Page 5 of 5 FirstFirst ... 345
Results 101 to 114 of 114
Thread: What's the best wat to cut steel?
  1. #101
    Sep 2021
    USA
    Re: What's the best wat to cut steel?
    I don't think I necessarily agree with LIS on the torque end of things. It may depend on what speed range you need/desire and your power transmission set up . Treadmills have been known to drag some fairly heavy loads at low speeds. But there are a couple of other things that I might consider. Is the motor totally enclosed? Is it a permanent magnet motor. I'm wondering about the collection of iron dust in/on the motor and/or if you can protect it or place it to avoid same. Just a thought or two..
    I never considered that the motor could get debris inside and tear up the motor. I never considered they should be sealed. Thanks for the heads up on that.
  2. #102
    Apr 2016
    CA
    Quote Originally Posted by Need Advice View Post
    Well if you have a motor that you got for free then there is not much you will loose if you kill the motor from dust except for your time fabricating the tool. You could always make a housing with some bushings that encases the motor to reduce the metal shavings from getting into the motor housing. Other options would be to have compressed air blowing on the belt just below where you are griding to direct the dust into some kind of metal dust collection or use both compressed air and a vacuum to keep the area clean Just a matter of how much time do you want to spend tinkering with it to get it to work just as planned. I still have yet to build a belt sander. I have way to many other things to do before I have free time to do that.
  3. #103
    Sep 2021
    USA
    Thanks. I have a lot of free time at the moment.
  4. #104
    I find this saw works well for me. Not as fast as a band saw, But more accurate cuts.
    I bought this one at a farm auction for $250
  5. #105
    Sep 2021
    USA
    That's a nice old saw. I saw one in a flea market but didn't even bother asking the guy what he wanted for it. I figured it was more than i had. It was huge and heavy looking.
  6. #106
    Power hack saws work fine. I have 4 of them, none as new as the one pictured. Three have been motorized from flat belt drives. If one come up for sale near here they sell cheap. The one I use most often, my father bought new in the early to mid 1930's. The other 2 flat belt drives need some work to take the slop out of them. They are slower than some other methods but I set it up turn it on and go do other things while it cuts. The newest one a Racine will cut angles. Like MJD mentioned in another thread, if I were to find myself cutting 20 ga. I'd use a shear, a Beverly for curves and a straight shear for straight cuts.
    https://www.eastwood.com/throatless-...=google&wv=3.1
    https://www.amazon.ca/dp/B00YNEXV5A?...EEQ%5Ejul21%5E
    ---Meltedmetal
  7. Likes Lis2323, Need Advice liked this post
  8. #107
    Looks great.
    Low cost blades
    You can make new blade from coil .
  9. #108
    Jun 2021
    Northern Lower Mi summer, FL winter
    I didn't read through all the replys. My experience is I cut more with my 6" Metabo angle grinder with a cut off wheel than anything else. Second is the horizontal band saw, which is handy because it can be cutting while I'm doing something else.
    I use the oxy/acl torch more than I use the plasma for cutting. The torch is a must for heating to shape also. IOW, for me the plasma is the least used cutting device.
    Miller Dialarc 250
    Hobart 140
    HTP 220 MTS
    Miller Legend AEAD 200LE Gas drive
  10. Likes Need Advice liked this post
  11. #109
    Sep 2021
    USA
    Quote Originally Posted by KenO View Post
    Thanks. I can see myself using the bandsaw a lot because its quiet. I plan on using the Plasma cutter a lot for pattern cutting sheet metal and thin plate. I would like to use a copy cutter or pantograph. I plan on trying the PrimeWeld CUT50DP. It has a 3 year warranty and only costs $400.
    Lincoln Pro MIG 180
    Chicago electric 225 Arc
    Harris oxy fuel
    Everyone who calls on the name of the Lord will be saved. Romans 10:13
  12. #110
    Sep 2021
    USA
    I used my chop saw today. It seems to cut better than the last blade i had on it. Maybe diablo makes a good blade. The chop saw will get me by till i get a bandsaw. I cut 2" bar stock with it as well as some other sizes and it preformed satisfactory.
    Lincoln Pro MIG 180
    Harris oxy fuel
  13. #111
    Sep 2012
    It isn't "the best" for every situation but I just bought an Evolution S380CPS and have been very impressed with the accuracy and finish of the cuts. I have always wanted one to replace/augment my old Milwaukee abrasive chop saw. I finally decided to pull the trigger before tariffs, runaway inflation or Supply Chain collapse (or any combo of those) left me wanting.
  14. Likes Need Advice liked this post
  15. #112
    Sep 2021
    USA
    Quote Originally Posted by AFSOC View Post
    Washout a doubt the evolution is hassle free and cuts good but its loud and throws metal shaving all over the place. I have hearing damage so I'm going with the quiet bandsaw, otherwise i would get the evolution too because Its faster and hassle free. A bandsaw you have to tune up and its much slower.
    Lincoln Pro MIG 180
    Harris oxy fuel
  16. #113
    NOTHING is “hassle free”.
    Ask anyone who realized too late their workpiece wasn’t securely clamped in the vise of their dry cut saw.
    If you need to frequently “tune” your bandsaw something is wrong.
  17. Likes Need Advice, BD1 liked this post
  18. #114
    Tune up your bandsaw ??
    My HF 4x6 is old old. All I ever did was replace motor. It's still gets used for small stuff.
    My ELLIS 1600 is 5 years old. I replaced blade, that's it.
    Set material in bandsaw saw and do something else ,close by, while it's cutting.
  19. Likes Need Advice liked this post
Page generated in 1,638,513,379.74717 seconds with 13 queries
