Results 1 to 22 of 22
Thread: fence price
    Nov 2021
    fence price
    I have a 72í fence to finish on a already started project that has all da post in and framing. I have to redo the posts beacuse they arenít in the ground and put in all the vertical tubing and also there will be 2 sliding gates and to 4í wide swing gates. So what sounds reasonable to charge since iím new in the business.
    Re: fence price
    Quote Originally Posted by Tru-Stud-Welding View Post
    I have a 72’ fence to finish on a already started project that has all da post in and framing. I have to redo the posts beacuse they aren’t in the ground and put in all the vertical tubing and also there will be 2 sliding gates and to 4’ wide swing gates. So what sounds reasonable to charge since i’m new in the business.
    $10,000.00
  3. Likes _Weldman_, drillerjoe liked this post
    Re: fence price
    $10,000.00
    $10,155.00 otherwise the customer will think you're just throwing out numbers.
  5. Likes John T, _Weldman_ liked this post
  6. #4
    Outside of Raleigh, NC
    Re: fence price
    $10,155.89
    Miller Trailblazer Pro 350D
    Miller Suitcase MIG
    Miller Spectrum 2050
    Lincoln 210MP
  7. Likes Lis2323, _Weldman_ liked this post
  8. #5
    Re: fence price
    $10,155.89
    Much better. Thank you
  9. #6
    Re: fence price
    Somebody started it, did not finish it, now you remove what was started? Does not sound like "finish"ing a job. Not sure what I would charge from the description, however don't tread lightly on pricing. Seems like you should be checking locally fir pricing on labor on fence building. Good luck
  10. #7
    Re: fence price
    Itís a joke.
    Itís equivalent to these guys to come onto the board and say Iím thinking of starting a welding business
    What sort of machine should I buy?
    Get the F out of here.
    Anyone with common sense would not step into a business without knowing what to charge.
    Especially getting involved with a job without quoting a price and then go online and ask what he should charge
    Itís retarded.
    Not to mention digging holes by hand with a shovel.
    So much wrong with this I donít know where to start.
    A smart man will take a job for six or seven months for a fabricator or a fence company and learn the ins and outs.
    How to do things how to price jobs etc. etc.
    Whatever.
    Turkeys almost done.
    Iím out of here.
  11. Likes _Weldman_ liked this post
  12. #8
    Brethren, Mi
    Re: fence price
    You never know, i have seen as many start out in reverse as running in foreward.
  13. #9
    Re: fence price
    John is our good will ambassador. I'm on an old car forum and a guy came in that had just bought a car. Wanted me to tell him what it was. Dude!
    Cut 50 Plasma
  14. Likes _Weldman_, Lis2323, 12V71 liked this post
  15. #10
    May 2021
    45.97267, -106.27818
    Re: fence price
    and the actual retail price is $10,000 for a difference of zero dollars, come on down John T.... Bob Barker
  16. Likes Lis2323, whtbaron, 12V71 liked this post
  17. #11
    Mar 2021
    California Central Valley
    Re: fence price
    I got started in the fencing business when I couldn't find anyone who would build what I wanted - a wood fence with square steel posts, set in concrete, with steel-framed gates and remote openers. I ended up renting a two-man power auger and doing it all myself. I was already building gate frames to replace wood ones, which typically fail in 2-3 years. Did my own, learned what I needed to in that process, and started doing them for others who admired my work and wanted some.
    Step 0 - Get your contractor's license. Without it, you WILL get screwed. If you won't/can't get a license. don't do a contract - do time and materials ONLY. "I charge $X/hour, and the customer supplies all the materials. My time starts when I arrive, ends when you pay me, and has a 6 hour minimum, unless agreed on in advance."
    Step 1 - draw up plans to determine materials quantities. Add 50% for waste and price increases.
    Step 2 - estimate labor, then triple it. Everything that can go wrong, will.
    Step 3 - meet with the client, and be prepared to take your drawings, materials list, and estimate with you WHEN YOU WALK AWAY.
    Realize you are cleaning up someone else's mess on this job, so you'll probably regret getting involved with this customer.
    Miller 250P, MM210, Bobcat 250
    Lincoln 225AC/DC, Pro-Mig 175
    Lotos Cut 50
    PrimeWeld TIG225X
    Titanium Easy Flux 125
  18. Likes Lis2323 liked this post
  19. #12
    Re: fence price
    It's tough to go cost plus. Most people won't hire you. They prefer a flat bid.
    I had a guy cutting Cedars for me that was by the hour. He screwed me big time, and I still have a ton of trees that have to be cut.
    I had issues with a grapple. Made one, but it didn't work as planned, redesigned it, and finally got out on the line with the dood. Cut more trees in about 4 hours, than he did in a f'n week. Then the azzhole just up and quits because when I worked with him, the pace was too fast. Contractors are either good, or suck.
  20. #13
    Re: fence price
    Quote Originally Posted by Teachu2 View Post
    Add 50 percent of what?
  21. #14
    Mar 2021
    Re: fence price
    Of your calculated materials.
    Lotos Cut 50
    PrimeWeld TIG225X
  22. #15
    Re: fence price
    It sounds you know how long took.
    How many hours did take and the number of posts installed?
  23. #16
    Mar 2021
    Re: fence price
    Understood - but if you quote a complete price without a contractor's license, you have no recourse if you don't get paid - at least here in California.
    Lotos Cut 50
    PrimeWeld TIG225X
  24. #17
    Re: fence price
    I agree
    At point you just a employe and do not sign or give a contract.
  25. #18
    Dec 2007
    Los Angeles
    Re: fence price
    I'm in California as well.
    I never pay by the hour. That person then becomes an employee and opens up another can of worms not in your favor either.
    Ed Conley
    MM252
    MM211 (Sold)
    Passport Plus & Spool gun
    Klutch 120v Plasma cutter
    SO 2020 bender
    Beer in the fridge
  26. Likes Lis2323 liked this post
  27. #19
    Re: fence price
    What can worms are you taking about?
  28. #20
    May 2021
    Landrum, SC
    Re: fence price
    I'd find out why the job was left unfinished in the first place....
    Lincoln 330 MPX
    Modified Tombstone
    Lincoln LN-25X-TVT
    Magnum PRO 250LX GT Spool Gun
    ľ Ton of Torches OFC-A / OFG-A
    SMAW FCAW GMAW
    Air Carbon Arc Gouging
    #Freebird Welds
  29. #21
    Dec 2007
    Los Angeles
    Re: fence price
    In California:
    You hire someone by the hour/day laborer they are technically now YOUR employee. They are NOT independent contractors/labor.
    Employees have rights and are very well protected in California, rightly so as a lot of employers are pretty crappy. But also the gubment wants to make sure taxes are collected.
    Anyhoo... the worker/employee gets injured while working for you... you are on the hook if they want to file workers comp claim. You can't claim that they are independent contractors. They are considered employees by the state.
    Pay dispute ? They can file a claim with the EDD (Employment Development Department) and say... they, as an employee, were not paid timely or correctly.
    All of the problems/can of worms fall in to your lap.
    It has become worse with the passage of AB-5 and the rules for how workers are classified.
    ****e- you control when they start or stop- boom, employee.
    It gets dizzying for sure.
    Ed Conley
    MM252
    MM211 (Sold)
    SO 2020 bender
    Beer in the fridge
  30. #22
    Re: fence price
    As a retired contractor I found this same type person will come up ways not pay.
    Either way you will find people will not pay.
    If do not have license and just starting about the only thing you can do is be a employee if working on buildings and hope best out come. Most will pay for your work.
    California does permit a handyman up to $500.00 most welders I have know most handyman and welders would do just labor and owner pay for material up to $500.00 it is safer. But again they where working to get a license too.
    But if you working on equipment a contractor works great. No license need most cities and a few countries will require a business license in California.
    In California:
Page generated in 1,643,128,141.61844 seconds with 13 queries
