Re: Belt grinder motor questions.
Originally Posted by
Lis2323
Let us know how it works.
From what I understand you will lose too much torque at the lower speeds.
Lots of people have used these motors for drill presses and bandsaws. I have yet to see anyone say anything bad about them.
Lincoln Pro MIG 180
Chicago electric 225 Arc
Harris oxy fuel
Everyone who calls on the name of the Lord will be saved. Romans 10:13
Use 90 vdc on my two bench top drills
dc motor 90 volt
xmmancharl
Did you use the speed controls from the corresponding treadmills or build your own from scratch? What kind of spindle speeds are you running and how is the torque from a 3/4 hp motor at low speeds? I was wondering if you would still need to gear down the belt drives and run the variable speeds on the motor in a higher range...
Cut 50 Plasma
whtbaron
I cant recall your situation. You do have 3 phase power don’t you?
If not, surely you should be able to find a used heavy duty 3 phase machine and add a VFD or phase converter.
Then you wouldn’t be d*cking around like I did for so many years.
Edit. Or maybe buy a mag drill and fixture it so that you can use on your heavy welding table.
Just single phase here. I geared down my press with the belts/pulleys and a 1/2 HP 1725 motor. I need to fix the belt tensioner better... right now the belt slips long before the motor powers out with the big bits.
Cut 50 Plasma
using this 90 volt controller...
box
other drill press
mounted...
xmmancharl
box
other drill press
mounted...
Nice. So how low an rpm can you run/ what size drill in steel /with what HP?
usiing a 2 1/2 inch hole saw...forgot had my gloves on...
hole saw grabbed my glove....trip to emergency room...10 stiches on smaller finger...
so i guess its got enough torque
never change belt pulleys anymore
rpm range... about 50 up to 1,000
good enough for me
xmmancharl
I just ordered this controller. I've been told that the terminals on the back that are labeled "PW" are for an emergency stop switch. Is this correct?
Thanks,
Joe
I finally got around to getting the motor out of the old treadmill. As I've been reading and watching various how-to videos for controllers - one thing keeps popping up:
They all seem to us an AC controller, then the bridge rectifier, and wired that to the motor.
I'd like to have the 120V wall power go to a bridge rectifier, then the DC into a DC PWM controller, and on to the DC motor. The many reviews and boards seem to indicate the PWM is superior to a "SCR" controller.
If that's doable - the next question is:
My motor is tagged for 130VDC, all the controllers I can find only seem to go up to 90VDC. I can get ones with plenty of amps and watts - but am curious what degradation in performance (if any) would possibly result from the lower voltage. (I've used to W to A, etc calculators but the expected end results still confuse me a bit.)
EDIT: Just came across a discussion regarding PWM's - the "FILTERED" ones can go to 130VDC, unfiltered limit out at 90VDC. I'm still searching, but this brought up another question: Is/would a "CHOKE" act as a filter? I'm trying to figure out if they do more than help with audio noise issues.
Yeswelder MIG-205DS
56 years young and still learning...
After lots more reading I have a MC-60 motor controller coming that does it all: AC to DC conversion and 130VDC max output (same boards that run treadmills), and a 5K linear potentiometer. Those two items should get me into the testing stage at least. If that works out, then it'll be taking out the soft start circuit, and getting it into a project box.
Yeswelder MIG-205DS
