Results 1 to 4 of 4
Thread: how to accurately mix gasses?
    Mar 2012
    Australia
    I Can't have every gas combination possible on my truck that I use, I want argon for TIG work, C25 for dual shield flux core and short circuit MIG where a WPS calls for it (which surprisingly is not readily available where I am) 100% Co2 for where dual shield with it is acceptable, some C10 when I need to do some spray transfer solid wire is great, plus oxy and acetylene.
    I'm guessing you are seeing where I'm going with this, I want to only carry 4 E sized (140ish cubic foot) bottles around, oxygen and acetylene, an argon bottle and a Co2 bottle.
    What is the best way to accurately meter argon and Co2 for a mix, I am mostly going to be wanting C25 and C10 mixes, but I will has to be able to demonstrate accurate (within 10%) flow rates for the gasses to be approved by the CWI, what mixing tools are out there that can do this?
    The best idea I have atm is an CO2 calibrated ball flow meter and an argon calibrated ball flow meter on they're respective bottles connected with a Y connecter after the meters.
    May 2015
    Re: how to accurately mix gasses?
  3. Likes ttoks liked this post
    Dec 2007
    North Texas
    Sure, gas mixers are the best, and most expensive, solution to your problem. I have done it in the past with a "Y" connector and separate flow meters to produce a 90/10 Ar/CO2 mix from a cylinder of 100% Ar and another with C25. I understand you are doing something a little different, but the same principles should apply. Rather than explain the calculations I used in detail, here is a link to a post by Oscar on another forum that spells it out.....
    https://forum.weldingtipsandtricks.c...hp?f=6&t=14410
    Scott
    Miller XMT 350 CC/CV w/gas solenoid opt.
    Miller S-22A wirefeeder
    Bernard 400A "Q" gun
    Miller Spoolmatic 30A / WC-24
    C-K 200A torch/gas lens
    Weldcraft WC-18 watercooled torch
    Hypertherm Powermax 30
    Victor O/A
  5. Likes ttoks liked this post
  6. #4
    Laredo + Midland/Odessa
    ttoks, you CAN have every gas mix available if you want! With a few specialized flowmeters I can build you a Frankenmixer flowmeter station where you can hook up 3 gases: Argon, CO₂, and O₂. The O₂ is optional, but who knows, you might need to add in small amounts of it. You can then proceed to dial in any reasonable gas mixture from just 3 tanks. The O₂ tank I use is the small 20 ft³ since it is only used in tiny percentages, it takes up hardly any extra space, and lasts a very long time.
    This is one I built for a customer/friend, it has dual CO₂ flowmeters since he, like you, wanted to dial in C25 with a large overall flowrate, along with low percentages for spray/pulsed-spray
  7. Likes ttoks liked this post
Page generated in 1,713,305,595.00323 seconds with 21 queries
