Page 1 of 6 123 ... LastLast
Results 1 to 25 of 138
Thread: Pipe Stands
    Pipe Stands
    Name:  pipe stands4.jpg
Size:  221.4 KB This is probably the beginning of stagflation, mark my words. I don't see how anybody can keep a business going when something like this crappy 10' piece of 2 1/2 x 3/16 tubing costs $130 F'n Dollars.
    I have quite a bit of steel on the rack, bought when prices were real. If it were not for that stuff, I wouldn't be making anything. When your steel starts to cost more than your welding equipment, it's time to hang it up.
    Job numbers were poor last week, lagging expectations. The coneheads chalk it up to Covid. I think they're wrong. Inflation is trickling down to affect all business enterprises. This is unsustainable.
    Anyways........I guess the work starts tomorrow.
    6 stands, at retail price, would run around $480. With the steel prices today, I'm going to be lucky to come in at slightly above 2/3 that cost.
    130 steel
    45ish threaded rod
    40ish Acme nuts
    and this doesn't take into account the 2" 11ga tubing off the rack, if I were to pay for it at today's prices.
    THIS IS BULL$#!^
    Re: Pipe Stands
    130 steel
    45ish threaded rod
    40ish Acme nuts
    THIS IS BULL$#!^
    Yes it sucks. I was quoted 240$ for a 4x 10 sheet of 16 gauge 2 weeks ago. Not long ago it was about 60$. Once again elections have their consequences.
    Re: Pipe Stands
    Price check last week : 4’x8’x3/4” steel plate $1777cdn plus tax = about $1900.
    Mar 2008
    Georgetown, Texas
    Re: Pipe Stands
    Hey Sam, you have any 1" and 1 1/4" pipe laying around? It will make better pipe stands than the square tube. These are 27 years old and still work perfectly. Pretty easy to build too.
  6. Likes _Weldman_, whtbaron liked this post
  7. #5
    Re: Pipe Stands
    The more I think about it, I made a stupid decision to go this route. I just couldn't get it out of my mind that I needed to make something that would mount to my sawhorses.
  8. #6
    Re: Pipe Stands
    130 steel
    45ish threaded rod
    40ish Acme nuts
    THIS IS BULL$#!^
    Pretty much why I have a dozen or so Sumner folding pipe stands. My time is more valuable than that.
  9. Likes _Weldman_ liked this post
  10. #7
    May 2021
    45.97267, -106.27818
    Re: Pipe Stands
    I went the same route and I’m retired on a fixed income. Best investment in awhile.
  11. Likes 12V71 liked this post
  12. #8
    Jun 2008
    Re: Pipe Stands
    Holy hell, that is unbelievable.
    Place I used to work buy a dozen or so tandem truck chassis most every year. Fella that got my job said the chassis went down slightly....then they added a $CAN1600 steel surcharge on top of it..............Mike
  13. Likes whtbaron liked this post
  14. #9
    Re: Pipe Stands
    If you think steel is bad, trying buying fertilizer. Right now I've locked in enough phosphate and sulphur for next year at a 14% increase which isn't too bad, but nobody will let me lock in nitrogen. Europe is shut down due to high natural gas costs (China has been shifting from coal due to international pressure to reduce emissions) and a big plant in the US gulf region got shut down after the last hurricane so nobody knows where stocks are coming from. They tell if I could lock it in today, the price would be double last yr's $500 plus/tonne.
    Cut 50 Plasma
    Re: Pipe Stands
    Name:  pipe stands5.jpg
Size:  222.9 KB Most of the steel is cut, and marked for drilling.............well, about half I guess.
    I was able to come up with a design that uses very little steel, or at least LESS steel. So, at this point..............the 2 1/2 tubing cost is right around $52 for 48". I'm not sure what the angle cost, it's been on the rack for years. There's only 39" of it anyways.
    Was gonna get it all machined, but we have heavy storms coming in. I don't like being in the shop when it's bad.
  16. #11
    Aug 2012
    AR
    Re: Pipe Stands
    OK seems to get the worst of bad storms...hunker down. Do you have a fraidie hole? (aka storm shelter)
  17. #12
    Re: Pipe Stands
    LOL. “fraidie hole”. Sure glad you clarified what you meant
  18. Likes whtbaron liked this post
  19. #13
    Mar 2008
    Georgetown, Texas
    Re: Pipe Stands
    The best thing about thes stands is the rod for fine adjustment is a 3/4" all thread rod. You can make different heads on all thread couplers and easily change from a flat head to a V head or a roller head while using the same stands.
  20. #14
    Re: Pipe Stands
    I don’t work with pipe enough for pipe stands so In the past I would make do with a forklift
  21. Likes _Weldman_, 12V71 liked this post
  22. #15
    Re: Pipe Stands
    That works great
    I have did that too.
    Just a little till back and the pipe does not roll off the forks. If someone need the forklift just point to the hand cart.
  23. Likes Lis2323 liked this post
  24. #16
    Re: Pipe Stands
    So they are pipe stand because the hold pipe? I have 4 sumners. They alright if you need something that heavy. Annoying to move and carry.
    Perhaps you could have modded some cheap material stands also.
    Interested to see what you come up with.
  25. #17
    May 2021
    Re: Pipe Stands
    They do make interchangeable heads for Sumner jacks, they aren’t one trick ponies.
    https://www.sumner.com/sumner/sub/pr....9.29.0.0.html
  26. Likes 12V71 liked this post
  27. #18
    Re: Pipe Stands
    Quote Originally Posted by _Weldman_ View Post
    Be cool to make a fork pocket to accommodate those interchangeable heads. Might need a set of double forks tho
    or two forklifts.
  28. Likes _Weldman_ liked this post
  29. #19
    Pipe Stands
    And you think fertilizer is bad. My daughters not here and I wasn't about to cook a turkey for myself. I got major sticker shock buying the smallest prime rib roast "on sale"....
    Yes, I'll make three meals out of it but still!
    More than double the price from earlier this year ??!!
  30. Likes whtbaron, _Weldman_ liked this post
  31. #20
    Re: Pipe Stands
    That much for turkey and you could have eaten for a month...
    Cut 50 Plasma
  32. Likes Lis2323 liked this post
  33. #21
    May 2021
    Re: Pipe Stands
    Think that cost me about 50 cents to get
  34. Likes Lis2323, N2 Welding liked this post
  35. #22
    Re: Pipe Stands
    Maybe closer to a BUCK?
  36. #23
    May 2021
    Re: Pipe Stands
    Nope, half a BUCK as I said since it wasn’t fully grown.
  37. Likes Lis2323, 12V71 liked this post
  38. #24
    Re: Pipe Stands
    GONNA GET MAD COW DISEASE EATIN' RAW MEAT!!!!!!!!!!!!!!
  39. #25
    Re: Pipe Stands
    Waving a piece of meat over the fire for 3 seconds doesn't qualify as cooking
  40. Likes Lis2323, jw3 liked this post
    Dislikes Roert42 disliked this post
Page generated in 1,638,881,072.50331 seconds with 13 queries
