Page 1 of 3 123 LastLast
Results 1 to 25 of 52
Thread: auto-draining water separator for compressed air
    Laredo, Tx
    I'm looking for options for a self-draining water-separator to install before a refrigerated air-dryer. Current CFM capability is ~55 CFM, but it might be higher in the future. I want something that will auto-drain, while in-use, meaning without having to depressurize. So I was told I want the water to be collected and then the float-actuated drain will expel it all completely on it's own. Seen options in Amazon already, so I've done basic research already, but not everything is on Amazon. I've seen stuff from Tsunami and some other brands, but I want to make sure I know what I want. I believe I want two components, one of which is the water separator, and the other is a float drain, but it looks like there are units that are both.
    https://www.compressorworld.com/50-c...1999-0131.html
    I tried calling them with no luck. Who has actual experience with such a beast?
    Re: auto-draining water separator for compressed air
    No experience with commercial units, just the one I built myself. My theory was to not store any water in the tank, and it "should" reduce vapor in the air. So far it seems to be working. I have a drier 30 ft downstream from the compressor (5 HP 2 stage Ingersol/Rand) and I have yet to put any pellets in it. I also have filter/regulators at each drop with automatic drains, but I have yet to see them collect any water. The unit is just an old hydraulic cylinder with the piston rod removed and replaced with a sealed scrap bolt. The petcock was removed from the bottom of the air tank so it constantly gravity flows into the cylinder, which is held at an angle so the water drains to the outlet end. I turn the compressor on and off every day I'm using it (which is probably 4 days of the week) and hit the drain valve each time, so twice a day (up at a very handy level). The valve drains the water from the cylinder into a vented plastic jug due to air pressure. I close the tank when I turn it off, so it stays up to pressure while the lines are allowed to drain and activate the auto drains at the drops. I've probably posted this here before, so my apologies if it's old hat.
    Cut 50 Plasma
    Always been curious. Why do you need to reduce pressure in the tank before you drain it???
    I just let 'er rip, and shut the valve when it runs clean. Am I missing something?
    Auto drains are generally spring loaded (at least the ones on my regulator/filters are) so they only drain when pressure drops below 5 psi. When I drain my POS cylinder drain, I, as you say, just "let her rip..."
    Cut 50 Plasma
  5. Likes farmersammm liked this post
  6. #5
    I like the hyd hose BTW. No need to plumb with expensive, hard to work with, hard line. Mine's the same way for areas where there's a connection, or weird bend. 2500psi should be all you need for any compressor.
  7. #6
    Laredo, Tx
    Yup I remember seeing it, but some of my air tools will not let my 10HP compressor stop. At All. Hence there is no way to count on air cooling down in the tank. However it does cool down on the 100ft trip to my garage, which is where I need to focus the water-trapping at.
  8. Likes whtbaron liked this post
  9. #7
    The rubber stall mat is a little over the top though (I'm just kidding.......I have the same). Does the vibration/noise interfere with your enjoyment of Vivaldi's Four Seasons?
  10. #8
    I've dealt with 2 refrigerated air dryers at work and some big industrial units in the past. All of them had a built in auto drain. I can't see any reason to add another. On my compressor at home I have an ingersal rand electric auto drain. That one has a timer for how often it purges and length of time for purge.
  11. Likes whtbaron, bfjou812 liked this post
  12. #9
    I had some lines in really good shape that I had removed from equipment I wrecked for parts, so they got incorporated into the build when I plumbed the shop with black pipe. I also have fittings and a manual press so I can make my own. 1/2" for the outlets to the black pipe, and "I think" 5/16 to the cylinder drain. Not affected by oil when the compressor gets older, and yea, I've never blown one at 175 psi. It was another reason I chose the old cylinder for water storage. The only caveat is that you don't want it in a location that could freeze.
    Cut 50 Plasma
    Jeez man, what are ya runnin' with that thing?? I gots a Champion 80gal 5hp unit, and it never runs dry...........even painting, or running die grinders, drills, etc............ Hell, even the plasma cutter doesn't kill the capacity/pressure.
  14. #11
    I've run the 5 HP steady for quite a while with no issues. Basically my cylinder and drier (without pellets) serve the same function if you had one at the compressor, and one at the shop.
    Cut 50 Plasma
    The best part is the doghouse it's in... that used to be the front door into my hog barn before the building conversion. I really don't get a lot of noise or vibration as long as that uninsulated door is half shut. Of course, I guess if you really wanted the thrill you could sit on top... my son's in-laws are into horses so I got the matting for free. Works great.
    Cut 50 Plasma
    If you're crimping hyd hose on your press, you need to put up some pics of the dies, and the dimensions. I'd love to have some dies. You get raped when they make lines.
    But, in hindsight (there's always a catch), I'm wondering if those dies are heat treated.
  17. #14
    Didn't you see those 50 HP air grinders he was playing with?
    Cut 50 Plasma
  18. Likes farmersammm, Oscar liked this post
  19. #15
    I can do dies for crimping cable, although I never get around to it. But hyd hose....................I'm gettin' a woody just thinkin' about it.
  20. #16
    Laredo, Tx
    3M 28824's and 28826's. I actually added two smaller 120V compressors in parallel, and all 3 just barely keep up with 1 of those bad mamma jamma's.
  21. Likes whtbaron liked this post
  22. #17
    It's somewhat "like" a press, but purpose built for hoses. The problem with dies is that everyone tries to alter their fittings so only their dies will work ... no such thing as a "generic" hydraulic die system anymore. When I first picked this unit up, I could pick up cheap fittings at Princess Auto and everything worked great. They updated their line and I might have to do some creative grinding to make the old dies work again. I haven't tried it yet, so yes, they may be very hard to change.
    Cut 50 Plasma
    So...........it's a press with the collet thing. Not a straight upsy downsy press. I get yaName:  tkqe4fh-smiley-two-thumbs-up175028_285604.gif
  24. #19
    I have an old timer kicking around and thought about wiring it in for an auto drain system (basically the timer/solenoid valve would just replace that release valve on the wall), but so far my twice a day draining seems to suffice.
    Cut 50 Plasma
    Quote Originally Posted by oscar View Post
    3m 28824's and 28826's. I actually added two smaller 120v compressors in parallel, and all 3 just barely keep up with 1 of those bad mamma jamma's.
    wow!!!!!!!!!!!!!!!!!!!!!!
  26. Likes Oscar liked this post
  27. #21
    Brethren, Mi
    I go kick the valve open once in w while when i read an auto drain thread. Got enough problems without adding some more fussy gadget to the system. Got them plumbed to a common tube thru the wall. You do not have to drain every 5 minutes.
  28. #22
    That depends on how much heat, how much air and how much humidity you are dealing with. I suspect Oscar is close enough to the gulf to have lots of all 3...
    Cut 50 Plasma
    My worst time is when we get into the 70* dewpoints during the peak of the Summer.
  30. #24
    Brethren, Mi
    I wonder how it was done before the gadget? Not that tech isnt good but a simple valve every once in a while is super reliable. Some water sitting in the sump doesnt hurt.
  31. #25
    And once the tank gets a rust hole you have your auto drain.
Page generated in 1,642,862,943.98500 seconds with 13 queries
