Results 1 to 15 of 15
Thread: Jack Repair
    Jack Repair
    This is the one I bent like a noodle a few weeks back
    Name:  jack repair7.jpg
Size:  238.9 KB The thing wouldn't budge, so the area where the bend occurred had to be slit, and cut off.
    Name:  jack repair8.jpg
Size:  239.3 KB The cut off section has some damage, and wouldn't have slid off unless it was slit.
    Name:  jack repair9.jpg
Size:  199.9 KB Taking a look at the bend, and where heat will be required to straighten in. The heat is applied to the top flange, and both sides, in the pie shaped pattern, then hit with water to hasten the shrinking process. Nary a hammer, or heavy object will touch this piece. It's all a heat shrinking process.
    Name:  jack repair10.jpg
    Name:  jack repair11.jpg
Size:  219.1 KB Damage to the inner tube from cutting the section of outer tube is filled, and ground flush. I don't do MIG, so y'all can just kiss my butt
    Re: Jack Repair
    Name:  jack repair12.jpg
Size:  208.9 KB The clamps are tightened a bit, not too much. Very little force is needed...............the clamps are mainly for restraint.....keeping the metal from expanding beyond the upset point. They'll loosen once the steel starts to shrink. Heat is kept to around 1200*
    Name:  jack repair13.jpg
Size:  212.3 KB Here you can see how the heat is applied. I generally don't need to go beyond the neutral axis on tubing. Depends on the severity of the bend. This piece took about 3 different heating cycles in 3 places to get it straight.
    Name:  jack repair14.jpg
    Name:  jack repair15.jpg
    Get back to it tomorrow. Put the cut off piece back on, and then focus on either straightening, or replacing, the thingy that pins the jack to the baler.
    Re: Jack Repair
    Name:  jack repair17.jpg
Size:  220.4 KB The main tube was also bent, and had to be smoogied. Shrining was made easy by using the inner tube to apply the necessary force when retracted.
    Name:  jack repair18.jpg
Size:  246.7 KB Inner tube is blued to see where the interference is.
    Name:  jack repair19.jpg
Size:  216.6 KB Just that one spot was hanging it up.
    Cut off portion was reattached using scabs/fishplates. The welds look like someone at Vo Tech did 'em. Earliest they can take me for the cataracts is in late December.
    Name:  jack repair20.jpg
Size:  181.9 KB Fully extended.
    Name:  jack repair21.jpg
Size:  182.3 KB Fully retracted past the previously damaged portion. I guess it's a success
    The square tubing that attaches the jack to the baler was heat worked, not heat shrunk. It was heated to orange, a bar inserted in the holes, and twisted back into rough shape.
    Re: Jack Repair
    Name:  jack repair22.jpg
Size:  246.9 KB Ready to go
    The baler was on a hydraulic jack (all my cribbing is in use on other stuff, and the equipment stand is under the Allis), which shifted, and the baler fell off. It's still under the tongue. I'm hoping the pickup reel wasn't damaged when the baler fell. I believe the baler weighs somewhere near 5K, with a huge proportion of the weight on the tongue. I guess we'll find out when I put the little crane back on the Oliver to lift it up today.
    Re: Jack Repair
    Looks good. Probably better than new but I would likely have gone this route here and that's CAD$: https://www.princessauto.com/en/5000...t/PA0008051013
    ---Meltedmetal
    Re: Jack Repair
    Me too, but here's the route I would have gone. https://www.princessauto.com/en/5000...t/PA0008055055
    I've been picking up the 5,000 to 8,000 lb drop legs that weld on for most of my equipment and I love em. I can usually pick them up on sale for $40 to $60 Cdn. They don't shift sideways when you try to unhook like the pinned versions do. Just Chinese junk, but I have yet to have problems with one. I did the same thing Sam did with a rented spreader and replaced the bottom piece with new square tubing drilled full of holes and welded to the original base. It was also a weld on drop leg so no issues with where it attached to the frame.
    Cut 50 Plasma
  7. Likes snowbird liked this post
  8. #7
    Re: Jack Repair
    Even better than the one I listed.
    ---Meltedmetal
  9. #8
    Re: Jack Repair
    Sam. A few old railway ties Sawn into 18" lengths make perfect stands for placing under any jacked up equipment
    I always have a few handy and wouldn't go under anything without placing them first.
    Just a suggestion I find very handy and safe.
  10. #9
    Jun 2016
    Re: Jack Repair
    yes and railroad ties and treated lumber cutoffs don't bend!!!!
    lincoln 125sp
    dayton 250 ac/dc
    miller 211 w/spool gun
    ahp 200 sx tig
    lotos ltp5000d
    kubota b3200 FEL BH
    of course duramax diesel
  11. #10
    Re: Jack Repair
    Dagnabbit Samm.... you cursed my jack! At least I got it stopped before the square tubing got tore up. Hit the corner of the tire on a sharp turn and tore off the spring loaded retaining pin. I think I'll drill some more holes and use a through pin... nothing to catch the tire next time. I know the baling twine is passe but it's all I had handy at the time....
    Sometimes you just have to make do with what you have....
    Cut 50 Plasma
    Jack Repair
    My dad wired everything up. But I gotta admit he was a PRO. His wired up jobs looked “factory “. LOL.
    Must have been because he was in the army. Military precision
  13. Likes whtbaron liked this post
  14. #12
    Re: Jack Repair
    No cows and the miles of telephone wire I rolled up in the 70's is pretty much gone. I have to resort to the newer plastic materials...
    Cut 50 Plasma
    Southern California
    Re: Jack Repair
    Great work.
    Heat bending and straightening is always fascinating. It's truly an art of understanding the nature of metal, and sammm you are quite the artist in this regard.
    I love the zip tie cotter pin, I've heard stories of everything from green wood/bark, tape, nails and screws, wires of every type, and even super glue (most used to make more of a lump than a pin) saving the day and getting stuff limped home.
    We always have at least a few rolls of thick and thin bailing or rebar wire around at all times, and it gets used consistently!
  16. #14
    Re: Jack Repair
    All our new 50 and 100 pound jute/burlap sacks came in big bundles secured by a really good grade of steel wire.
    We always had a pile of 10 foot lengths around. Nice for gas welding with too.
  17. Likes rhunt liked this post
  18. #15
    Aug 2012
    AR
    Re: Jack Repair
    A coffee can in your truck or tractor with large nails and small garden spikes work too for emergencies. Just don't spill them in the field!!
  19. Likes whtbaron liked this post
Page generated in 1,638,066,954.67346 seconds with 13 queries
