Results 1 to 7 of 7
Thread: Tig hose broke
    Tig hose broke
    My mini chinese tig gas hose cracked.its the hose to the torch. The fitting is a compression type so i assume the pressure is high. Can this be repaired?
    Re: Tig hose broke
    Typical shielding gas pressures are around 50psi, so not that high pressure. Braid-reinforced vinyl hose (thick wall) of the same size will suffice.
    Pensacola , Fla
    Re: Tig hose broke
    YOu also may want to check the regulator to be sure the pressure is not creeping up higher then is should be.
    Hypertherm 65
    Everlast PowerTig 255 EXT
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
    Sep 2005
    Cave Creek AZ
    Re: Tig hose broke
    Just trim off the end and reinstall with the compression sleeve.
    Re: Tig hose broke
    The hose is falling apart, needs to be replaced. Saw some on amazon. Are compression fittings universal? I was told this tig machine is italian, not chinese and decent.Name:  20211018_170508.jpg
Size:  63.4 KBName:  20211018_175614.jpg
    Re: Tig hose broke
    Connection at head
    Re: Tig hose broke
    Fixed, $13Name:  20211024_143000.jpg
  8. Likes tapwelder, LtBadd liked this post
Page generated in 1,638,547,343.76712 seconds with 15 queries
