Results 1 to 9 of 9
Thread: Dual Manifold C25 Regulator / Best Setup For 2 Machines For Hobbyist
    Arizona
    Happy Thanksgiving all - just an early morning thought experiment.
    Since I now have 2 fully functioning multi-process machines I'm thinking it would be nice to set up each differently to minimize swapping wire and whatnot.
    I'm most likely the only one that can answer this question, but it's nice to hear your thoughts and ideas.
    I like/use .O30 wire for most of my yard art/sculptures. A little bit of stainless, but mostly a combination of thick and thin mild steel. Probably .023 in the other machine.
    Either can be easily switched over to stick. Not a fan of Flux core.
    Anyways, just throwing it out there - maybe someone has ideas I hadn't thought of (usually the case!)
    Yeswelder MIG-205DS
    Fredericksburg, VA
    Re: Dual Manifold C25 Regulator / Best Setup For 2 Machines For Hobbyist
    That will work and is the simplest solution.
    Use the machine with the shortest gun for the 0.023.
    Or use the machine with the least available power for the 0.023 if both guns are the same length .
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Miller Spectrum 625 Plasma
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
  3. Likes Shootr liked this post
    I'm in the opposite condition, that is 1 machine 2 different gases. I expect the purists to cringe but I just use airline quick couplers and they work fine for what I do.
    ---Meltedmetal
  5. Likes Shootr liked this post
  6. #4
    CT
    what are you welding with the 023 wire that can't be welded with 030? Me personally I would set up one machine for steel and one for stainless or bronze wire, with a different gas. I would think MIG brazing would be more useful for your art than two different sizes of ER70-S6.
    Miller Multimatic 255
  7. Likes Welder Dave, Shootr liked this post
  8. #5
    2 separate flow meters is probably about the same price as the dual. Unless your welding 22 gauge, .030" wire should be all you need.
  9. #6
    Arizona
    And there it is - never even heard of mig bronze brazing. Now I have to price argon bottles - DAMN YOU ! Just for giggles, any idea what happens if you try with C25?
    Yeswelder MIG-205DS
  10. #7
    CT
    No workie...bad porosity
  11. Likes Shootr liked this post
  12. #8
    Brethren, Mi
    I am going to score a 140 for small wire. I made it a long time without but had one around for a while is lot easier for exhaust and down to near foil thickness.
  13. #9
    This is what I do
Page generated in 1,643,254,047.50696 seconds with 13 queries
