Results 1 to 14 of 14
Thread: Cutting question
    Cutting question
    I am switching from acetylene to propane. Besides a new proper propane tip what else do I need to replace to my old Victor torch system? Thanks in advance.
    Los Angeles
    Re: Cutting question
    MM211 (Sold)
    Klutch 120v Plasma cutter
    That is only thing you
    All the equipment is same but the tip.
    Quote Originally Posted by cattleguardguy View Post
    May 2007
    IBesides a new proper propane tip what else do I need to replace to m? Thanks in advance.
    i think theres a diference in hose. i cant remeber for sure, or how much it matters, but think there is a differnce hose for propane
  5. Likes welding1 liked this post
  6. #5
    If you look at dedicated propane setups they are different from acetylene kits. Doesn't mean you can't use what you have with the correct tips I recon.
    The regulator is a 50 psi for Propane and a 15 psi for acetylene.
    The hoses are T rated for the propane gas so they don't break down over time from the incompatible gas.
    And of course the tips as mentioned.
    Look at regulator part numbers. The middle number is max pressure. Acetylene 15 psi Propane 50 psi.
    Hose types and sizes. 3/16 acetylene 1/4" propane. Propane is T rated for propane gas.
    Propane,
    https://www.millerwelds.com/equipmen...it-mba-30510lp
    Acetylene,
    https://www.millerwelds.com/equipmen...-300-mba-30300
  7. Likes 123weld, scsmith42 liked this post
  8. #6
    Feb 2012
    I think it's a waste of money
    Edit
    Waste of oxy
  9. #7
    I took the acetylene equipment and put on propane tank and changed the tip.
  10. #8
    Aug 2013
    Hudsons Hope BC
    When I started cutting with propane I never even knew that there was a different tip and hose for it
    I'm still using the wrong hose
  11. #9
    The right heats up faster.
    Since I would switch back forth between gas it always works great.
    Quote Originally Posted by bcguide View Post
  12. #10
    May 2015
    Erie, PA
    you can save lots of money using propane. a 20lb propane tank (BBQ size) will cut as much as three 140 Cubic Ft acetylene cylinders (maybe more). also the rose buds/heating tips for propane are way more effective if you need lots of heat fast. T-grade (teflon) hose is recommended. Propane deteriorates your regular acetylene hoses prematurely, though not overnight.
  13. Likes welding1 liked this post
  14. #11
    Nov 2012
    North Port Florida
    I've been using propane for years. love it, 1 30 lbs can is good for 4 bottles of oxygen. Plus you can leave it horizontal. Not quite as hot but cuts rusty metal better.
    We've done so much, for so long, with so little. Were now qualified to do anything with nothing !
  15. #12
    When first started it was acetylene for cutting.
    Then 10 years using propane for cutting.
    Next was Mapp gas for 20 years.
    In retirement I use now acetylene for both welding and cutting. Only need one set of bottles.
    Quote Originally Posted by welding1 View Post
  16. #13
    Big Lake/Monticello MN
    On my Harris based torch, just a new tip. Kept using the same hose for years because I didn't know.
    I haven't used acetylene for cutting or heating since the 90's.
    Btw, look up setting the flame online. It's a little different. Also, raise the torch up a little extra, too close isn't effective.
    Syncro 350
  17. #14
    Apr 2011
    minnesota
    On the smith torches I just change the tip. I don’t worry about the hose because we seem to wreck them fast enough anyway. Going from a propane to acetylene you would want to be more careful as the regulator is higher pressure
    Millermatic 252
    millermatic 175
    miller 300 Thunderbolt
    lincoln ranger 250
    smith torches
    lots of bfh's
Page generated in 1,713,257,292.74724 seconds with 19 queries
