Page 5 of 6 FirstFirst ... 3456 LastLast
Results 101 to 125 of 129
Thread: Small Shop Guys What is a tool you use frequently that is out of the norm
  1. #101
    Mar 2021
    Near Roanoke, VA
    Re: Small Shop Guys What is a tool you use frequently that is out of the norm
    I agree. Over the years I’ve assembled a collection of wedges that are used frequently for welding projects, machinery repair and general construction setups.
    I have quite a selection of wedges too, but I have to confess, I have a couple of thinned down pet screwdrivers too.
    OK, I gotta admit, I have never even considered a wedge, so, there are a few questions,,
    FIRST,, do you hit them, much, or just little taps?? In other words, do they have to be hardened??
    I ask, because, I have a 4 or 5 foot piece of 1" X 8" steel hot rolled A36, and a bandsaw big enough to cut them.
    I will not waste my time, if they gotta be hardened,,
    SECOND,, if they are measured at the wide end, what width do I cut them, (like, 3/4", or 1.50",, ) ?
    Do I need to cut them as matched sets? or are they used individually?
    AND, finally, how many should I cut, to start?? This question is sorta like,, do I need four of the 3/4",, or six, or whatever??
    I looked on eBay, the beat up old Armstrong wedges were over $20 each, so, it is cut, or nothing,,
    OH, YEA,,, Will I have any use for aluminum? I have some 1" thick aluminum (and 2"), so I could make some real soft ones,
    if there were any need for soft wedges,,
    I have to make these in advance, I would never stop a project, set up the saw, and make as needed,, that would kill my project,,
    Thanks,,,,,,,,,,,,,,,,,,
  2. #102
    To me wedges are an intuitive thing, you look at the application and grab one that "looks right", tap or whale as necessary. I've cut a bunch of my own by just looking at the angle on the saw or lay out for the torch if it's a big one. I do like the "Armstrong" style for cracking stuff apart. A fast wedge with lots of pressure can be very dangerous if it gets spit out in your face. I prefer slow angles and stepping up to thicker slow wedges if I need them.
    I get my armstrong style from a buddy that pulls deep well turbine pumps. His company buys them by the bushel to level top bases to the top of the casing plate.
  3. #103
    May 2010
    Ct.
    I have several of those Armstrong wedges at work in 6” & 2 “.
    They appear to be forged. 6” is maybe 3/4” at thick end.
    They get hit pretty hard and haven’t mushroomed at the striking
    end.I use 6” for disassembling crusted up machinery. Small one is
    used to split inner bearing races after carefully cutting part way
    through with abrasive wheel. ( when neither puller or heat can be
    used.)
    Miller a/c-d/c Thunderbolt XL
    Millermatic 180
    Purox O/A
    Smith Littletorch O/A
    Hobart Champion Elite
  5. #104
    Laredo + Midland/Odessa
    This extended reach is only a 3" so it probably won't get used a lot, but it should get me into places nothing else will go..
    I bought one from harbor freight thinking it would be great to grind out tack welds or bad welds (I do a lot of those ), but it is severely under-powered, even for harbor freight quality, lol.
  6. #105
    Yea, it's no powerhouse... there's a reason the good ones are over $300 and this one was $70. Like I said, it's not something I'll use a lot, but for those nasty little places where nothing else will go, it's an option. That screened face shield will also have limited uses. Right now I'm doing a lot of wire wheeling on some rusty paint, and it's good for that. I noticed on the grinder that I can still feel particles getting through it though ( not too surprising being a screen ) so it will require safety glasses under it while using the grinder.
    I just looked on line. $99cdn regular price so you did okay.
    Too bad it doesn't have a lower profile head
    I use mine A LOT (embarrassed to say)
  8. Likes whtbaron liked this post
  9. #107
    Power tools from Harbor Freight
    I only buy Dewalt with cord as they keep going and going and still going.
    PS very few things I buy from HF
    If I can not fix or upgrade I do not buy HF
  10. #108
    Dec 2014
    Northern California
    Do you like that Aircat you posted last week or some other suggestion …I am getting myself some Christmas presents and one of those extended reach grinders is on my list…thanks.
  11. #109
    Quote Originally Posted by Tarmstrong View Post
    I really like that Aircat. The extended reach in conjunction with a relatively low profile head make it invaluable.
    I purchased it several years ago on advice from from a member here on WW
    Put it on your list and Merry Christmas!
  12. #110
    Nov 2019
    North East Ohio
    Is this the Air cat you are referring to? https://www.tooldiscounter.com/produ...caAiY_EALw_wcB
  13. #111
    6375 A. Affirmative !
  14. #112
    Dec 2014
    Northern California
    You found any flap discs that will work with that…cut off I found, couldn’t find flap discs anyplace…thanks.
  15. #113
    Not certain but I never looked. I find the cut off wheels work well for light grinding as well as spatter removal in tight spots.
    Post here if you find some
  16. #114
    Yea... I might still get an Aircat if I find I'm using this one for things that annoy me. It says max. 4" disc.... won't take 4.5" with the guard on?
    $250 Cdn. all in... that's better than the $312 I got quoted last time..... https://www.amazon.com/AIRCAT-6275-C.../dp/B00U24VGBQ
    Pretty sure not. I will look tomorrow.
  18. Likes whtbaron liked this post
  19. #116
    And the answer is no
  20. Likes whtbaron liked this post
  21. #117
    I would think if you found a 3/8" 24 external to 1/4" 20 thread insert you could adapt a 3" roloc holder and use 3" roloc flap discs or surface conditioning pads on there
  22. #118
    That's a really good idea. I have Trim Kut and Rolocs that I currently use in the right angle die grinders.
  23. #119
    Same here. Major issue I've found is it's not really a low profile setup. Usually have to use one of the small hand held belt sanders like the Milwaukee band file for those situations
  24. #120
    Come to think of it, I think you can get " trim cuts" with 3)8" 24 thread.
  25. #121
    Same. I just bought a cordless Makita
    which I like using because it’s so handy, but lacks the real power of my pneumatic Dynabrade with 1/2” belt.
  26. #122
    I have the larger 3/4" belt in pneumatic. Biggest issue I have is the belts don't last that long. Not really a big deal since it's a tool not often used.
  27. #123
    I have the same problem with my Klingspoor 1/2"x24" belts.
    My own fault for buying a big *** box of them off eBay. The adhesive bond let's go on them.
  28. #124
    Haven't had that problem. It's just that it's a relatively small belt and they just wear out quickly. I haven't tried ceramic ( if they are available) , just zirconia.
  29. #125
    I agree
    I have 1/2" and rarely use it but I had for 40 years.
    I found electric 120 volt last longest and I do not to run a air compressor. Battery power is great till the battery dies now I have a costly draw filler.
Page generated in 1,713,263,486.67797 seconds with 19 queries
