Page 1 of 3 123 LastLast
Results 1 to 25 of 52
Thread: Non-traditional shielding gases
    Nov 2021
    Republic of Texas
    Of course, everyone knows about using argon, CO2, and helium as shielding gases... And some gas mixes even contain a bit of nitrogen or hydrogen...
    But what other gases have been tried over the years and what were the results?
    There are other noble gases, although some of them might be a bit expensive for use in welding...
    I wonder how a gas like propane / butane / methane would work as a shield gas... Surely *someone* has had a few too many beers and given it a try...
    Jul 2021
    Pitman PA
    Re: Non-traditional shielding gases
    Leave it to a sailor to come up with that...I just might try it and Im just crazy enough to try it without alcohol
  3. Likes NavyVet1959 liked this post
    I've heard of some mixes (for mig IIRC) even containing a small amount of oxygen, which was a surprise to me!
    Sep 2007
    I wonder how radon would go. Might add some extra energy to the weld pool, and give the welder super powers.
  6. Likes NavyVet1959 liked this post
  7. #5
    Mar 2012
    Australia
    Small amounts of oxygen (around 2%) in mig has is very common, in fact where I am (in Aus) getting standard MIG gas without oxygen is a special order and is often more expensive than tri mix argon/CO2/Oxygen mixes, C25 here is about 15-30% more expensive than 16%CO2 2.75% oxy mix.
  8. #6
    Nov 2013
    Quote Originally Posted by NavyVet1959 View Post
    Yea but,,,, Flammable gases??? Not sure How That would work!
  9. #7
    Jul 2018
    Cumbria, UK
    Hydrogen is used for TIG welding stainless steels. Works well for austenitic grades as hydrogen embrittlement isn't a problem.
  10. #8
    Quote Originally Posted by ttoks View Post
    Huh. Interesting. I have a grand total of about 15 minutes of hood time on MIG, from when I took a welding course. It was surprising to me to hear of oxygen being in a welding "shielding" gas because oxygen is mostly what you're shielding from!
  11. #9
    Jul 2018
    Cumbria, UK
    Nearly all our MAG gas has 2% oxygen in. But our European friends have plain CO2/Ar.
    Our usual gasses
    Light gas - 5-7/2
    Medium gas - 12-15/2
    Heavy gas - 20-25/2
    CO2/O2, remainder Ar
    Stainless MAG gas would be 2% O2 OR 2% CO2, pick your flavour.
  12. #10
    Mount Tabor VT
    I don't know what it means, I'm just repeating something. MIG requires a reactive component in shielding gas. I've heard it said CO2 is reactive. Pure argon doesn't work as MIG gas.
    As for propane, theoretically it'd work, but somewhere there has to be a place where it'll mix with air & a spark. Then all bets are off!
  13. #11
    Laredo, Tx
    Oxygen is not used as the shield per say; that is still primarily argon that does the shielding. Oxygen is used as a component, in small amounts. It reduces the surface tension of molten steel and therefore helps toes wet out, as well as help initiate droplet detachment in spray-arc or pulsed-spray. The reason you can use it in the mix is due to the filler metal constituents, deoxidizers to be specific. They will combine with the [small amounts of] oxygen and trap it in the silicon islands after it's benefits have been reaped. Large amounts of oxygen, aka the atmosphere, is most definitely something to shield from, as the deoxidizers are not anywhere near sufficient to keep porosity at bay.
  14. Likes NavyVet1959, Lee J liked this post
  15. #12
    Mar 2008
    Georgetown, Texas
    I have used straight CO2 for shielding gas for tig welding on a couple occasions. It's not great but it worked.
  16. #13
    Sep 2016
    Detroit, Michigan
    Oh, this is just ripe for a MIG Vs MAG argument!
    http://mivise.com
    Hobart Champion Elite
    Everlast PowerTig 210EXT
  17. Likes Oscar liked this post
  18. #14
    Brethren, Mi
    That is interesting and more than i will ever know about it. Must be something learned while studying, ha.
  19. #15
    It like any shielding gas it needs to be approved by AWS or other to use.
    I look into nitrogen as use in other countries the down side is may leave N in weld but biggest reason is it makes laughing gas and nitric acids, so you would be a happy welder with bad lungs.
    Which works in third work countries.
  20. Likes NavyVet1959 liked this post
  21. #16
    And the air we're shielding from is 78% N and 21% O2, and apparently at least 1% beer farts on a Saturday...
    Cut 50 Plasma
  22. Likes NavyVet1959 liked this post
  23. #17
    Soda springs,Id
    I can't get my head wrapped around using propane or hydrogen for shielding gas.
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
  24. #18
    Blow torch
    It heat gas up to 5,000F and when hits the air hot 🔥 flame 🔥
    I hope he takes video and post here.
  25. #19
    Feb 2012
    Quote Originally Posted by .RC. View Post
    For TIG, Radon should work in theory as it is a Knoble gas or as I like to call them ion gasses because there outer Valence bands are full and therefore ionic and also UN REACTIVE especially with oxygen. They don't mix with other atoms or molecules. Radon is radioactive tho but then so is Thorium or was it Cerium? In any case , why use Radon? I've asked a similar question about why aren't the other Knoble gasses used like Krypton, Xenon and Neon. Answer was: they are used but supply and demand is cost prohibitive. Makes sense. As for Hydrogen TIG, that's an easy No. Hydrogen is used for OxyHydrogen and I think developed in SoCal for airplanes during WW2 because the Navy needed all the acetalyne. It's going to go boom boom boom in a tig torch if it's pure Hydrogen.
    Not to hijack , more like hitch hike, I have a question. Why can aluminium be welded with D.C. CV Mig and Argon but not with D.C. Tig CC?
  26. #20
    Sep 2015
    West coast of Florida
    Argon with 2% hydrogen is a sweet mix on stainless (TIG)
    Richard
  27. Likes Insaneride liked this post
  28. #21
    Feb 2012
    Why and can you explain it? Is it like He mix?
    Hydrogen boost?
    Edit: it's for Stainless?
  29. #22
    Sep 2005
    Cave Creek AZ
    No real need to re invent the wheel on welding gases, what we currently have seems to work very well.
  30. #23
    But hydrogen worked great in zeppelins... to a point...
    Cut 50 Plasma
    Nov 2021
    Republic of Texas
    Blow torch
    It heat gas up to 5,000F and when hits the air hot  flame 
    Well, if I had a MIG machine, I would probably give it a try... After a few beers...
    Chemically though, what would be happening? The propane / methane would burn with the oxygen in the air, producing CO2 and water vapor... Hmmm...
    The flame is not necessarily a *bad* thing... You might even be able to justify it in that it would be helping to heat up the metal...
    I've been diving (SCUBA) since the mid-1970s and the commercial and deep divers (and some "tech" divers) use mixed gases for certain dives, so I've read about it a bit... There are certain gases that work well and often they are noble gases... Basically you are looking for a gas that does not dissolve readily in your blood stream or tissues, even at pressure and it off-gasses quickly to reduce the decompression time... Xeon would be one possible candidate except for the fact that it is also an anesthesia even at standard pressures... Most of the other gases either cost to much for this or have other disadvantages... For really deep diving, hydrogen has been used as a mix gas, but you have to keep the oxygen content in the mix below 4% (IIRC)... Since only 4% oxygen in your breathing mix will have you passing out on the surface, you have to use another mix to get to a depth where the PPO2 is sufficient that you will not pass out breathing the 4% O2 96% hydrogen mix... Hydrogen has a much greater flammability range than propane or methane, so it's more dangerous to work with... For diving, just like for welding gases, the gas choice is usually a balance of availability, advantages / disadvantages, and cost...
  32. #25
    O/A torch tips are built to create a venturi effect that helps to eliminate burn back into the handle. I highly doubt that MIG handles are...
    Cut 50 Plasma
Page generated in 1,642,504,817.66387 seconds with 12 queries
