Results 1 to 25 of 29
Thread: Power source welder on a mobile trailer????? Too much vibration???
    Oct 2021
    Howdy folks,
    Are power source welders durable enough to last on the road? For example, lets say a miller synchrowave rubber mounted on a short wheelbase generator trailer. Good idea or will it screw it up after pulling down the road? I'm thinking with the right rubber suspension it would not cause too much of a jolt and screw it up.
    Or how about humidity? Are these machines resistant to such conditions?
    Would like to hear peoples opinion or experience.
    Brethren, Mi
    Re: Power source welder on a mobile trailer????? Too much vibration???
    What is it you are trying to do?
    Los Angeles
    yeah.. why are you wanting to trailer a Synch around?
    MM211 (Sold)
    Klutch 120v Plasma cutter
    Nov 2010
    Mid-East
    Professional-grade machines are made to operate all over the world, including in the tropics - so outside humidity isn't going to bother them. Rain will, though. I've carried an XMT-304 on and off in my service truck, beat it around on a rough-riding solid-wheel cart for a couple years in a factory environment, and no harm done. A good rubber bushing suspension, as you suggested, would go a long ways towards peace of mind. If I had a need to trailer-mount a typically shop-housed welder, I'd pay most attention to potential issues from vibration and precipitation.
    An engine-drive is obviously made for all-weather environments and is likely a better choice. Most people would shudder to see the jobsite my highest-hour TB325 is living on right now. And yet it still starts up and performs on demand.
    Put it in the original box. Packaged, it handles UPS and FEDEX.
    Interesting idea. Are you going to pull it behind a vehicle? Is it going to be used with the generator power?
    I would be concerned about road spray, also.
    Sep 2016
    Detroit, Michigan
    Quote Originally Posted by brad.bds.llc View Post
    Howdy folks,
    Generally speaking, vibration isn't a good thing for electrical devices that aren't built with that in mind, so I wouldn't want to haul something like a Syncrowave around on a regular basis. I wouldn't consider a Syncrowave resistant to humidity either....the fan vents give an open path to everything inside of the machine. I would expect they'll still work after a long time being exposed to humidity, but sooner or later you're going to have some heavily rusted stuff on the inside.
    http://mivise.com
    Hobart Champion Elite
    Everlast PowerTig 210EXT
    May 2015
    Erie, PA
    I've hauled Lincoln 350MP welders all over on flat beds and never had an issue. Everything is pretty solid and well connected in most welders (try taking one apart). I think you would be fine and "mobile" tig can be worth some money. Risk vs reward I say go for it!
    Sep 2005
    Cave Creek AZ
    Are you going to power it with an engine drive?
    Brethren, Mi
    Trying to make a portable out of a synch aint to far from a brain fart, machine that weighs a lot and takes big electric service. Even if all this was free the effort alone would be worth more than the cost of modern equipment.
    Please post a photos
    How old are rubber mounts?
    Howdy folks,
    Doesnít seem like a feasible idea. Were you planning on housing the Sync in an enclosed trailer? How were you planning on keeping it dry ?
    Oct 2021
    Welding/ construction trailer with a military 30kw generator powerplant. 4 cyl john deere (already purchased). 3 phase capability. Ac dc powersource. Mig stick tig ect.. w/ lead reels and suitcase w/ possible gas hookup through air comp. hose. and a tig dolley cart. all process , great weld output. ( not that a miller bobcat isnt great weld quality, just not as good for generator and not diesel ) The highest quality weld output. Able to use all processes on the job with a diesel power plant. Less cost than a lincoln pipeliner machine or other welder/generator. A far better Generator capability and 3phase.
    Manufacture things off grid without running electric or 3 phase installation. Outsource Manufacturing and eventually manufacture C-perlins and Zee out of galv. rolls w/ .1 inch thickness or 2.5mm.
    Oct 2021
    Good to know, thx. The main reason for doing it this way is the cost effective diesel generator alone w/ no built in welder.
    Oct 2021
    Housed on a trailer w/ insulated and sealed + locked box.
  15. Likes Lis2323 liked this post
  16. #15
    Oct 2021
    Either a synch or other 3 phase machine. Trailer is dual 14k lb axles hauled by a f550 Or a international 4900 w/ digger derrick crane. Job trailer. Massive amounts of tool storage w/ water tank and sprayer and military 30kw generator w/ 3 phase. May be a more modern 3 phase power source but still the same concept.
  17. #16
    Oct 2021
    Yes, 30kw diesel gen. 3 phase
  18. #17
    Oct 2021
    Good to know, figured I better make sure someone has done it without issues before ruining a high dollar power source! Thx
  19. #18
    Oct 2021
    Yes, on a trailer with Gen.
  20. #19
    Oct 2021
    Yes good to know. Might need a more modern power source rather than a synch with the outdoor rating. Would be stored in a sealed insulated box. You remind me though, I would have to figure a good way to supply air flow when in use if it was totally sealed.
    Or, with a outdoor rated machine the sealing wouldn't be necessary. The plan is to make the box easy to remove from trailer. Thx
  21. #20
    Oct 2021
    Welding power source for a diesel Gen. without built in wleder
  22. #21
    Oct 2021
    Howdy folks,
    Update: So it sounds like the synchrowave would not be very feesable mainly due to the moisture. Plus the size and weight wouldn't be ideal. The Ac+Dc feature is nice however.
    -BUT, it sounds like an XMT would work great. That would just require to have an A/C machine on board as well or just bring when needed.
    An xmt/ pipeworx machine or/ a lincoln flextec. I think they'd hold up to moderately outdoor conditions like moisture and mild vibrations... I want to have it totally suspended by rubber.
    Like super heavy duty rubber bunjee cord material suspending like a spider web inside the box so I can hit any size pothole and never worry about it
    ***Thx for the input folks! Has anyone else had experience subjecting these machines to moisture or vibratory conditions and did it effect them?
  23. #22
    Brethren, Mi
    Cant be great hauling them around but they are pretty tuff at least for a while but depending on model they are heavy and greedy. I understand tossing all this on a truck I had kind of thing but a lot of investment in it being rather obsolete right from the start makes it a hard sell. The price of modern stuff has went so wayyyyy down that it might be cheaper to start over.
    I have a good compressor, could have made it with less in hindsight but,,,, 3 or 4 K for the comp,,, another 600 for an impact can now buy without a cord for less than 600 and weighs 20# instead of another 4 or 500 for the comp. Even if a guy needed air could do it for 1/2 the cost size and weight today for smaller tools or air up.
    I used to use a torch every day, now some in the shop and I carry one for absolute emergency but rides a lot of miles for nothing. Battery saw, grinder, drills, 120/240 welder, put my fave little engine drive back on a trailer or can fork it in if I really need one.
    I went thru phases as work style changed and today need 1/2 the tools I did.
  24. #23
    Brethren, Mi
    If I was hanging out the sign for any and everything and decided I had to carry it would be a total different matter I spose but found that for most field work get along with a welder torch and grinder, dont carry wire, no plasma, no tig. , if its humanly possible do it with a stick.
    The big thing when I leaned on heavy truck was could carry some pieces of steel, big nut/bolt collection and some pipe fittings. Enough hose and lead to reach around comfortable like.
  25. #24
    Brethren, Mi
    Another thing to consider is the moving. If you are on a job for time then some of this might not matter, could run other setups with the genset etc but the initial question was so vauge its like asking,,, what kind of truck do I need?
    In both cases, if you can afford it or not afford it looking to the practical is where its at in the end. Do you really need tig on a drilling truck?
  26. #25
    To answer your original question, I think there is a good reason why you never see mobile welding services trailering around a Syncrowave. Itís just not practical.
Page generated in 1,656,521,080.60496 seconds with 12 queries
