Connecting gas to a Miller Cricket??
3.3K views 8 replies 2 participants last post by  straightaxle65
I acquired a Miller Cricket XL and it already has the gas hardware kit installed on it. I need a nipple fitting that goes into the solenoid valve to connect the gas supply hose. The Miller manual describes the solenoid valve as "1/4 IPS port 1/8 orf".
Can someone here decipher that for me? I looked up IPS and it describes it as Iron Pipe Standard. Does the 1/8 orf mean orifice size?
Thanks for your help.
#4 · (Edited)
https://www.airgas.com/product/Gas-...oduct/Gas-Equipment/Gas-Equipment-Accessories/Adapters-&-Fittings/p/RAD64003964
That is a standard 5/8-18 inert gas fitting to barbed hose. Nothing there to fit 1/4" IPS that you said you were trying to fit. Made it sound as though the 5/8-18 fitting was not in the solenoid valve.
Knew you didn't find and 5/8-18 to 1/4" !PS as I looked for 2 hours for you. Oh boy. You only needed a standard 5/8"-18 fitting/hose. Lol.
5/8-18 is a standard inlet size for Miller machines and Lincoln too. Those are dime a dozen and standard for inert gas. You don't have to look for those. They are everywhere by the dozens.
https://www.amazon.com/inert-gas-hose/s?k=inert+gas+hose
https://store.cyberweld.com/powerweld-inert-gas-hose-pw-ah-10.html
Just get the proper hose already made up if it really is 5/8-18 inert gas thread you have and are trying to fit.
Premade hoses are cheap. Unless your regulator is not 5/8"-18 and yor using a barbed fitting connection there to.
Even if Regulator only has nipple. You can take that out and usually get 1/4" NPT to 5/8" -18 B size fitting and then use premade hoses. So much cleaner installation with the premade hoses.
