Page 1 of 3 123 LastLast
Results 1 to 25 of 71
Thread: Small Shop Guys What is a tool you use frequently that is out of the norm
    Nov 2019
    North East Ohio
    Just curious what guys have that weld part time, side Hussle or beer money use that is out of the norm??? I imagine we all have grinders, band saws, radio and refrigerator.
    I weld in my 2 car garage and space is very limited.
    My magnetic drill has been very helpful as is my 20 ton press with the Swag Off Road press brake.
    Southern California
    Re: Small Shop Guys What is a tool you use frequently that is out of the norm
    These are some non conventional things I use:
    Box fan with home air conditioner filters makes an excellent garage air cleaner.
    A scissor jack, ratchet straps, bottle jack, and come along (these are probably pretty common).
    Furniture style lifting lever (google), along with dolly/sliders to move really heavy stuff.
    I love my tri-stand (usually for plumbers, found cheaply on craigslist type apps) as a very heavy duty base/stand that folds up nicely into the size of a set of golf clubs. I like the chain vise versions with either the lever or the screw tightening mechanism, use a piece of leather to protect metal from chain if so needed.
  3. Likes Roert42, greenbuggy, _Weldman_ liked this post
    Some people might consider my railroad anvils out of the norm, but they are pretty standard in this crowd. I also have a large nut welded on a scissor jack so I can move things around in tight places with the impact (probably not recommended).
    Cut 50 Plasma
  5. Likes 12V71, _Weldman_ liked this post
  6. #4
    Scissor jacks are great for leveling stuff like irrigation filters and piping. Got a half dozen from late 90's Chevy pickups with nuts welded to the shaft. A ratchet and a 15/16" socket makes for easy fine tuning.
  7. Likes whtbaron, farmall, _Weldman_ liked this post
  8. #5
    The hydraulic lift cart as a welding table. Raymond Head first turned me onto the idea with this photo of one of his power hammers under construction. Being able to raise or lower the work to get at a weld is great, but the cart is still a cart and can be used to offload the truck or move things around the shop. The older I get, the more I appreciate someone else doing the heavy lifting!
    Just saw that one of the big companies is now making a small welding table that is similar, but doesn't have much in the way of elevation capacity.
    For more general stuff, I'd have to say that my belt grinders are probably the two most used and underrated tools. When I got my 2x72 grinder, I was gobsmacked at just how handy it was and still marvel at how I ever survived without it.
    I need to get a mag drill, but lately I've been really curious about those metal-cutting circular saws for their portability.
  9. Likes whtbaron, 12345678910, _Weldman_ liked this post
  10. #6
    A good host is big help.
  11. Likes Roert42, farmall liked this post
  12. #7
    Fredericksburg, VA
    I also have a tri stand and with the chain, you can hold odd shapes .
    Using pipe vises since you can make them any length you want.
    Here is an idea I came up with a while ago to use my vise in a way similar to a carpenters tail stock vise.
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Miller Spectrum 625 Plasma
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
  13. Likes VaughnT, whtbaron, farmall liked this post
  14. #8
    Sep 2008
    Dalton, GA
    A HF port-a-band in a Swag table to make a vertical bandsaw is the tool I’m most surprised at how often I use it.
    Burt
    _____________________
    Miller Syncrowave 250
    Millermatic 211
    Miller 375 Plasma Cutter
    Hobart Handler 120
    10FtDrillBit.com
  15. Likes VaughnT liked this post
  16. #9
    Soda springs,Id
    I too use the HF hyd lift table for lots of things, so many I can't name them all. For instance with a milk crate on it it supports 20' lengths of steel while cutting off pieces, to put lawn mowers and snowblowers on to get them up to a convenient working height, small engine welders, etc. It's just my little helper for heavy lifting which my 74 yr old back doesn't like anymore. I also have a swinging boom with a long reach jack for setting boom angle and a boat winch for setting heavy objects on the lift table. Since the lift table jack tends to leak under load I rigged up a chain setup on the scissor mechanism to hold the load for extended periods.
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
  17. Likes VaughnT, Roert42 liked this post
  18. #10
    High lift pallet jack...
  19. Likes VaughnT, scsmith42, _Weldman_, bfjou812 liked this post
  20. #11
    Assistant or first aid attendant ....
  21. #12
    Mar 2021
    Near Roanoke, VA
    OK,, after that ,, I got NOTHIN' !! ` . ~ ~
  22. Likes Lis2323, whtbaron, JimboTN, scsmith42 liked this post
  23. #13
    lol.... she'd make a good host for Smithdoor too. Odd how the over 50 crowd is heavy on jacks and hoists to lift things for us...my chiropractor would be impressed.
    Cut 50 Plasma
  24. Likes 12V71, JimboTN liked this post
  25. #14
    I dated a chiropractor a long while ago.
    Pretty certain she couldn't give a crap...
  26. Likes whtbaron liked this post
  27. #15
    Sep 2011
    Magnetic drill. I use mine, more than my drill press. Any steel over 1/4" thick that needs a hole bigger than 7/16" (my smallest annular cutter) i use the mag drill. Plasma table is probably out of the norm too
  28. #16
    Nov 2019
    North East Ohio
    All great Ideas. If you have pictures that may help as well.
  29. #17
    Oh we've got all kinds of pictures... glad to be of assistance...
    Cut 50 Plasma
  30. Likes 12V71, Reebz, LtBadd, VaughnT liked this post
  31. #18
    Mount Tabor VT
    Name:  580 Super N.jpg
    Sort of a rare project doesn't involve this.
  32. Likes whtbaron, Lis2323, scsmith42 liked this post
  33. #19
    That's a nice looking TLB
  34. #20
    This probably sounds stupid, but the tool I use most, that you'd not even think would get much use....................A 6" 4R ruler. Get you oneName:  tkqe4fh-smiley-two-thumbs-up175028_285604.gif
  35. Likes whtbaron liked this post
  36. #21
    Mount Tabor VT
    What's 4R?
  37. #22
    Brethren, Mi
    Use the washer a lot.
  38. #23
    What's 4R?
    4r is the type of calibration. 1/64", 1/32", 1)16" and 1/8" increments. Usually a 6" scale type or a 12" combination square or ruler in 4r.
  39. #24
    When she was little my daughter used to
    complain I had too many rules...
  40. #25
    The older I get, the less I bother with the blurred-out portions on the rulers. If it can't be made with the big hashmarks above an eighth of an inch.... it doesn't need to be made at all.
  41. Likes Reebz liked this post
Page generated in 1,638,739,183.37743 seconds with 13 queries
