Results 1 to 7 of 7
Thread: Manny
    Oct 2021
    Manny
    Hi, Iím Texas and I own a 5 acre pecan farm that Iím planning to fence in using 2 1/2Ē oil field pipe. I have a regular stick welder that I normally use, but I need a small gasoline welder for this project. Iíve looked around the internet and checked various reviews, but but to no avail. Iím looking at a Lincoln Bulldog at Home Depot and a Tomahawk from Lowes. My brother in law had a Bulldog that he did a similar project and was very pleased. I really would like some inputs from you all.
    Outside of Raleigh, NC
    Re: Manny
    You have several options.
    1. Buy or rent a generator to run your existing stick welder. At least 10KW and 12KW unit would be best. If your current stick welder is an AC/DC machine, going this route will allow you to use DC and 6010 for welding the oil field pipe. You can probably get by with 6,500 watt minimum, but more is better.
    2. Buy or rent an engine driven welder. I'd consider something used. I don't know where in Central Texas that you're located, but there are several used Lincoln welders on the Waco Craigslist for 2,800 on up.
    If you go new, of the two that you listed I'd lean more towards the Lincoln.
    Miller Trailblazer Pro 350D
    Miller Suitcase MIG
    Miller Spectrum 2050
    Lincoln 210MP
    Jun 2017
    AJO, ARIZONA
    Re: Manny
    Welcome! My buddy is fencing his property with oil field pipe, he has a lincoln AC225 and a 7000 watt genny that he has on a little trailer to do his welding, it does great for him.
    IMPEACH BIDEN!
    NRA LIFE MEMBER
    UNITWELD 175 AMP 3 IN1 DC
    MIDSTATES 300 AMP AC MACHINE
    GOD HELP AMERICA!
    "Those who would give up essential Liberty, to purchase a little temporary Safety, deserve neither Liberty nor Safety.Ē BENJAMIN FRANKLIN
    Jan 2010
    virginia
    Re: Manny
    Welcome
    Sent from my SM-G973U1 using Tapatalk
    Aug 2012
    AR
    Re: Manny
    Whatever you get, just be aware that some oil field tubular goods can be magnetized, giving you troublesome arc blow. AC works best for that, but with DC there are some workarounds.
  6. Likes scsmith42 liked this post
  7. #6
    Sep 2011
    Jasper TX
    Re: Manny
    Quote Originally Posted by Figman500 View Post
    Hi, I’m Texas and I own a 5 acre pecan farm that I’m planning to fence in using 2 1/2” oil field pipe. I have a regular stick welder that I normally use, but I need a small gasoline welder for this project. I’ve looked around the internet and checked various reviews, but but to no avail. I’m looking at a Lincoln Bulldog at Home Depot and a Tomahawk from Lowes. My brother in law had a Bulldog that he did a similar project and was very pleased. I really would like some inputs from you all.
    Where in Texas are you? I live near Kirbyville in southeast TX and has some questions about my pecan trees. Welcome!
    Owner of Fast Leroy's Bar and Grill
    Liquor up Front, Poker in the Rear
  8. #7
    Sebeka and Bemidji MN
    Re: Manny
    That's for sure. I got some cheap ones about 6" diam from the oil field. They would hold up a hammer with the magnetic field.
    DC did not work at all. AC was no problem
    I got them cheap because he said they couldn't be welded.
    For the OP. I bought a Miller Bobcat 225nt for my mobile stuff. $1500 used with under 500 hours.
    A good choice for random work in my opinion.
    Syncro 350
Page generated in 1,638,679,985.78389 seconds with 12 queries
