Results 1 to 15 of 15
Thread: Wheel welding question
    Mar 2008
    Georgetown, Texas
    I would never do wheels unless the tire was off the wheel but haven't run into this before. Man working on my 2 mile long driveway broke a wheel off a Cat skid loader. Half the studs broke and half pulled through the wheel. He has a weldor/mechanic coming out that is supposed to put new studs in and is going to weld in the pulled through holes. I told him it was extremely dangerous but he said the tires are foam filled. What do you guys think? Dangerous or OK?
    Re: Wheel welding question
    Just have him stand beside you and ask question.
    I would never weld with tire on.
    One mistake and you a hear loud bang if lucky and the hospital will good pain pills.
    Then start counting on fingers and toes see make it to 20.
    Welding in the center of the wheel with foam filled tires shouldn't be a problem. Still I would monitor the heat input. With the foam in there pressure build up shouldn't be an issue
    This came up several years ago. Several videos. As I recall it was not heat build up from the source. It was the heat causing a chemical reaction in the rubber and producing more heat and pressure. The reaction could continue for several hours after the heat source was removed. Thus explosion could be well delayed after repair
    That's the way I remember it?
  5. Likes shortfuse, whtbaron liked this post
  6. #5
    Brethren, Mi
    I remember that too. I agree working cautiously on the center might be ok.
  7. Likes shortfuse liked this post
  8. #6
    Aug 2012
    AR
    That makes three of us who remember those videos....I wouldn't be standing anywhere near that operation when he welds, foam or not.
  9. Likes whtbaron liked this post
  10. #7
    If does welding I hopping for video of the chemical reaction.
    PS I hope he does try this one and he watch a video on internet .
    I listened to old welders and never try this one.
    I can still count to 20 on my hands and toes.
  11. #8
    Yeah... But what's in that foam? and more than likely only a 16" wheel, not much room to dissipate much heat.
  12. #9
    Southern California
    It's a reaction that happens due to the rubber being heated.
    Bridgestone video about heating rims:
    Strongly advise against it and stand back.
  13. Likes whtbaron, Meltedmetal liked this post
  14. #10
    Like video
  15. #11
    He's filling in some oblong wheel stud holes, how much heat can you put in it before it blows out? I would think about the same as if you cut off a lug nut. If I was doing that repair I would use a carbon rod centered in the hole and weld around it. A wet rag placed on the rim side would suck up any heat radiating towards the rim.
  16. #12
    Southern California
    Very true M J D, but I have learned to always assume the worst from people.
    Give people a chance, they'll surprise you in miraculous and ingenious ways lol
  17. #13
    I hear that. If you keep your expectations low enough you won't be disappointed.
  18. Likes whtbaron liked this post
  19. #14
    Mar 2008
    Georgetown, Texas
    Supposed to fix it next week, I don't plan on being close by. I'll let you know if ambulance is called.
  20. Likes whtbaron liked this post
  21. #15
    If there are security cameras handy, can you make sure one is pointed in the right general direction for us?
    Cut 50 Plasma
  22. Likes Weldalittle liked this post
Page generated in 1,638,058,005.12008 seconds with 12 queries
