Results 1 to 21 of 21
Thread: How clean is clean enough?
    Mount Tabor VT
    I've welded 52+ years. I've come to a point where every weld gets a pre arc grind. Most of my welds are stronger than the application needs, so I grind until shiny.
    Today's project is a new trailer hitch on a 28000 LB GVW truck. The trailer is 23000 LB GTWR.
    I will attach the hitch to two crossmembers built a year ago by the man who fitted the dump body. He used new steel, primed & painted.
    I'm under the truck over a 66" deep grease pit, I'm standing on the third rung of a stepladder grinding it clean where I will Dual Shield weld it. After grinding all the paint, all the mill scale, I still see black veins in the steel.
    Should I grind until there is nothing left? Or, will Dual Shield overcome some impurities. Factory steel is NOT flat. One has to grind pretty deep to get past all the texture.
    When do I stop grinding?
    Re: How clean is clean enough?
    I usually clean rust and paint with a really nasty stiff bristled cup brush in a 5" angle grinder and then hit it with a hard disc. Small imperfections will burn out just fine.
  3. Likes MinnesotaDave, Louie1961 liked this post
    Mount Tabor VT
    Dual Shield is a product I've had success with sometimes. Out of position, a mountain of weld to place, I want to use dual shield. Someone suggested cutting down my contact tip to allow more stick out, better gas coverage. I tried it. In test runs I got only a small bit of worm track first arc, the hose might not have been completely purged.
    First real weld has to be good, I'm going to chance it. I feel there should be a limit to grinding when 3/8" steel gets down to 1/4, it might be too far.
    Mar 2012
    Australia
    Same as 12v71, the reason welding filler material isn't just hot rolled round bar is partly the deoxidizers for dealing with some impurities.
  6. #5
    When it has to be absolutely positively shielded on the the first trigger pull, I run 3-4" of wire and clip it off where I like my stickout. Purges all the lines and the gun.
  7. #6
    Dual shield is a lot more tolerant about rust or scale than hardwire. If it's mostly shiny without loose rust your good.
  8. Likes 12V71 liked this post
  9. #7
    Mount Tabor VT
    I clicked the trigger 10 or more times, no wire feed. I thought I was purged, but first weld had a single worm track. I was at 40 CFH 75/25. I turned up to 45, no tracks. I'm now set at 50 CFH, a trailer hitch is important!
  10. #8
    Mar 2012
    Australia
    Something to keep in mind is that those surface worm tracks you get with dual shield don't affect the welds mechanical properties at all, when doing the oil and has stuff with dual shield it made no difference to the Charpy v notch test numbers at any temp, the rockwell hardness, X ray/gamma ray (as long as the worm tracks were ground off the top) or tested yield or ultimate tensile strength, or elongation.
    What brand of dual shield wire are you using?
  11. #9
    Sep 2012
    Wheatland, Wyoming
    I've noticed that grinding steel with primer and paint often leaves little lines of primer/paint residue. Never have had them develop any weld defects. Never been a fan of grinding where base metal thickness is reduced.
    Chris
    Auction Addict
  12. Dislikes 12V71 disliked this post
  13. #10
    Mount Tabor VT
    Quote Originally Posted by milomilo View Post
    I go over it several times. I work with hard disc from closest to farthest, get the paint off. I go back one more time to get residue. Then I use a 40 grit flap disc. Finally, I go at it with a non woven (Scotchbrite) style. Most paint residue is gone. It's the texture in the steel, (might have rust deep in the voids), but everything on the surface is clean.
  14. #11
    Sebeka and Bemidji MN
    Damn Willie, that's a lot of cleaning for dual-shield
    For stick or self-shielded wire, I just hit it with a hard wheel and then get to welding.
    For solid wire mig or for tig I do a lot more.
    I can't imagine the dual-shield wouldnt work about the same as self-shield and stick?
    Syncro 350
  15. #12
    Mount Tabor VT
    I can't imagine the dual-shield wouldn't work about the same as self-shield and stick?
    OK, you talked me into it, not that I have much over the top of my head grinding left in me anyway.
    If it's a success, I'll be bragging later. If a fail, I'll be very very quiet!
  16. #13
    Can you cook it out?
  17. #14
    Mount Tabor VT
    Not much cooking happens with Dual Shield. Laying down filler is fast.
  18. #15
    I meant with torch, preweld
  19. #16
    I understand that very well
    There are no pics of my failures
    Syncro 350
  20. Likes whtbaron, 12V71 liked this post
  21. #17
    Mount Tabor VT
    Oh, perhaps.
  22. #18
    Aug 2006
    St. Paul Park MN
    I just gotta ask.. what brand of Dual Shield wire are you snarling up constantly ?
  23. #19
    Mount Tabor VT
    Quote Originally Posted by lars66 View Post
    I can't say. It's a pressboard reel, label is gone. I went into Maine Oxy. They had Lincoln & another well known brand I can't remember. He said a local welder, (member here) used a lot of it, refuses the other brand. I believe I have Lincoln.
  24. #20
    Oops... Had to undislike this post. Dislike was an accident. My fingerpad has a mind of it's own sometimes.
  25. Likes MinnesotaDave liked this post
  26. #21
    Nov 2014
    PDX PNW
    I find the stick out on dual shield doesn't make much difference like hard wire. So dont worry to much about that. I like it close. Really close on hardwire, the closer the better
Page generated in 1,638,546,656.21178 seconds with 12 queries
