Results 1 to 25 of 30
Thread: Duty cycle
    Dec 2008
    Duty cycle
    Does the person running the welder have to keep track of the duty cycle time? Will a typical unit auto shutoff in the middle of a weld, or will it just overheat if the person is careless?
    Re: Duty cycle
    Some welders (particularly some modern inverters) do, some welders (like older transformers) don't.
    The upside of the bigger, heavier transformers without auto-shutdown is that they're probably a bit more resistant to burning up, and you really have to beat on them to roach them.
    When you smell insulation cooking, prolly a good time to ease off.
    Sep 2016
    Detroit, Michigan
    Re: Duty cycle
    Quote Originally Posted by upand_at_them View Post
    It really depends on the machine. Many/most will shut down when they get too hot, but that often means you've already exceeded the duty cycle. Most of the newer machines will shut down before they hurt themselves, but probably not all. In many cases it's actually hard to even get to the duty cycle, where others it might not be that difficult. Do you have any specific machines in mind?
    http://mivise.com
    Hobart Champion Elite
    Everlast PowerTig 210EXT
    Dec 2008
    Re: Duty cycle
    I have the Titanium Flux 125. It's an inverter machine. Welds well for my beginner needs. I've only done some simple stuff so far, not even coming close to the spec'd duty cycle. But I have project coming up where I'll be doing a lot of beads on 16 or 11 gauge square tubing and I was curious.
    (Yes, I will get out the manual and read it now.)
    Soda springs,Id
    Re: Duty cycle
    And leave it on but don't weld so the fan can cool things down.
    To the OP: duty cycle is usually rated at full amps. The further you are down from that the longer the duty cycle.
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
    Laredo, Tx
    Re: Duty cycle
    Depends on what you see in your head as "typical". My HTP welders are very conservative, but will shut off before internal components reach a critical (damaging) temperature. My previous Millermatic 211 inverter did not shut off, and stupid me didn't see the over-temp light. Kept running until it blew the main board.
    Re: Duty cycle
    The only time I had keep track of duty cycle is very long welds that lasted over 10 minutes.
    Most welding is 2 minutes out of 10 minutes.
    So if welder 60% duty cycle you ok with all your welding.
    I also included a excel worksheet for calculations duty cycle.
    Attached Files Attached Files
    Sep 2016
    Detroit, Michigan
    Re: Duty cycle
    I'm not sure where you're getting that, but more often than not the duty cycle is listed at quite a bit less than full amps. For example, your Millermatic 175 has a max of 175A, but it's duty cycle rating is 30% at only 130A. The Miller 250 family of MIGs were all actually 300A machines, but they called them 250, 251, 252 etc because the duty cycle was at 250A. Lincoln and Hobart machines tend to follow that same general pattern.
    http://mivise.com
    Apr 2021
    Re: Duty cycle
    Duty cycle is generally given at the rated output of the welder. This ESAB welder has a maximum output current of 240A (probably limited) but the rated output is 235A. The duty cycle is given as:
    40% duty cycle 235 A
    60% duty cycle 200 A
    100% duty cycle 160 A
    Smaller welders usually don't specify an absolute maximum output current, just the rated current.
    The machines are generally named for the rated output current, not the absolute maximum and there are no performance figures for operation above the rated output current.
    Jack
    Sep 2005
    Cave Creek AZ
    Re: Duty cycle
    I weld every day for a living. For most light work I never give it a second thought. Occasionally, when I have the machine cranked welding heavy steel or aluminum I have to start paying attention. I have used a timer on occasion. Usually at those Amos and length of weld the heat of the welding gives your body a duty cycle that is less than the machine.
    Jul 2018
    Cumbria, UK
    Re: Duty cycle
    Here's a rough rule of thumb: if your MIG set is 115v only, then it's likely you'll run into duty cycle issues on bigger stuff
    All manufacturers rate their machines differently. It USED to be that Lincoln and Miller set their model numbers in line with the output at 60% duty - that being for professional production use.
    Nowadays they seem to mostly have joined all the other manufacturers in numbering their models at the maximum output... mostly anyway.
    Remember temp comes into it too... 40 degC ambient temps, I'll never see in my workshop... maybe 30. So my two Lorch machines which are rated at 40%DC max current at 40degC, I've never ever managed to come close to heating them up... in fact I rarely even hear the fans speed up to max, even with the TIG set at max current for long periods.
    Re: Duty cycle
    Quote Originally Posted by Jack Ryan View Post
    My Millers all spec the DC at about 3/4 or 4/5 of the max output but also give DC at maximum current (often on a graph).
    For example, my Sync 250 has a DC of 40% at 250A, about 28% at 300A and max current of 310A.
    When the duty cycle at the max current isn't specked, you can figure it out. This is from AWS:
    For my Sync 250:
    (250/310) x (250/310) x 40 = .26 = 26% at 310A...meaning that for every 10-minute period, you can weld at 310A for 2.6 minutes with 7.4 minutes of cool-down time in-between.
    My 251D is rated at 100% DC at 250A, and goes down to (according to the graph in the owner's manual) 40% at 400A. Or supposedly. Got overhead?
    Syncrowave 250DX
    Miller 330 A/BP
    Miller Big Blue 251D
    Apr 2021
    Re: Duty cycle
    You can do those calculations but you are only assuming that is is permissible to extrapolate higher than the rated output of the machine. I have not read what the AWS has to say on the subject but it is not its job to second guess a manufacturers specifications. Those calculations can be used to determine the duty cycle for welding currents less than the rated output but not more.
    Currents in excess of the rated output can be achieved but only fleetingly - the mean current should remain at or below the rated output and within the duty cycle and temperature stated.
    Jack
    Sep 2016
    Detroit, Michigan
    Re: Duty cycle
    Jack
    I don't know why you think that's a general rule because it's not. Many machines have a duty cycle chart that show all the way up to maximum amperage, so the "rated output" isn't just one number. Often manufacturers will list a "rated output" on spec sheets using a set duty cycle percentage, but that varies so it's far from an industry standard. Some use 30% because it makes the machine appear to be more powerful, some use 40% to be more conservative, some use something else like my Everlast which uses 35%. Heck, my Hobart is rated at 100% duty cycle.
    Even Harbor Freight's little Titanium 125 welder has an owner's manual that lists it being 30 to 125A output. They list a rated output of 30% at 90A, but clearly list 125A as a max, and still call it a 125A welder. I'm sure some inexpensive machines don't have max output listed, but it's certainly common for them to have the full range given in their manual and some are named after their maximum output rather than rated output.
    No performance figures for anything above rated output? That might be true for some machines, but it's certainly not a general rule. As mentioned above, the duty cycle charts supplied with many machines cover more than just the "rated output" number given in spec sheets. My Millermatic 350P has several rated outputs listed: 300A output at 60% duty cycle, 350A output at 40% duty cycle. The chart goes up to the max of 400A output at 30% duty cycle as well.
    Regardless of all of that, my comment above was correct..."rated output" is rarely at a machine's maximum output.
    http://mivise.com
    Sep 2016
    Detroit, Michigan
    Re: Duty cycle
    Jack
    No need to extrapolate when the manual has a chart showing the duty cycle up to max amperage. As I said previously, my Millermatic 350P shows 400A max with a 30% duty cycle, which is what some companies use as their normal "rated amperage". I wouldn't call that "fleetingly" at all.
    http://mivise.com
    Re: Duty cycle
    Nonsense, Bart. You're obviously basing this on the assumption that the user will empty out all the "cold particles" from their machine at regular intervals to replace the "positrons" getting sucked up by the tungsten.
    Jul 2018
    Cumbria, UK
    Re: Duty cycle
    Why? If it's a quality machine you can use it up to its duty cycle at that amperage and temperature. "Rated output" is a bit wide ranging since as pointed out above, most quality manufacturers produce at least two figures, often more - 60%, 100% and 30% being common... it's still "rated" at 30%...
    Re: Duty cycle
    Maybe on your welders.
    My welders will run far "in excess of the rated output" until they overheat (when the current "droops" and the welder gets "colder" presumably due to an excess of cold particles building up) or catch fire...but this takes quite a while.
    Where do you get this stuff?
    NW New Jersey
    Re: Duty cycle
    At the OP : I wouldn't worry to much about duty cycle when doing tubing, you'll find you spend more time setting up, grinding, brushing, squaring up, and moving things around. If your truly curious, find a 12"x12"x 1/8" plate and start padding some beads on as fast as you can, occasionally cooling it with water, until the light comes on. Then you'll have an idea where that limit feels like. I don't think it well trip out that easily, and you may find that your 115v circuit is you limiting factor.
    Good Luck
    Miller Synchrowave 180 sd
    Miller Econo Twin HF
    Lincoln 210 MP
    Dayton 225 ac/dc
    Victor torches
    Snap-On YA-212
    Lotos Cut60D
    Los Angeles
    Re: Duty cycle
    One thing to consider is that although your project will need a lot of beads- the sequence you will need to weld these beads will most likely keep your machine under the duty cycle.
    Fit up, weld a small section, move to a different section to keep the distortion from turning your project into a banana
    Machine is resting while you are moving around the project.
    MM211 (Sold)
    Klutch 120v Plasma cutter
  21. Likes Munkul liked this post
  22. #21
    Jun 2009
    Draper, UT
    Re: Duty cycle
    For my typical welding, the fan on my 252 rarely even turns on
    MillerMatic 252, HTP 221 w/cooler, Hypertherm PM45, Lincoln IdealArc 250 AC/DC
  23. #22
    Re: Duty cycle
    If quoting work most time a welder is lucky to welded 20% with stick.
    MIG welding is around 30% to 40% of time welding. Some types of work will drop down to 10% welding time.
    If you are doing carbon arc that can be 100% duty cycle.
    You read books that give fantastic speed once welding hit shop floor it drops in speed and duty cycle need.
  24. #23
    Sep 2005
    Cave Creek AZ
    Re: Duty cycle
    If you are really worried you could get a small refrigerator, cut a hole for the gun lead. Call it a MIGeRator.
  25. #24
    Mar 2021
    Near Roanoke, VA
    Re: Duty cycle
    May I throw in the fact that when the air is humid, the moisture pushes the air molecules apart,,
    so, you have less air flowing through the machine to cool it.
    This came up when discussing airplane takeoffs.
    When the air is high humidity, the plane engines must rev higher to get enough lift to make the plane take off.
    So, now we need a humidity sensor on the welding machine.
    If the humidity increases, the welding machine will have to speed up the cooling fan,,,
    to maintain the same duty cycle,,,
  26. #25
    Apr 2021
    Re: Duty cycle
    I agree with that.
    The machine can be used up to its duty cycle and yes, there is the maximum and often higher duty cycles specified for lower currents up to the current at which the machine has a 100% duty cycle. Yes, the duty is specified under certain conditions such as temperature and over a specific time period.
    You can also rev an engine past the redline.
    Some specifications include a graph of duty cycle verses current. In that case, the welder is rated for those currents but those graphs are rarely linear so that simplistic AWS calculation does not apply.
    In the end, most home welders don't need to worry too much about duty cycle but that doesn't mean you can just make stuff up to suit yourself.
    Jack
Page generated in 1,635,299,058.89847 seconds with 13 queries
