Page 2 of 2 FirstFirst 12
Results 26 to 28 of 28
Thread: Brazing with OXY/Propane
    Re: Brazing with OXY/Propane
    I didn't read all the posts but wanted to point out that you CANNOT get a neutral flame with propane. You can't really get a carburizing flame either. You can get an oxidizing flame in varying amounts down to a pointed blue flame. Often just setting the tip on edge on a piece of steel before lighting helps as does adding a little oxygen. Acetylene welding tips can be used with propane but you usually need a larger size to get the required heat. Propane cutting tips can be 2 piece or the end recessed. I think Esab even has or had some that are flat on the end like acetylene tips. Not sure if they just have larger preheat holes or what is different about them.
    Feb 2012
    Welder Dave compliments and good explanation.
    Edit: thanks for answering question for all
    Oxy acety is best. Propane if it's all you got
    After an explosion stretched the 10 gallon tank to about 12, I concluded torch wasn't best to solder with.
    Nice. That would have extended your driving range an extra 20-30 miles.
    Just like having a “reserve” on our old Ford farm tractors.
Page generated in 1,638,112,543.47689 seconds with 11 queries
