Page 2 of 2 FirstFirst 12
Results 26 to 50 of 50
Thread: Plasma cutting table question.
    Pensacola , Fla
    Re: Plasma cutting table question.
    this is what I use on my Plasma table to dry the air, I have since mounted it to the cart for my Hypertherm 65.\there are Kitty litters that are made with Silica Gel much cheaper.
    Hypertherm 65
    Everlast PowerTig 255 EXT
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
  2. Likes Need Advice liked this post
  3. #27
    Sep 2021
    USA
    Thanks. Very informative video.
    Lincoln Pro MIG 180
    Chicago electric 225 Arc
    Harris oxy fuel
    Everyone who calls on the name of the Lord will be saved. Romans 10:13
  4. #28
    Sep 2021
    USA
    I plan on building a dryer out of pipe and drain valves similar to the one in the video below, and then downstream i can add one of those silica jell filters like you use. I used one of these pipe style dryers at a shop i use to work at, it can trap a lot of water before it gets to the other filter. This guy in the video uses water separators at the bottom of the pipe but the one i used simply had drain valves at the bottom of each pipe that you could open up to drain the system.
    Lincoln Pro MIG 180
    Harris oxy fuel
  5. #29
    Pensacola , Fla
    by the time you pay for all those filter and copper pipe you may as well buy a Refrigeration type dryer. I bought one plumbed it into the system, never powered it on.
    Hypertherm 65
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
  6. #30
    Sep 2021
    USA
    Not quite. The copper will be much cheaper than one of those dryers. I thought about using pex tubing instead of copper but i don't know if that will work the same as metal pipe.
    Lincoln Pro MIG 180
    Harris oxy fuel
  7. #31
    Sep 2021
    USA
    I figure it would cost about $150 for the pipe, fittings, and valves. If you added water separators instead of valves the price would be much higher depending on the particular filter units.
    Lincoln Pro MIG 180
    Harris oxy fuel
  8. #32
    Dec 2008
    Black iron pipe is cheaper than copper. All of those water separators in the post #28 video are wasted money. If the water separator separates out the water, what does he think the ones after the first one are doing? Just need one at the tool hookup. A drain at each leg may be unnecessary...People are saying that almost everything is caught at the first drain, a wee bit at the second drain, and nothing at subsequent drains. An aftercooler after the compressor and before the tank is a good idea...It cools the air, removes a lot of the water, and reduces tank rust..
  9. #33
    Sep 2021
    USA
    Quote Originally Posted by upand_at_them View Post
    i agree those separators are unnecessary
    Lincoln Pro MIG 180
    Harris oxy fuel
  10. #34
    The older Miller plasma torches were far from great (really far actually) so comparing one as if it's the same as a newer much improved Miller plasma doesn't wash. Just get a water separator with either a spin on filter or a Motor guard filter that uses a cartridge. The Motor Guard can even use a roll of toilet paper in a pinch. Consumables that are less cost but you go through a lot more is not saving money.
    https://www.summitracing.com/parts/mgc-m-60
  11. #35
    That is what I would do.
  12. #36
    Apr 2016
    CA
    I use this right at the plasma cutter. I also have a cheap water separator from HD right at the compressor. It works ok not the best solution but I get by. I really like the idea acourtjesture uses with desiccant beads but kitty litter beads to save money. The Motor Guard is a must though IMO.
  13. #37
    Sep 2021
    USA
    I don't know how old that miller was, the guy never said. Thanks for your input.
    Lincoln Pro MIG 180
    Harris oxy fuel
  14. #38
    Sep 2021
    USA
    A guy in a video i saw claims you can dry out those beads in the oven and reuse them.
    Lincoln Pro MIG 180
    Harris oxy fuel
  15. #39
    Quote Originally Posted by Need Advice View Post
    Nice. Possibly toxic fumes in your home oven.
    Thanksgiving dinner at Need Advice's. LOL
  16. Likes N2 Welding liked this post
  17. #40
    Sep 2021
    USA
    lol, you have a point. You could use a cheap toaster oven. Ive seen bladesmiths use them for tempering blades.
    Lincoln Pro MIG 180
    Harris oxy fuel
  18. #41
    Pensacola , Fla
    Yes you can recycle the kitty litter, I also use in a dry box for 3-D printer filament, Ebay sells these little battery powered humidity indicators I put one in the storage box so I can see if the stuff is good.
    https://www.ebay.com/itm/30380626147...Cclp%3A2047675
    Hypertherm 65
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
  19. Likes Need Advice liked this post
  20. #42
    Yes you can recycle the kitty litter]
    No thanks. I'll pass...
  21. Likes Need Advice liked this post
  22. #43
    Pensacola , Fla
    I hope you did not think I was talking about the stuff out of the kitty box
    I don't mix them up
    Hypertherm 65
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
  23. #44
    I had an aunt that refused to buy recycled toilet paper. She told me, "There's some things you just shouldn't recycle."
  24. Likes N2 Welding, Lis2323, Need Advice liked this post
  25. #45
    Sep 2021
    USA
    You can buy the beads that change color when the beads need changed.
    Lincoln Pro MIG 180
    Harris oxy fuel
  26. #46
    Ceres, California
    Motor guard filters can be dried out and reused. just get a couple of them and cycle them. You don't want to leave a wet filter in the housing for a long time.
    A wet filter will cause the paint to fail and the housing to make AL dust.
    I open my filter at the end of the day and let it dry. Filters can be reused until they fill up with oil or start falling apart.
  27. Likes N2 Welding, Need Advice liked this post
  28. #47
    The technical term is "they work until they don't".
  29. Likes N2 Welding, Need Advice liked this post
  30. #48
    I have a homemade unit on my Atlas Copco that works extremely well but I don't recommend it and would not do it again.
    Should have bought a refrigerated dryer.
  31. Likes Need Advice liked this post
  32. #49
    Sep 2021
    USA
    That compressor looks like a beast. What's the oil thing on the top for? I would assume its to add oil to the compressor but why is it so big?
    Lincoln Pro MIG 180
    Harris oxy fuel
  33. #50
    Oil yes.
    This is the beast I sold.
    I would have to rob the piggy bank for oil changes. $500 /20 litre pail for synthetic oil. (Aprx a pail and a half per change.)
  34. Likes Need Advice liked this post
Page generated in 1,713,292,960.49488 seconds with 20 queries
