Results 26 to 50 of 52
Thread: Non-traditional shielding gases
    May 2011
    Re: Non-traditional shielding gases
    You can use Oxygen when pulse steel mig welding. There are 2 mixes that people use and its 98/2 and that's either 98/2 CO2 or 98/2 Oxygen.
    The O2 actually works quite a bit better then the CO2.
    That's the only time I have ever seen o2 used.
    I have heard of people using nitrogen, hydrogen, helium, and obvious argon for purge gases, though I only have used argon and helium myself.
    I used about 99% the time I used CO2 with flux core
    Today I use self shielding flux core E71T-11 no gas to buy or loose.
    Quote Originally Posted by Country Metals View Post
    Laredo, Tx
    There's actually more common mixes for pulsed-spray: C10 or C8.
    The downfall of O₂ is that is uses up the deoxidizers in mild steel MIG wire, so the weld bead is left a dull-gray instead of the usual look like when C25 is used.
    Laredo, Tx
    Why and can you explain it? Is it like He mix?
    Hydrogen boost?
    Edit: it's for Stainless?
    Lincoln GMAW Guide.
  5. Likes Insaneride liked this post
  6. #30
    I did not see on Lincoln chart propane
    Waiting for the video of propane shield gas.
  7. Likes whtbaron liked this post
  8. #31
    Laredo, Tx
    Propane is not a welding shielding gas, pretty simple.
  9. #32
    Apr 2021
    Alabama
    Has anyone tried welding in a vacuum? Use a Hvac 2 cycle pump to evacuate all the air out. Interesting stuff happens!
    Andy
    ESAB 350 MPI
    ESAB 330I CVCC
    Lincoln Idealarc 250
    Eastwood TIG 200
    Hobart Ironman 240
    Hobart Plasma Cutter
    Lincoln 110v MIG
    CH 110v MIG
    MK Industries Cobramatic with Prince XL
    Miller XR Wire Feeder
  10. #33
    I know that
    But video would be a great for tic toc and news. Heating propane to 5,000°F and then hitting the air BIG HOT flame.
  11. #34
    NASA has but most metals in a vacuum will weld by self.
    Quote Originally Posted by andremajic View Post
    Andy
  12. #35
    Feb 2012
    Thanks Oscar but GMAW is MIG or wire feed. Lt Badd said he uses for TIG. I get that MIG can be used with all kinds of mixes including O2 and CO2 but those gases don't work with TIG. My question was about Hydrogen and TIG. I suspect a small amount like 2% Hydrogen gets snuffed out by the 98% Argon but gives desired weld temps for SS ?
    Also, I think the term mix is being used loosely. Knoble gases do not form a chemical bond with other elements or molecules. You can blend them like mixing oil and water but Knoble or Ion gases do not form bonds because there outer Valence is full. The CO2 molecule is interesting because it has a symmetrical chemical bond but neither gas is Knoble. Theres something about the efficiency of CO2 molecule to release energy but I don't remember the mechanics. Interesting but useless information.
  13. #36
    Feb 2012
    I get it your joking but we all know that propane is good for heating and cutting only. For shielding a weld use acetalyne. I think with a carburizing flame?
  14. #37
    Laredo, Tx
    True, I missed that but none the less, it seems it serves the same purpose based on the Lincoln guide description.
  15. #38
    I perfurter make a joke about a dangerous things and most can see a lot faster as joke
  16. #39
    Sep 2016
    Detroit, Michigan
    Knoble?
    http://mivise.com
    Hobart Champion Elite
    Everlast PowerTig 210EXT
  17. #40
    NW New Jersey
    Hydrogen boost?
    I have never used this (AR/H mix) , but have heard of it.
    Short answer , yes it hotter.
    Long answer - Consequently, argon is a gas with high efficiency for shielding around the arc weld. ...
    It has also been found that the addition of hydrogen to argon promotes increased
    welding speed due to hydrogen significantly increasing the volume of molten material
    in the weld pool.
    Even longer answer : science direct article,
    https://www.sciencedirect.com/scienc...%20weld%20pool.
    Might be a good read with a mug of coffee/tea
    No real need to re invent the wheel on welding gases, what we currently have seems to work very well.
    True, I think most of the newer shielding gases are slight manipulations with smaller amounts of reactive elements , and compounds.
    I don't think the use of Hydrocarbon mixes will be some new revelation, especially if the come from a well, they might have a lot of other compounds in there, even after fractionation.
    @LtBadd - Does this work well on all stainless joints ? Wondering if this is better on thicker sections , or is it good on sheet metal too ?
    Miller Synchrowave 180 sd
    Miller Econo Twin HF
    Lincoln 210 MP
    Dayton 225 ac/dc
    Victor torches
    Snap-On YA-212
    Lotos Cut60D
    Primeweld 225 ac/dc
    Primeweld mig180
    Miller AEAD-200
  18. Likes LtBadd liked this post
  19. #41
    Knoble?
    When I went to school they called them inert gases because they wouldn't combine with anything else... I guess the terminology is different given geography and generational differences... and spelling...
    Cut 50 Plasma
    Oct 2019
    Australia
    I use nitrogen for purging stainless tig welding often.
    Welds come out nice and shiny but with a gold hue to it. One of these days I'll get a hardness test done to see if there's any embrittlement going on. Haven't had any failures yet.
  21. #43
    Sep 2015
    West coast of Florida
    No need to use for thinner material, although you could increase travel speed a fair amount.
    @ Insaneride
    "The Linde HydroStar® shielding gas blends are primarily used for joining austenitic stainless steels utilizing the Gas Tungsten Arc Welding (GTAW or TIG) process. Hydrogen increases heat input to the base materials while providing a reducing atmosphere to enhance weld cleanliness"
    "A strong arc-voltage drop is produced by higher ionization energy and higher thermal conductivity of hydrogen if compared to argon. Thus this increased power leads to higher penetration of the weld joints. Thus, productivity can be improved by using higher travel speed without compromising to cost and quality. Also as hydrogen is reducing in nature it will lead to clean weld."
    "This Argon – Hydrogen shielding gas mixture is only recommended with Austenitic stainless steel material. As with other materials, defects due to hydrogen may be prevalent. For welding of Austenitic stainless steel material Argon-hydrogen mixture can be seen as best option instead of using Helium as shielding gas"
    The previous shop I worked at we used this a lot on 316 pipe and other stainless weldments
    Richard
  22. Likes Munkul liked this post
  23. #44
    Sep 2016
    Detroit, Michigan
    I did a bunch of searches wondering if it's spelled that way in other countries...no luck. It did find that it can be an insult that combines the words "Knob" and "Goblin" and a Middle English term that means "little knob or bump". Neither would seem to make a good shielding gas....pretty sure goblin gas is highly reactive
    http://mivise.com
  24. Likes whtbaron liked this post
  25. #45
    Feb 2012
    Good information here. My next question is why Hydrogen vs Helium? It was answered in Lt Badd's post. Higher thermal conduction leads to higher production.
  26. #46
    Feb 2012
    I was spelling noble wrong.
    The noble gasses are inert but not all inert gasses are noble. CO2 can be considered inert.
  27. Likes whtbaron liked this post
  28. #47
    It would work.
    But down side is after welding it is blow torch up like a balloon in ww1.
    It is used for a fuel on cutting torches.
    It would give a new name to welding.
    FYI In past they have used hydrogen gas in some types of light bulbs before Edison.
  29. #48
    Jul 2021
    Pitman PA
    Patience my friend...Im sure somebody somewhere will be crazy enough to try it...In my youth it would have been me
  30. #49
    I would have too.
    But as got older I was wiser by pain of it all.
    Quote Originally Posted by old miner called Pop View Post
  31. #50
    Jul 2021
    Pitman PA
    I would have too.
    My Dad used to warn me about doin dum****...It never ceased to amaze me how he picked up so much wisdom as I got older
  32. Likes whtbaron liked this post
Page generated in 1,642,505,917.16405 seconds with 12 queries
