Page 3 of 3 FirstFirst 123
Results 51 to 62 of 62
Thread: Help me choose a belt grinder and sander
  1. #51
    Sep 2021
    USA
    Re: Help me choose a belt grinder and sander
    I'm not sure about this statement "There are good and bad in every design, so don't let perfection be the enemy of good enough."
    If you are building a tool for yourself to have for sometime to come, do it right. There is not shame in making changes to make it better.
    Now to the grinder I built a 2" X 60" belt grinder (maybe 1985) and used the heck out of it. It was simple 2-- 6" wheels and a vertical platen 2 HP motor loved it did great. About 2 years ago I moved to a 2" X 72" belt grinder, these things are so flexible, they have many grinding possibilities. Being able to adjust the angle of the grind and different optional attachments allows then to fit into many projects start to finish. I understand not everybody can afford or have the time to build one but if you do you will be happy you did. This is the Jeremy Schmidt design, I did make a few changes, I did CNC Plasma cut the custom shaped parts.
    Nice grinders. That's the thing that i noticed, 2x72 belt grinders are versatile. I saw knife makers use a surface grinding attachment for their 2x72.
  2. #52
    Perhaps at this stage of the game I wouldn’t get too caught up on horsepower.
    My older Burr King 2”x48” is only 3/4 HP and if it was my only belt grinder I could get by just fine with it. Keeping in mind I’m not a pro or a knifemaker.
    Also that Jet Vaughn T has would be ideal, especially if you found one used.
  3. #53
    Sep 2021
    USA
    This eastwood belt grinder is cheap, its only $200, but i wonder if it will bog down under a load.
    https://www.eastwood.com/1-2hp-8in-c...t+sander+combo
  4. #54
    Sep 2021
    USA
    Maybe I'm wrong but it seems like some motors outperform other motors of the same HP. Those Jet grinders seem like a good brand but they start out at $500. It would be worth it if they don't bog down under pressure.
  5. #55
    Sep 2021
    USA
    Quote Originally Posted by Need Advice View Post
    After reading reviews on this grinder i dont know if this is a good grinder. One person said no one sells the size belt this grinder takes, he said you have to special order them. That's not for me if its true. Unless this person is wrong. It takes a 2x28 belt. I have seen them with a quick google search
  6. #56
    The majority of my grinders regardless of the make have Baldor motors.
  7. Likes Need Advice liked this post
  8. #57
    No idea but import motors generally have exaggerated HP ratings.
  9. #58
    Generally speaking any belt size is available but without a doubt the major belt manufacturers offer the greatest variety of grit/composition selections in 2”x72”.
    And probably the best grinding cost value can be had from using a 2x72 machine. IMO
  10. #59
    Sep 2021
    USA
    Eastwwod does have a return policy.
    (If any item* is not satisfactory, you may return it for a full product refund (less S&H) within 60 days ofreceipt.)
    Maybe i should try out their grinder. Its the cheapest option i have found so far. It might get me by until i get funds and time to build a 2x72 grinder. I can go that rout or buy the multi tool brand attachment for grinders. I don't know but its something to think about.
  11. #60
    Sep 2021
    USA
    Generally speaking any belt size is available but without a doubt the major belt manufacturers offer the greatest variety of grit/composition selections in 2”x72”. IMO
    Thanks. something to consider.
  12. #61
    Sep 2021
    USA
    I think i might just get the multi tool attachment. After thinking it over i think it will work on my RA saw motor. And i could use it in the vertical position like i would prefer. All i need is to make an adaptor so it would bolt onto the part that the blade guard usually bolts onto. I'm sure it will work but if not I'll get a good bench grinder because mine bogs down easily.
  13. #62
    Sep 2021
    USA
    What nice about the radial arm saw motor is I can put the multi tool belt grinder on one side and a drill chuck on the other side which i can use for either a disc or drum sander attachment. Its also a 2 HP motor with 3500 RPM which is ideal unless I'm mistaken. Its almost too perfect. I definitely need to try that out. I also have two of those motors, i could make two grinders or have one for a spare motor.
Page generated in 1,713,255,171.84903 seconds with 21 queries
