Results 1 to 10 of 10
Thread: What is this switch(?) called?
    Nov 2016
    Was replacing the nuts on this "switch" and one of the studs broke off. Can someone tell me what it's called so I can get a replacement.
    It's off a Esab Migmaster 150.
    Thanks
Size:  33.8 KBName:  20211020_093432[1].jpg
Size:  34.3 KBName:  20211020_093445[1].jpg
    May 2015
    Re: What is this switch(?) called?
    Quote Originally Posted by Gump_Runner View Post
    Thanks
    I could be mistaken but that doesn't look like a switch that looks like a terminal block.
    Nov 2016
    A "terminal block". Thank you for your help.
    Soda springs,Id
    And back off on the torque a little.
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
    Feb 2019
    Snyder TX
    Is that the terminals where you switch polarity?
    Big Lake/Monticello MN
    Quote Originally Posted by cwby View Post
    It is on every welder I've seen it on - you're probably right.
    Syncro 350
    Feb 2012
    It looks like a SHUNT to me. I really don't know for sure and without seeing the rest of the circuit or schematic, Im guessing. It is deffinitly shuntting a connection. A SHUNT is another word for short but a SHUNT is used for metering current.
    Sechelt, BC
Size:  56.2 KBNope, not a shunt.
    Feb 2012
    It's not a shunt. It's a terminal Esab item 408. It looked like shunt.
    https://www.esabna.com/literature/ar...rts_110331.pdf
  10. Likes whtbaron liked this post
  11. #10
    Nov 2016
    I replaced it with this:
    "STUD POLE 175A POWER FEED-THRU FEEDTHRU TERMINAL BLOCK"
    https://www.ebay.com/itm/381970729520
Page generated in 1,713,290,502.85076 seconds with 20 queries
