Results 1 to 7 of 7
Thread: weight of handrail
    Pittsburgh,Pa
    weight of handrail
    Just a quick question for all of you rail makers. I made a rail out of all solid stock. I weighed it and comes in around 55Lbs. My question is do you think if I core drill 2" holes 4" deep will it be sturdy enough. End posts are 1 " square. The steps are only about 3 years old.
    Sydney Australia
    Re: weight of handrail
    If its concrete no dramas .
    Also the 4" is in concrete not including tiles etc
    A good guess is better than a bad measurement
  3. Likes BOP101 liked this post
    Sep 2008
    Dalton, GA
    As Brett said, if in good concrete or good brick (not crumbling or coming apart) you will be fine depending on anchor material. I use Quik-Rock.
    Burt
    _____________________
    Miller Syncrowave 250
    Millermatic 211
    Miller 375 Plasma Cutter
    Hobart Handler 120
    10FtDrillBit.com
  5. Likes BOP101 liked this post
  6. #4
    Mar 2021
    Near Roanoke, VA
    Quote Originally Posted by BOP101 View Post
    If you have any concern, weld a piece of 1/4" X 3 X 3 steel bar sitting flat against the concrete, centered around the 1" square.
    That piece of 1/4" will require the hand rail to pull out of the concrete before any movement occurs, rather than simply moving sideways.
    I made a handrail for my wife out of 1.5" solid round 12 feet long, with 2 vertical supports (also 1.5" round)
    (including the vertical supports, it weighs over 100 pounds)
    The hand rail supports are simply in the dirt 12". but have a plate near the top of where the support is in the dirt.
    You can not move the hand rail,, it is solid, because of the plate.
  7. Likes BOP101 liked this post
  8. #5
    Pittsburgh,Pa
    Thank you for the replies. Yes, it will be in 4" of concrete, no tile. SweetMK, I think you have an excellent suggestion.
  9. #6
    Sep 2008
    Dalton, GA
    Also, it would be better if you can tie one end to a wall or if you put a small return section at 90*.
    A single straight section will have some wiggle if just anchored in the holes.
    Burt
    Millermatic 211
    Hobart Handler 120
    10FtDrillBit.com
  10. #7
    Sydney Australia
    SweetMK brings up a good point I didn't mention.
    Deforming the leg so that it does not come up vertically.
    A much greater concern in things like polished SS tube than solid square stock , but still a step.
    Does not have to be any thing too radical , but options depending on type of leg include.
    A simple welded stip/ strips.
    Hitting tube with a hammer at bottom.
    Drilling a hole
    Drilling a hole and putting in a bolt
    Localised bending of leg
Page generated in 1,638,741,368.71593 seconds with 12 queries
