Results 1 to 16 of 16
Thread: Cross Over Tube for Pizza Oven
    Mar 2014
    Troy MI
    My friend John’s brother Dave owns a bar in Northern Michigan, which is an economically depressed area. He has an industrial pizza oven that was purchased in 1984. Over time the cross over tube has rusted out and the welds holding one of the two brackets have rusted off. The oven manufacturer is still in business, but doesn’t sell the cross over tube as a replacement part. A new double oven similar to this one would cost $26K. Pizza ovens are very hot. The pilot light ignites flames in a cross over tube, which lights four burners.
    1. Burner assembly
    Name:  1. Burner assembly.jpg
    Before John retired, he owned a Fluid System Engineering company, so he asked one of his former technicians Harry bend up a replacement tube.
    2. Old and new tube assemblies
    Name:  2. Old and new tube assemblies.jpg
    3. Rusted tube
    Name:  3. Rusted tube.JPEG
    The first step was to make the brackets. I like to scribe shape of the bracket as well as the hole and slot locations. I find that this gives me a second check on locations and dimensions.
    4. Scribing bracket
    Name:  4. Scribing bracket.jpg
    5. Cutting out bracket
    Name:  5. Cutting out bracket.jpg
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Clausing/Coldchester 15" Lathe
    16" DuAll Saw
    15" Drill Press
    7" x 9" Swivel Head Horizontal Band Saw
    20 Ton Arbor Press
    Bridgeport
    Lincoln LE 31 MP & Lincoln 210 MP
  2. Likes SweetMK liked this post
  3. #2
    Mar 2014
    Troy MI
    Re: Cross Over Tube for Pizza Oven
    6. Sanding edges of bracket
    Name:  6. Sanding edges of bracket.jpg
    7. Center drilling bracket
    Name:  7. Center drilling bracket.jpg
    For non-critical slots I like to drill a hole in each end of the slot and then plunge the cutter into one hole, make a pass then increase the depth of cut on the other end before returning to the starting hole.
    8. Drilling bracket
    Name:  8. Drilling bracket.jpg
    9. Milling slot
    Name:  9. Milling slot.jpg
    I typically use the power of the mill using the back gear to reduce speed, to tap the holes, because I don’t own a tapping head. For thru holes I use spiral point taps, which push the chips ahead of the tap and through the back side of the hole. For blind holes I use spiral fluted taps which pull the chips out of the hole.
    10. Tapping holes
    Name:  10. Tapping holes.jpg
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Mar 2014
    Troy MI
    11. Brackets done
    Name:  11. Brackets done.jpg
    I really like to use hog mills to square up stock, because they cut fast and leave a decent finish.
    12. Squaring up crimp tool
    Name:  12. Squaring up crimp tool.jpg
    13. Drilling crimp tool
    Name:  13. Drilling crimp tool.jpg
    I chose to bore the hole in the tool for the tube and for the crimp area in the same setup to assure that they would be concentric. I had a 3/8” reamer which I used for the tube bore in the tool. I didn’t have a .340” reamer, so I bored the hole for the crimp portion of the tool.
    14. Boring crimp tool
    Name:  14. Boring crimp tool.jpg
    15. Reaming crimp tool
    Name:  15. Reaming crimp tool.jpg
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Mar 2014
    Troy MI
    16. Crimp tool 1st op reamed
    Name:  16. Crimp tool 1st op reamed.jpg
    17. Installing dowel
    Name:  17. Installing dowel.jpg
    18. Using center finder
    Name:  18. Using center finder.jpg
    19. Reaming crimping tool
    Name:  19. Reaming crimping tool.jpg
    20. Crimp tool done
    Name:  20. Crimp tool done.jpg
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  6. Likes Weldalittle liked this post
  7. #5
    Mar 2014
    Troy MI
    The swivel fitting on the end of the cross over tube is actually just a standard barb fitting. The tube was crimped loosely to hold the barb fitting in place, but still allowing it to rotate for installation. The barbed fitting has an .040” orifice in the end, which acts as a jet which accelerates the air as it leaves the fitting. This creates a low-pressure area, which in turn creates a vacuum. The cross hole through the tube near the end of the barbed fitting allows air to suck into the tube. This means that gas doesn’t leak out of the small space around the barbs, but instead sucks in air past the barbs.
    21. Crimped barb fitting
    Name:  21. Crimped barb fitting.JPG
    22. Crimp Mark on old tube
    Name:  22. Crimp Mark.jpg
    I drilled a larger hole most of the way thru the orifice and just drilled the .040” hole through the last 1/16”.
    23. Orifice pieces
    Name:  23. Orifice pieces.jpg
    I used my arbor press to install the orifice.
    24. Orifice press fit
    Name:  24. Orifice press fit.jpg
    25. Orifice installed
    Name:  25. Orifice installed.jpg
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  8. Likes Weldalittle liked this post
  9. #6
    Mar 2014
    Troy MI
    26. Arbor Press with crimping die in place
    Name:  26. Arbor Press.jpg
    27. Crimping swivel fitting
    Name:  27. Crimping swivel fitting.jpg
    28. Fitting crimped
    Name:  28. Fitting crimped.jpg
    I had to rotate the waist of the Bridgeport to allow the tube to pass the left end of the table.
    29. Setup for drilling holes
    Name:  29. Setup for drilling holes.jpg
    I installed tight fitting blocks in the Tee slot and then bumped the 1-2-3 blocks against them. (a red arrow points to one of the blocks.)
    30. End view of setup
    Name:  30. End view of setup.jpg
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  10. #7
    Mar 2014
    Troy MI
    I used a parallel against the back side of the 1-2-3 block to set the position of the tube.
    31. Parallel to set tube position
    Name:  31. Parallel to set tube position.jpg
    First I center drilled a drill point and then I drilled the 112 holes with a #76 (.020”) drill.
    32. Drilling hole
    Name:  32. Drilling hole.jpg
    33. Close up of hole
    Name:  33. Close up of hole.jpg
    34. Crimping end of tube
    Name:  34. Crimping end of tube.jpg
    35. Tube crimped
    Name:  35. Tube crimped.jpg
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  11. Likes VaughnT liked this post
  12. #8
    Mar 2014
    Troy MI
    I used my Fireball Tool magnets to hold everything in place for welding.
    36. Setup for welding
    Name:  36. Setup for welding.jpg
    Here is a picture of me welding the brackets.
    37. Welding brackets to tube
    Name:  37. Welding brackets to tube.jpg
    38. Brackets welded
    Name:  38. Brackets welded.jpg
    39. All done
    Name:  39. All done.jpg
    40. John holding the completed cross over tube
    Name:  40. John holding completed cross over tube.jpg
    John plans on going to the Upper peninsula in two weeks to visit his brother and to install the new cross over tube.
    -Don
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  13. #9
    Apr 2020
    Excellent job!
    Great write up and pictures showing the process.
    Hard to believe the oven manufacturer does not sell that part.
    Free pizza for life?
  14. #10
    Sep 2011
    Jasper TX
    Man that is some nice clean work!
    Your friends brother will be very happy.
    Owner of Fast Leroy's Bar and Grill
    Liquor up Front, Poker in the Rear
  15. #11
    Jul 2018
    Cumbria, UK
    There's some hours gone into that! Nice work.
    Out of interest, how do you know that the crimp around the hose barb is gas tight? I think I would have soldered it personally, although the crimping was more satisfying to see.
  16. #12
    Mar 2014
    Troy MI
    Quote Originally Posted by Larry4406 View Post
    Excellent job!
    Thanks, I'm sure that John's brother would treat me to a pizza next time I make it up there.
    Quote Originally Posted by Fast Leroy View Post
    I like to help out hard working people, who are just trying to support themselves and their family.
    Thanks, it was a stump the chump job. I thought that some of the techniques that we came up with might help someone else.
    The swivel fitting is necessary for assembly and disassembly of the cross over tube. John and I wondered about the leakage between the barb fitting and the tube. It turns out that the orifice creates high velocity of the gas, which creates a vacuum, so air is sucked in through the cross hole and from the tiny space between the barbs and the ID of the tube. In other words gas doesn't leak out but air leaks in. (We did test it with compressed air and the orifice does indeed create a vacuum.)
    By the way I enjoyed the study that you did back in 2018 comparing short-arc, pulse and spray. I have been playing with spray and dual shield recently. I did take a welding class on spray pulse, but I currently don't own a spray pulse welder.
    -Don
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  17. Likes Munkul, whtbaron, Fast Leroy, Larry4406 liked this post
  18. #13
    Jul 2018
    Cumbria, UK
    Quote Originally Posted by Don52 View Post
    -Don
    Nice, that makes perfect sense.
    No worries, glad it was helpful Oscar has done some studies on pulse spray as well which is quite interesting as he got slightly different results to me. Since then I've bought a different machine and the penetration and usability of pulse spray is much better, so I use it a lot. It still doesn't replace dip transfer for thin metal or vertical/overhead though.
  19. #14
    Sep 2005
    Cave Creek AZ
    Nice work!
  20. #15
    Feb 2008
    Great thread, but the best picture is John because he appears to be thinking “holy crap how did Don52 replicate this thing so perfectly”.
  21. #16
    Mar 2014
    Troy MI
    Quote Originally Posted by El Greco View Post
    We will find out if it works as soon as John gets up there. I believe that it will work.
    -Don
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
Page generated in 1,638,516,177.66387 seconds with 13 queries
