Page 8 of 10 FirstFirst ... 678910 LastLast
Results 176 to 200 of 231
Thread: FAIL! Collets 101
  1. #176
    Re: FAIL! Collets 1
    . Come to think of it, some day I should open it up and see how things are doing....
    No No No.
    When will you ever learn...!
  2. Likes 12V71, whtbaron liked this post
  3. #177
    Re: FAIL! Collets 101
    Apparently in your world there is no rust. You've never seen the affects of liquid road brine and ferrous metal. Would have figured that was trying to cut a cap rather than a cross the way that was mutilated.
    I can one-up that... Inter axle shaft in a 30 year old fertilizer truck. That's when I finally bought a portable U-joint press for trucks.
  4. #178
    Unless you mess it up
    This was the response to post #169
  5. #179
    Tiger Tools?
  6. #180
    Fertilizer is pretty nasty as well. Changed out quite a few front axle U joints where the snap rings were pretty much non-existent. Never used the on truck U joint press before. To me anchor pins are a bigger struggle as far as heavy truck- trailer stuff goes.
  7. #181
    Fertilizer spreader has a drive shaft on bearings for the spreader that runs right below the apron that "leaks" granular. When the bearings go, you pretty much torch the whole thing off and start building new.
    Cut 50 Plasma
  8. Likes 12V71 liked this post
  9. #182
    Re: FAIL! Collets 1
    No No No.
    I've run it until the wheels fell off once... on a nasty sidehill. That wasn't fun either...
    Cut 50 Plasma
    Tiger Tools?
    Mine is an older OTC press that bolts on to the cap bolt holes. I have been looking at the new Tigertools model. I have their slack adjuster puller set and it's awesome.
  11. #184
    Anchor pins... that is one I will pierce with a #2 torch tip and beat out with my long stroke CP air hammer.
  12. #185
    I have the snap on anchor pin press that works really well on about 1/2 the ones I come across. Otherwise I torch the protruding ends off and blow thru them. I recently bought a .498 air hammer which definitely does the job faster than my long barrel snap on. The lisle driver set does a good job on the " open" style spiders on Meritor drive axles.
  13. Likes 12V71 liked this post
  14. #186
Size:  208.4 KB After the alignment pin is pressed, and welded, into the collar.................it's slotted to receive the driveshaft tube.
Size:  193.7 KB Dummy shaft tube used to check fit
Size:  200.6 KB Another gage is made for the output end of the the shaft.
Size:  229.0 KB Second collar slotted on both sides, and checked for fit.
Size:  192.3 KB Components stack. Input collar with alignment pin, dummy shaft, second collar, rear output sleeve
  15. Likes whtbaron liked this post
  16. #187
Size:  236.7 KB Collar bored to clear inner output shaft.
  17. #188
    Hand a Blind Dood
    a
    Stinger
    This stupid drive shaft is round. I figured I'd better try to bone up on round stuff, before I trash the new shaft.
    The hardest thing is training your hand to roll. It's not something I do..........I don't weld round stuff like the pipe guys do.
Size:  240.4 KB When I time the roll, it's presentable
Size:  219.3 KB When I don't time it right, or do it clumsy, it gets ugly.
Size:  212.3 KB Add arc blow to the mix, and it's Wild West
Size:  192.8 KB Keep piling the welds up the side of the pipe........
  18. #189
Size:  190.3 KB Towards the end of the session, I was getting a bit more consistent.
    Anyways............it's a work in process
    Atom Arc 7018, 125amps, early afternoon, wind from the South at 6mph, all welds freehand w/o bracing any body parts. That ought to cover the pra-mee-ters
    Go through a few more rods tomorrow, and I might ready to glue the driveshaft togetherName:  tkqe4fh-smiley-two-thumbs-up175028_285604.gif
Size:  1.1 KB Tain't gonna be purdy, but it ought to be serviceable.
  19. #190
    Aug 2018
    Looks good to me. Can't complain about something you don't do often.
  20. #191
    That's not pipe welding, it's a simple fillet around a round object.
  21. Likes IAMsteelworker, bfjou812 liked this post
  22. #192
    Probably not in the alternative universe.
  23. Likes 12V71 liked this post
  24. #193
    6G anybody? With a TIG root.
  25. #194
    Now your pushing it. Are you really ready for another 9 page tutorial 🤣
  26. Likes whtbaron, 12V71 liked this post
  27. #195
    Now your pushing it. Are you really ready for another 9 page tutorial ��
    It's really funny how "tutorials" involve things the rest of us have done for years?
  28. #196
    6G................................Are you crazy???????????????????
Size:  195.8 KB I'm doin' good just to get a simple stringer to stay together without spilling the puddle One pass on a builtup, and I called it a day.......................why tempt fateName:  t519276_scared-smiley-emoticon.gif
    Hell, I can't remember the last time I did any out of position welding, except for those pipe stands (which probably ain't gonna get used).
    I'm just trying to get back up to speed on stuff I don't do anymore, and stuff I was never good at, didn't mean to offend anybody. Thought folks might enjoy it.
  29. #197
    Padding is as good a way as any to get back to some semblance of normal I guess.
  30. #198
    Aug 2018
    So you not building a gantry setup anymore? You said you probably aren't going to be using the pipe stands......
  31. #199
    Get those eyes fixed and it will be a whole new world... ask me how I know.
  32. #200
    Quote Originally Posted by IAMsteelworker View Post
    Yeah, it's still on the schedule this Winter. Actually the pipe stands will come in handy I guess. Can run some heavy wall oilfield pipe on them, and use them to support the crane components for leveling when I'm doing fitup. I used to do everything by eye, now I can use a level...........be 10x quicker. I've been looking at a nice Empire 24" magnetic level.
    I have a beautiful older David White transit I guess I could use..............but even for me, that's sorta overkill
Page generated in 1,642,455,454.29803 seconds with 13 queries
