Results 1 to 7 of 7
Thread: Lincoln Ranger 8 will not weld
    Sep 2021
    Lincoln Ranger 8 run fine welded about an inch and quit. It will only spark a little on end of rod. The machine set up for about 6 months but had been used for aux power once in the 6 month period, Aux power output is fine just wont weld. The machine only has 294 hours on it. Followed troubleshooting guide including checked and cleaned brushes/rotor.
    Re: Lincoln Ranger 8 will not weld
    See if brushes and or commutator need cleaning.
    Quote Originally Posted by TK101 View Post
    Dec 2008
    Were you welding on DC or AC?
    If it welds on AC but not DC that could indicate one or more open diodes
    If it doesn't weld on either AC or DC then check both leads at both ends.
    Sep 2021
    I was welding on DC+. Unhooked shorter leads on machine and hooked up longer leads an it welded about an inch. Then just spark. Hooked shorter leads back up and same thing.
    Sep 2021
    Checked and cleaned. Still will not weld
    Jul 2012
    Did you check/test D2 , it's a bridge rectifier.
    Feb 2023
    Im having the same issue with mine, curious to see what the fix is
Page generated in 1,713,306,385.05787 seconds with 18 queries
