Results 1 to 18 of 18
Thread: Receiver for Rear of Trailer
    Mar 2014
    Troy MI
    My friend Rick wanted me to fabricate a receiver that would mount to the cargo carrier on the rear of the trailer that would allow him to install a bicycle rack to the receiver, when desired. With this design the bicycle rack would be easy to remove from the cargo carrier when it wasnít required. Rick originally wanted to use a piece of angle iron that he had for the cross brace, but I talked him into using a piece of square tubing, for improved torsional rigidity. I didnít want the bicycles to bounce around too much -- particularly the heavier electric bicycle.
    1. Original Plan
    Name:  1. Original Plan.jpg
    Rick wanted the bottom of of the receiver to be flush with the deck to we installed the receiver tube offset on the top as shown below.
    2. Offset receiver
    Name:  2. Offset receiver.jpg
    I welded a tab to the top of the cross tube to close off the hole caused by the offset receiver tube.
    3. Offset tab
    Name:  3. Offset tab.jpg
    Notice the Fireball square that I used to square up the receiver to the cross tube.
    4. Tack welding
    Name:  4. Tack welding.jpg
    5. Welding it out
    Name:  5. Welding it out.jpg
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Clausing/Coldchester 15" Lathe
    16" DuAll Saw
    15" Drill Press
    7" x 9" Swivel Head Horizontal Band Saw
    20 Ton Arbor Press
    Bridgeport
    Lincoln LE 31 MP & Lincoln 210 MP
  2. Likes _Weldman_, whtbaron, Shootr liked this post
  3. #2
    Mar 2014
    Troy MI
    Re: Receiver for Rear of Trailer
    6. Me welding the end cap
    Name:  6. Me welding the end cap.jpg
    7. End cap welded
    Name:  7. End cap welded.jpg
    8. Bottom of receiver welded
    Name:  8. Bottom of receiver welded.jpg
    9.All welded top view
    Name:  9.All welded top view.jpg
    10. Welded bottom view
    Name:  10. Welded bottom view.jpg
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  4. Likes _Weldman_, whtbaron, Shootr liked this post
  5. #3
    Mar 2014
    Troy MI
    11. Painted
    Name:  11. Painted.jpg
    12. Mounted on cargo carrier
    Name:  12. Mounted on cargo carrier.jpg
    -Don
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  6. Likes _Weldman_, whtbaron, farmersammm liked this post
  7. #4
    May 2021
    45.97267, -106.27818
    I would replace the pin in the receiver with a 5/8" fine thread bolt lock nut to take the slop out.
  8. #5
    How are you liking that Minion square? I've been thinking about getting a set since they're smaller than their brothers, but....
  9. #6
    That will work.
    When through bolting wood, using 1/4" plate and drilling a hole excedes a basic flat washer.
  10. #7
    Mar 2014
    Troy MI
    Quote Originally Posted by _Weldman_ View Post
    Good idea.
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  11. Likes _Weldman_ liked this post
  12. #8
    Mar 2014
    Troy MI
    Quote Originally Posted by VaughnT View Post
    I really like all of the Fireball Tools. I noticed that my Minion square has some improvements over the original square that I purchased. It has tapped holes on both sides, which makes it easier to gain access for clamps. It also has knurled screws so that you donít need any tools.
    -Don
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  13. Likes whtbaron, VaughnT liked this post
  14. #9
    Mar 2014
    Troy MI
    That will work.
    Good point, thanks for the suggestion.
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  15. #10
    Quote Originally Posted by Don52 View Post
    I It also has knurled screws so that you donít need any tools.
    -Don
    Hey! I also use knurled screws on my homemade squares. LOL
  16. Likes _Weldman_, VaughnT liked this post
  17. #11
    Mar 2014
    Troy MI
    I love your huge squares. The larger size Fireball squares are on my wish list.
    -Don
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  18. Likes _Weldman_, VaughnT liked this post
  19. #12
    Mar 2014
    Troy MI
    Here is a picture that Rick just sent to me showing the bicycles mounted to the rack.
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  20. Likes Lis2323, whtbaron, Larry4406 liked this post
  21. #13
    Aug 2021
    with the bolt idea, how about making bolt over length then drilling a cross hole so a padlock can be put through. then not only will it stop a thief just unbolting it and walking off with everything, it also means that if bolt starts to back out it can't go very far.
  22. #14
    Quote Originally Posted by ghost_walker View Post
    Good idea but it would be a pretty tiny shackle for going through the 5/8" bolt.
  23. #15
    Aug 2021
    if it makes it more awkward to steal, only those who really really want it will have a go at it.
  24. Likes Lis2323 liked this post
  25. #16
    Apr 2012
    Montreal area Canada
    nowadays thiefs have cordless grinders, they can steal whatever they want if you give them a minute....
  26. Likes Lis2323 liked this post
  27. #17
    May 2021
    Never had a nut back off on the combination I posted and I have driven thousands of miles with a 12k winch I custom fabricated to go in to a hitch receiver tube.
  28. Likes Lis2323 liked this post
  29. #18
    Mar 2005
    Under a Rock
    At least the tail lights are somewhat visible.
    I always shake my head when I see idiots with 10 bicycles on the back of their little sh*tbox car..... completely blocking the tail lights and marker tag.
    Good way to get rear ended.
    and I've actually seen that happen.....
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  30. Likes _Weldman_ liked this post
Page generated in 1,634,497,891.28807 seconds with 13 queries
