Page 2 of 2 FirstFirst 12
Results 26 to 37 of 37
Thread: Modification to easily install table on horizontal/vertical bandsaw without bolts.
    Sep 2021
    USA
    Re: Modification to easily install table on horizontal/vertical bandsaw without bolts
    I just put a large plate on the roller braket (2"2"׼ flat bar)
    All need to do is put saw in the vertical position and start cutting.
    Sounds good. Thanks.
    Thought you were going to convert your portable bandsaw to vertical? That set up with a foot switch would be more convenient. It does take space to verticalize your horizontal bandsaw. You notice the space consumption when you use it close to a wall and have to pull it away for vertical use.
    Sep 2021
    USA
    I was going to convert my portable saw before i decided to buy the horizontal/vertical bandsaw. I wasn't crazy about using that portable anyway because its kind of loud.
    Sep 2021
    USA
    Someone recommended a benchtop bandsaw. I liked the fact that the benchtop model pivoted for miters like a miter saw does, but that saw is loud like a portable and that's why i decided against it. I really like this 4x6 horizontal/vertical saw. Its quiet and versatile, and affordable.
  5. #30
    Dec 2008
    Quote Originally Posted by Need Advice View Post
    I'll admit that my Delta 4x6 is pretty quiet. All of my noise was originally coming from the stand and blade cover. Once those were fixed all I hear is the shhh of the cut and the whurr of the motor.
  6. Likes Need Advice liked this post
  7. #31
    Sep 2021
    USA
    Quote Originally Posted by upand_at_them View Post
    When i buy a quality angle grinder I'm going to try to get one with a brushless motor because they are quieter. I have an M18 fuel cordless grinder with brushless motor but i need a corded grinder.
  8. #32
    Dec 2008
    Brushless is also more powerful or last longer because of no brushes. I would wear hearing protection no matter what. When you lose your hearing you can't wish it back. Same goes for vision and lungs.
  9. #33
    Sep 2021
    USA
    I agree. My hearing is already bad.
  10. #34
    Sep 2021
    USA
    I had another crazy idea. I wonder if you can mount a bandsaw on a hub assembly so you can pivot the saw right and left like a miter saw does. I bet it can be done pretty easily with a hub assembly and a mounting plate for the saw to mount to. The tricky part would be cutting or drilling the stops for the various angle degrees. Maybe that's not needed though.
    Lincoln Pro MIG 180
    Chicago electric 225 Arc
    Harris oxy fuel
    Everyone who calls on the name of the Lord will be saved. Romans 10:13
  11. #35
    Yes. The pivot would need to be applied under the hinge area. And preferably detached from the table otherwise you will still be readjusting the metal / saw for miters. I have several new and used wheel hubs for such projects. Good luck.
  12. Likes Need Advice liked this post
  13. #36
    Sep 2021
    USA
    Thanks for the reply. A miter saw pivots under the blade so i was thinking of mounting it under the cutting area of the blade.
    Lincoln Pro MIG 180
    Harris oxy fuel
  14. #37
    You are correct. Middle of the blade for pivot location.
  15. Likes Need Advice liked this post
Page generated in 1,638,512,148.89888 seconds with 12 queries
