Results 1 to 15 of 15
Thread: Pole for Offset Bird Feeder
    Mar 2014
    Troy MI
    My friend and customer Chuck wanted a sturdy pole to hold a bird feeder bracket. The problem is that for some reason the arm of the bracket was three feet long, so it would apply a moment load to the pole. The other problem is that he wanted to mount the bracket 6-1/2 feet high so that people could walk under the bracket without hitting it. The first step was to make a SolidWorks model of the pole.
    1. Concept Model
    Name:  1. Concept Model.jpg
    I find that my mister is great for keeping the part cool while taking heavy cuts.
    2. Mister to keep part cool
    Name:  2. Mister to keep part cool.jpg
    I needed to cut a slot in the pole. To fit the pole in the room where my milling machine is located I had to rotate the waist of the Bridgeport and extend the ram as shown below.
    3. Offset waist of Bridgeport
    Name:  3. Offset waist of Bridgeport.jpg
    4. Slot milled
    Name:  4. Slot milled.jpg
    I used my lathe to chamfer the end of the pipe. I know that the chamfer doesn’t require the accuracy provided by the lathe, but I have a lathe and this is a very fast operation.
    5. End chamfered
    Name:  5. End chamfered.jpg
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Clausing/Coldchester 15" Lathe
    16" DuAll Saw
    15" Drill Press
    7" x 9" Swivel Head Horizontal Band Saw
    20 Ton Arbor Press
    Bridgeport
    Lincoln LE 31 MP & Lincoln 210 MP
  2. Likes Shootr liked this post
  3. #2
    Mar 2014
    Troy MI
    Re: Pole for Offset Bird Feeder
    6. Loose parts are made
    Name:  6. Loose parts are made.jpg
    7. Tack welded the tap plate
    Name:  7. Tack welded the tap plate.jpg
    8. Tap plate welded out
    Name:  8. Tap plate welded out.jpg
    9. Tip welded to tube
    Name:  9. Tip welded to tube.jpg
    10. Cross plate welded
    Name:  10. Cross plate welded.jpg
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  4. Likes Shootr liked this post
  5. #3
    Mar 2014
    Troy MI
    11. Tip painted
    Name:  11. Tip painted.jpg
    12. Cross plate painted
    Name:  12. Cross plate painted.jpg
    13. Cap installed on end
    Name:  13. Cap installed on end.jpg
    14. All done
    Name:  14. All done.jpg
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  6. #4
    Arizona
    That's just beautiful. I really enjoy posts like this. As a fledgling wannabe weekend warrior, these give me goals to shoot for. Also reminders that just because something seems simple it doesn't mean I should take any shortcuts or not go 100% to make it well.
    Yeswelder MIG-205DS
  7. #5
    Southern California
    Awesome.
    I would have had to try it out as a javelin before painting...
  8. Likes Kevin_Essiambre, whtbaron, rhunt liked this post
  9. #6
    Pensacola , Fla
    Watch out for the squirrels, little buggers are always swinging off my wife's feeder trying to ge in.
    Hypertherm 65
    Everlast PowerTig 255 EXT
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
  10. #7
    Mar 2014
    Troy MI
    My friend and customer Chuck sent me a picture of the installed bird feeder. I still am not sure why he required a three foot cantilevered bracket to support the bird feeder, but his wife is thrilled with it.
    15. feeder installed
    Name:  15. feeder installed.jpg
    -Don
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  11. #8
    Very nice work. The only thing I'd suggest to help keep the squirrels at bay would be attaching a Slinky at the top of the pole. Of course, with the red trellis there, squirrels could just use it as a launching platform.
  12. #9
    Los Angeles
    Quote Originally Posted by Don52 View Post
    -Don
    Looks like they wanted it to hang out over the flow bed.
    MM211 (Sold)
    Klutch 120v Plasma cutter
  13. #10
    Looks great hard for a cat to climb too.
    1. Concept Model
    4. Slot milled
    5. End chamfered
  14. #11
    Mar 2014
    Troy MI
    Quote Originally Posted by VaughnT View Post
    Or a squirrel ladder.
    -Don
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  15. #12
    Mar 2014
    Troy MI
    I was thinking that if they put the pole in the flower bed, they could have used a shorter cantilevered bracket. I know that Chuck’s wife bought the bracket first. He is a wise man to request a sturdy bracket that allowed him to use the bracket as it is.
    -Don
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  16. #13
    Mar 2014
    Troy MI
    Thanks, I bet the clever squirrels will eventually figure out a way to climb the red trellis.
    -Don
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  17. #14
    I know the squirrel will make it pole with dog pushing the squirrel up the pole.
    -Don
  18. #15
    Outside of Raleigh, NC
    Nicely done!
    Miller Trailblazer Pro 350D
    Miller Suitcase MIG
    Miller Spectrum 2050
    Lincoln 210MP
Page generated in 1,638,680,501.43999 seconds with 13 queries
