Results 1 to 11 of 11
Thread: Mounting acetylene valve upside down?
    Aug 2007
    I just finished mounting an oxy/acetylene hose reel, and the whip hose from the reel to the gauge set is just short enough that I have to flip the acetylene gauge slightly upside down. Now, I could make a longer whip hose, or even raise the acetylene tank about 8-12" off the ground, but any reason the partially upside down gauges will potentially case any problems? The gauges are probably -20* from being completely flat/level across the face.
    Re: Mounting acetylene valve upside down?
    Quote Originally Posted by Jason280 View Post
    I would not think the gauge being upside down or I guess we should say the regulator not being normally orientated would pose any issue.
    It's a regulator... No, it wont care about orientation.
    Apr 2021
    As others have said, no, that is not a problem.
    My regulators have been sideways since the cylinder outlet changed from vertical to horizontal.
    Jack
    Aug 2007
    Thanks, I didn't think it would be a problem.
    A pic. would help. The last thing you want is acetone coming out of the cylinder/regulator.
    May 2011
    It will only be a problem if the acetone in the tank gets inside the regulator. But of the tank stays upright all the time, it should not ever be a problem.
    Apr 2021
    Quote Originally Posted by Country Metals View Post
    That's true but there are two ways to rotate the regulator - with or without the cylinder. A picture can get rid of the ambiguity however unlikely it might be.
    Jack
    He didn't mention the tank not being upright. Laying the tank down would have same detrimental effect on regulator however it is attached if valve is opened and liquid acetone flows out.
    Apr 2021
    Nor did he mention it being upright. Hence the ambiguity - however unlikely it might be.
    I made the comment to emphasise the usefulness of including an image.
    Jack
    Quote Originally Posted by Jack Ryan View Post
    Jack
    Nobody knows for certain and your absolutely right a picture would answer our question and help us answer his for sure. Pics are always good and usually save a lot of typing.
    Sorry I guess I read further into his post and managed to put 2 and 2 together to be pretty sure he wasn't laying tank over to get the gauge face 20 degrees from horizontal.
    If he would need to rotate the regulator or raise the tank to make it reach means that the reel is probably above the tank/reg. Anything less than upright would make the regulator get further away making the hose even more short. So short of hanging it upside down I recon the tank is still upright.
Page generated in 1,642,501,398.81060 seconds with 11 queries
