Results 1 to 25 of 34
Thread: Is this weld too cold???
    Nov 2019
    North East Ohio
    Almost all of my MIG welds are cursive e style, I also keep the settings at "what the book says". The welds look fine but not the perfect stack of dimes that people like. I was bored and backed down the volts for the second and third picture.
    The material is 3/16 thick tubing with an 1/8 gusset.
    The first picture is at the 19 volts 351 IPM. Note not the sharp edges on the loops. This setting is for 3/16 material.
    The second and third picture is 18.3 volts and 293 IPM. Note Sharper edges. This setting is really for 1/8 material.
    Neither picture is my prettiest work, just typical. Ascetics is not important for this job, the application is to hold lights for a light tunnel you drive through.
    Customer is always happy I have made probably 1,000 of these things.
    The question is does the second third picture look too cold?
    Re: Is this weld too cold???
    It looks like solid wire.
    If looking for better weld use flux core with gas or no gas.
    The only time used solid wire when at some else shop.
    Sep 2009
    Get some small scrap pieces and weld a t joint. Only weld about 1"-1 1/2" . Then put it in a vise and bend the vertical piece back and forth until it breaks. This is called a break test. If the vertical piece breaks off around the weld bead it has good penetration. If the joint breaks across the weld.... Well you know the answer. We have these debates all the time at work and the Weld Inspectors alway settle it with a break test.
  4. Likes Reebz, BD1 liked this post
    Jan 2020
    Tighten up your whip (in your case make smaller e's). The stack of dimes thing is not relevant to GMAW. The science says so. Your welds in the 2nd photo are not wetting out on the toes. This could have to do with your push/pull angle as well as voltage/amperage settings.
    Lincoln 275 Squarewave
    Lincoln SP 250
  6. Likes Reebz, Louie1961 liked this post
  7. #5
    CT
    Not so much "too cold" as you are stepping out too far as you start a new cursive "e". Volts controls the shape of the bead not the penetration. Wire feed speed controls the amps and thus the heat. Decreasing the volts causes the weld to pile up or crown more, increasing the volts causes the weld to flatten. so too cold doesn't seem to be the issue to me. I like the way the toes wet in on the first picture (recommended settings). I think what you really want to do is make narrower "e"s and get the dimes to sit closer together. The way you are doing it now the welds almost look like a string of tack welds. Just tighten up the loops, use your recommended settings and maybe proceed just a tad slower and I think you will be really pleased with the result.
    Miller Multimatic 255
  8. Likes Reebz, scsmith42 liked this post
  9. #6
    Nov 2019
    North East Ohio
    Thanks Guys. I will tighten the loop and slow down. These pictures are after a long day and screwing around trying "to get the look".
  10. #7
    Sep 2016
    Detroit, Michigan
    I still don't know why someone would want a weld that looks good but might be weaker....
    http://mivise.com
    Hobart Champion Elite
    Everlast PowerTig 210EXT
  11. #8
    Nov 2019
    North East Ohio
    I get what you are saying and agree. I said it was typical work for me that is inaccurate I was experimenting and dragging *** tired. I will post my typical at the end of the day. But I'm still dragging ***. lol
  12. #9
    Nov 2019
    North East Ohio
    I think I'm back on track. I'm not really trying the stack of dimes look here.
  13. Likes Louie1961, Lis2323 liked this post
  14. #10
    CT
    looks much better
  15. #11
    Those welds are just sitting on top of the plate. And although very decorative, Like tig welds.
    But they have very little structural strength, Load bearing mig welds should be burned into the plate
    and smooth and flat on the top
  16. #12
    Nov 2019
    North East Ohio
    Josey I will snap another picture from a different angle. I think they are burned in.
  17. #13
    CT
    You can't tell that from those pics. Those toes in the first pic are wetted in nicely.
  18. Likes Munkul liked this post
  19. #14
    Mig can make beautiful looking welds.
    As stated, do a bend test.
    Ive repaired factory welds where the weld was only laying on top. The latest was a farm 3 point backblade. It still lasted for years.
  20. Likes vpd66 liked this post
  21. #15
    Nov 2019
    North East Ohio
    Here is a different angle, not the prettiest weld.
  22. #16
    Nov 2019
    North East Ohio
    So T joint bend test Thursday. What is your method?
  23. #17
    CT
    Or cut and etch
  24. #18
    Nov 2019
    North East Ohio
    I need to look up what to etch with
  25. #19
    Google is your friend.
    Many if not most acids work. I'd try "The Works" toilet cleaner (hydrochloric acid).
  26. Likes _Weldman_ liked this post
  27. #20
    CT
    Naval jelly works, just slowly. Oven cleaner works too
  28. #21
    Jan 2011
    W. Wisc
    The horizontal weld in post #9 looks cold on the side with the plate with the hole in it, to me. I'm good at making cold welds so should know!
    You can etch with most acids. Vinegar will even do it super slow. I used some Ospho recently as it was handy and that worked well after a couple minutes contact. Naval jelly should do it and easy to find in hardware stores too.
    -Dave
  29. #22
    Jul 2018
    Cumbria, UK
    I think your settings look good, maybe slightly cold (hard to tell) but you're travelling too slow. The bead is bigger than it needs to be.
    IMHO mig on steel should be pretty smooth, the dimed look is generally an indication of to much manipulation, too low a wire speed and not enough straight welding. If you're welding on the flat, turn it up and travel faster.
  30. Likes vpd66, Welder Dave liked this post
  31. #23
    Southern California
    I would cut and etch some samples to be sure. You might be surprised what you find.
    Like mentioned before any acid works to etch, the weaker acids just take longer to do so (even household vinegar works) .
    Looks like you're not getting root penetration (the main problem in penetration vs fillet weld) by the way the ends are rolled over the steel and not wet in.
    Gun manipulation can cause you to keep the arc too far back in the puddle and not burn into the base steel corner root - This is why many people recommend stringers.
    When manipulating the gun make sure you are burning into the root of the steel and THEN filling in after it. When I weave I tend to just trace the leading edge of the puddle (progressing half moon or V shape depending), making sure i am melting into the corner of the base steel.
    Fillet IMO welds are the easiest to look sound, but not have proper penetration at the root.
    I know I've made plenty of great looking fillet welds with the toes beautifully wet in and everything - only to cut and etch and see zero root penetration.
    Best of luck!
  32. #24
    I agree with Munkul, your settings look good. You just have to speed up a bit. Maybe use slightly more of a push angle. I don't do cursive E's but twist my wrist side to side slowly to get good wetting at the toes. Arc should be close to the leading edge of the puddle to ensure good fusion.
  33. #25
    Nov 2019
    North East Ohio
    I agree, I just loaded the truck with 200 finished pieces. The ones I took pictures of are not my typical work as I stated before, I think I was just tired and had poor gun angle and tried to compensate with going slower. I think I did this subconsciously, hell if I know at this point.
    I always check my work when once I'm done welding it and before I load it. I pulled 6 pieces all from that days batch.
    When I started back up in the morning I felt like my old self and had nice "wet toes".
    I have another 100 to go and will take a picture or two.
    Weird how you forget the basics when tired.
Page generated in 1,638,789,933.99345 seconds with 13 queries
