Results 1 to 13 of 13
Thread: Stel S300 on a 400V, 3-phase up-converting transformer
    Laredo, Tx
    Christmas comes early. Received my Stel S300 plus a mystery box
    Conductors are tiny! Very little amperage needed.
    Checking the voltages. Nicely balanced, coming from the 3-phase transformer that is being fed from the 30HP rotary phase converter
    Can't wait to put it through it's paces.
    Laredo, Tx
    Re: Stel S300 on a 400V, 3-phase up-converting transformer
    Laredo, Tx
    Stel rates the machine to be able to use 8mm (5/16") carbons.....hmmm
    what do y'all think?
    May 2010
    ct.
    How much will it draw on the single phase side of the phase
    converter if you run the welder wide open?
    Miller a/c-d/c Thunderbolt XL
    Millermatic 180
    Purox O/A
    Smith Littletorch O/A
    Hobart Champion Elite
  6. #5
    Laredo, Tx
    Not sure. I don't have a setup to measure it atm.
  7. #6
    Laredo, Tx
    opened it up to blow out the dust. Fully enclosed "wind tunnel" design. I like it.
    Beefy.
  8. #7
    CT
    Beefy.
    Really? You expected to have a dust problem in a brand new welder? SMH. I would respect you more if you just said "I wanted to see what it looked like inside".
    Miller Multimatic 255
  9. #8
    Laredo, Tx
    It was a combination of both because the times I do metalwork, it is inside my closed garage so there's plenty of fine dust floating around. In those pics I already blew out the little dust that had gotten inside. I didn't realize I had explain my each and every decision that goes with my thoughts.
  10. #9
    Jan 2005
    Looks like it could be made in any place in the world. Just by layout alone. Top exposed horizontal board is pretty standard old school inverter design, and side mounted capacitor,s without much holding them on the board, looks a little suspect to drop damage.. Of course this will be fine if only sitting in a garage.. I guess everything is built to a price point and what gets you by.. Look at a Hypertherm 45xp, and you can tell there was a lot of thought in making a very nice designed inverter.. (IMO)
    Esab/Lorch ET-220i
    Esab 160i caddy
    Esab CV353
    Thermal LM-200/ Lincoln feeders
    Thermal 60i- 3phase
    Pak 50
    Thermal 35C
    Thermal 15c
    INE 1500
    Klutch 220i
    Blue Demon/140 msi/90sti
  11. #10
    Apr 2022
    What is a "Helding Welmet"?
  12. #11
    Nov 2014
    Southern CT
    Your the only person I know that has 400V-3phase in the USA. Did you get that through HTP or directly from Stel?
    Ernie F.
  13. #12
    Laredo, Tx
    I actually have 3-phase in 208V, 240V, 400V, 480V, & 600V. The multi-tap transformer I have simultaneously up- and down-converts with all taps hot at all times.
    I asked HTP to special-order me this welder. I love being different.
  14. #13
    That transformer cost a lot.
Page generated in 1,664,114,547.81632 seconds with 12 queries
