Page 4 of 11 FirstFirst ... 23456 ... LastLast
Results 76 to 100 of 261
Thread: Would I be wrong to use 6013 over 7018 on this?
  1. #76
    Brethren, Mi
    Re: Would I be wrong to use 6013 over 7018 on this?
    The guy is practicing, sounds pretty conciencious, Most of the worlds work or a good share of it is not highly engineered, some of the biggest failures are. I am not current with those guys but back in the day some of my good buds were Detroit firefighters, I know some from a couple other major cities and they are a bunch of smart and capable guys and know enough about climbing not to get on it if it wobbles and unlikely this will be used 50 or 100 at a time.
    People ride motorcycles, face hundreds of 1000's of tons of steel on the hiway that is driven by,,, lets say not all well trained careful operators,,, repaired by anyone with a pulse, by contractors and this is scary?
    There needs to be a class in high school for estimation, risk that type of thing. My brother cant tell the difference between a little or a lot either. Seems blurred, little, lot, all, none, these mean different things to different people.
    This isnt even a little scary and if it wouldnt pass xray on a nuke doesnt mean it wont work well on this simple ladder.
  2. #77
    The way most use low hydrogen rod would not past code or e-ray.
    It is a real pain to do welding that pass X-rays.
    Low hydrogen welding rod can be brittle if not done to welding codes.
    This why shops in 1950's and 1960's used E6013 and E7024. E6010 and E6011 was only used for first pass only on some types work.
    I do not recall shops the using 6012.
    I did see a few times E7016 but when ask the reply was "no one uses today".
  3. #78
    In some old books it list E5011 and E5013 for use on mid steel.
  4. #79
    Brethren, Mi
    12 was the sheet metal rod alternative to 11. 16 ,,, seems I have seen it somewhere but its so long ago its off the charts.
  5. #80
    Back 1960's I was learning welding and would see all charts too.
    But when I was in shops they did not use most rods. I wonder how used the other rods and the reply was "it is used at ship yards".
  6. #81
    CT
    People either didn't notice or are forgetting this tower is only the height of two connex boxes and it is only holding the weight of a couple of guys at a time. Its not a multi story training tower with stairs and windows. Its a makeshift training tool. It doesn't need to be engineered and it doesn't need to be welded with low hydrogen rods. I mean that would be like engineering a tree fort for my kids. Sometimes too much engineering is overkill.
    Miller Multimatic 255
  7. Likes Josey, And256 liked this post
  8. #82
    I would see specifically in 1960's and 1970's with (E60XX). In 1980's I would see (E70XX and no solid wire). It was rarely to some different.
    On my drawings I would spec out E7018, E11018-D2 and or E71T-1 with per heating.
  9. #83
    Brethren, Mi
    You and I think a lot alike. Its not that we are always right but we are moderates. I have great appreciation for engineers.
  10. #84
    Brethren, Mi
    I have seen this before, used telephone poles or 4x4's
  11. #85
    What's the big deal with using 7018? It's used every day by professional weldors. If it's any more $$ , it's a small difference. There's a reason you don't see 6013, 7014 or 7016 on a job site, it doesn't meet structural codes that are commonly used. If one can't run 7018 to acceptable standards, that person has no business welding on that job site. And once again this nonsense that 7018 MUST be kept in an oven for every use. Tons of it are burnt every day without seeing an oven. Most of it that does see an oven isnt used in full accordance with the certain code either. Anyways, 100 percent code compliance most likely isn't required here, but if one is to do it, why not at least attempt to do it correctly?
  12. #86
    CT
    There's no big deal other than the OP said he felt more comfortable using 6013, and I don't think there is any reason to not use 6013. The structure as it stands was welded with either 6010 or 6011 and has been fine for a long time up to now.
  13. #87
    So because it was a hack job then it's OK to do a hack job now?
  14. #88
    Iíve seen the OPís work and itís highly unlikely he will be doing a ďhack jobĒ on this job or elsewhere.
  15. #89
    Mount Tabor VT
    I can't believe they'd use 60xx on a building site. It's not seismic rated as far as I know, and it just isn't what I've seen used. Any good structural guy should be well versed in 7018, or seismic rated wire. I couldn't imagine any WP calling for 60xx on structural iron. I might be wrong......dunno.
    As I said it was freestanding before welding. They cut out concrete floor anywhere a post would be, placed a 2' thick concrete pad. Posts supported horizontal beams, then perpendicular to those were steel truss joists. All this was inside a 20 year old steel warehouse. It was converted to a doctor's office facility.
    I can't say what standard it was built to, or what engineer signed off on it. I was surprised a faster process wasn't used. The welder explained that 6010 penetrates through rust better than other rods.
  16. #90
    May 2012
    Ontario, Canada
    I like 7018
    I get great results with it.
    I don't like 6013
    That's how I base my decisions.
    Just need 7018, use it, keep it fresh, stay practised and current on it.
    Burning through rust is a moot point, I have a grinder and I know how to use it.
  17. #91
    The 6013, 7014 or 7016 are in codes.
    It just welders for hire like using one rod like E7018. They also use E7018 per specifications for low hydrogen rod.
    Most today use flux core wire like E71T-11.
  18. #92
    I never said or implied that BB,the OP was going to do a hack job. What I meant was if the OP was to follow some " expert advice" posted on here, it would become a hack job.
  19. #93
    If those other electrodes we're acceptable by code standard one would think they would be used for pre-approved code work. I'm sure there are scenarios where an in-house code may use them but certainly not for pre-approved code work . Why would one go thru the same work using an inferior material when there is no cost or labor savings?
  20. #94
    My self going to a job sites I would use E7018. But that does not mean I could not use the other rods. The codes do not specify or only would say must comfor to AWS. Sometimes on specifications I would see " E70XX or greater ".
    Pipeline work is different set of rules.
    FYI When going in to field I would have some E6011 and E6013 if need. But everyone would ask are using 7018 they had on idea what 7018 was or even how to use rod. Just
  21. #95
    Mount Tabor VT
    I'd have said there is no reason to make other rod types if 7018 does it all. In my ignorance I've said 7018 was important to use, don't want to risk underbead hydrogen induced cracking. Others here more knowledgeable than I corrected it only matters in high carbon steel.
    6013 is a smooth weld to lay down flat. It would not be my choice for a vertical weld, takes too long to freeze.
    Messer 80TAC+ is the smoothest running all position rod ever.
    Unprepared steel, I want 6010 or 6011. I have blasted through rust & paint for welds on nasty steel. Its fast freeze properties mean it runs well vertical & overhead.
  22. #96
    All the low hydrogen stuff aside, 7018 offers much more ductility which means less chance of cracking.
  23. #97
    Brethren, Mi
    I think this is great. Guys likely doing this on down time but we could always get the government so hated to get involved,,, or better yet lets get a grant, a couple grant writers, some proposals, some review meetings, bet it could get done for say,,,,, what,,, 75k or so? To do something a ladder and decent tree branch could do?
  24. #98
    Brethren, Mi
    As Louie pointed out if this was a kids tree house everyone would be jumping on the fact it is overkill. A few bolts would hold it together and this guy is gonna weld it top bottom and up the sides. How we figure this all to "crack" and fall down more than most other stuff in the world, this is heavy duty and then some. Gonna work itself in to failure simply sitting there I seen lots of stuff 1/2 as good as this bouncing down hiways on logging equipment and this load aint squat.
    Any welder worth a pinch of **** can weld this up with any one of these rods without looking up a code.
  25. Likes 12V71 liked this post
  26. #99
    Mount Tabor VT
    Bring in some Feds. It'll cost $137,500. & it'll likely collapse with three firemen on it.
    I guess my point is this structure needs to support 1000 LBS. 6 square inches of weld cross section support the weight. If this weld is sound, it'll hold. Could weld it with coat hangers, it'd hold.
    The man hopes to use product familiar to him so his odds of a presentable weld are improved. I'd bet his weldment steel is A36. A 60,000 PSI tensile rod is almost overkill. If fusion is 1/4 of filler strength, there is no hazard.
  27. Likes 12V71, Munkul liked this post
  28. #100
    Laredo, Tx
    While I haven't ran all the all-position rods, but I do agree with how great it runs. I usually order a pound or two of 3/32" and 1/8" each time I place an order with HTP, which is pretty dang often, LOL.
Page generated in 1,642,727,954.61436 seconds with 12 queries
