 teeth in the cut.
  15. #11
    CT
    No I meant about the orientation of materials in the vise and how that effects the required blade pitch
  16. #12
    Angle iron I cut many times, point of the V towards movable jaw. No special V block needed for that. Square tube I wouldn't cut that way on a band saw since it's nowhere as secure and point up is the most likely way for a blade to grab stock and yank it out of the vise. Maybe that's Lennox's way of selling more blades.
  17. #13
    Cutting ln the diagonal really is more for dry cut saw where most folk cut one part at a time and minimize blade wear. Most bandsaw cut will not be made in a diagonal. Theory is one thing, but reality is if you gang cut you will likely cut the flats rather than tilt a couple hundred lbs.
    That said I have fixture that held 9- 20 foot pieces on 1/2 inch sq tube on diagonal to be mitered. But, I made straight cuts on the flats.
  18. Likes Broccoli1 liked this post
  19. #14
    Los Angeles
    Guess I missed this info all these years :0
    https://www.thefabricator.com/thefab...uctural-shapes
    Name:  Screen Shot 2021-09-08 at 8.09.06 AM.jpg
    MM211 (Sold)
  20. Likes Louie1961 liked this post
  21. #15
    Nov 2013
    When I got my drycut saw I bought this to go with it, always worked well for me though it certainly wasn't That price 10yrs ago (but what is...)
    https://www.amazon.com/gp/product/B0049SQ5OO
  22. #16
    Jan 2011
    W. Wisc
    Well, however the debates may rage, I made a pair. 6" long. 1/4" flat bar and 1.25" x 1/8" angle. Here is the front of one and the back of the other. They are identical.
    Name:  vise angle grips.jpg
    -Dave
  23. Likes psacustomcreations, whtbaron liked this post
  24. #17
    Sep 2005
    Cave Creek AZ
    If you are just cutting small tubing, maybe up to 2-3”, you can simply raise the tubing up off the floor of the bottom plate using a scrap of heavy flat bar, or tube. It just needs to change the angle of the dangle of the blade so that the blade isn’t cutting the bottom flat of the tube at its lowest angle of repose.
Page generated in 1,634,442,829.26573 seconds with 13 queries
