Results 1 to 7 of 7
Thread: Mig power and feed settings
    Aug 2020
    Utah
    I have a Hobart 130. It has a chart which provide setting for different thickness and for the type of wire. I have an ArCO2 bottle. I have noticed that when I use the recommended settings, the feed rate is too and and the wire start to pile up in the puddle. So I adjust it down and then things work out.
    Here is one I don't quite know how to adjust for. Lets say I have 1/4 inches thick piece of steel angel and I want to weld an 1/8 inch piece of flat stock to it. Is there a rule of thumb on how to adjust voltage and wire feed when I have a difference in the thickness of stock? Is it just a matter of trial and error on some scrap to figure it out?
    Sebeka and Bemidji MN
    Re: Mig power and feed settings
    The door charts just get you close, you are right to adjust as needed.
    For thick to thin, set for the thicker piece, then hold more arc/bead on the thicker piece.
    Syncro 350
    Aug 2020
    Utah
    Well, that is kind of what I have been doing so I guess I have been on the right track.
    Thanks for the information.
  4. Likes MinnesotaDave liked this post
    It would nice if chart had range everyone welds different and power coming to will very .
    With self I even found the morning to different are after noon different.
    Quote Originally Posted by smokey9701 View Post
  6. #5
    Brethren, Mi
    That is a wide open machine for that type of joint.
  7. #6
    Aug 2016
    utube TimWelds perfect mig welder
    settings in 3 asy steps
    using an everlast cyclone mig....has power set feature
    shows bunch of metal thickness on screen...usually weld 1/8...gives 19 260
    a few minor problems with this everlast....
    I like the mig torch, swivel thingy bottom handle, very comfortable to use...
  8. #7
    Aug 2020
    Utah
    Quote Originally Posted by xmmancharl View Post
    shows bunch of metal thickness on SCREEN...usually weld 1/8...gives 19 260
    No digital display on a Hobart 120Volt model 130. Amp settings are 1 2 3 4 5 and that's it. Wire feed is variable. It works for light jobs. At the time I got it, I only had access to 120 single phase. I now have a shop with 220V so it may be time to move up. But, it does work for the jobs I need to do and I have yet to have it cut out due to duty cycle overload.
  9. Likes xmmancharl liked this post
Page generated in 1,638,494,201.42174 seconds with 12 queries
