Results 1 to 9 of 9
Thread: Question about Cutting a crank or cam shaft.
    Nov 2019
    North East Ohio
    I pulled a camshaft and crank from a scrap pile of a repair shop. It most be to to some big *** diesel motor its like 4' long and thick. I want to use them to make a tv stand.
    The question is are cams, cranks a super hardened steel?
    Is an ordinary bandsaw blade what I should use?
    I put the cam on my Elis 1600 and it cut extremely slow. I did not leave it on very long because I don't want to screw up a fairly fresh bandsaw blade.
    Thanks Have a Great Thanksgiving
    May 2015
    Re: Question about Cutting a crank or cam shaft.
    You should not have a problem cutting a crankshaft with a bimetal bandsaw blade. It is most likely 1045. If you really are that concerned you can always use a cut disc.
    Quote Originally Posted by Weld_ View Post
    There is a possibility that the bearing journals on the crank and cam are induction hardened. Depending on the engine manufacturer. Cam lobes too.
    Nov 2019
    North East Ohio
    Thanks guys. I did not give the saw much time to work. It just seemed "different".
  6. #5
    Feb 2016
    Six Mile SC
    Start a groove with a grinder, then use your bandsaw.
    CG
  7. Likes Reebz, Weldalittle liked this post
  8. #6
    May 2007
    i wouldnt put it in a saw. id take a $3 zip wheel, use a 3rd of it in 1 minute, and ur finished and it cost u $1. a abrasive cutoff wheel hardly notices anything hard , it just cuts it. a saw blade cost many times more than a zip wheel. i dont like putting oddball shaped stuff in saws, or something that makes little surface contact in jaws, cuz it might come loose/spin, i screwed up enough blades doing it. a tv, naw, there bad foir u, better for a potted plant or somthin
  9. Likes Weldalittle, Reebz liked this post
  10. #7
    I've had stuff spin in the saw. Sucks.
  11. Likes Reebz liked this post
  12. #8
    Oct 2009
    Cartersville, Georgia
    I know that a brand new Bi-metal sawzall blade was no match for a 2 stroke Suzuki outboard crankshaft.
    I just needed the splined end off the crankshaft from an old seized (badly enough that I couldn't remove the crank via normal methods) parts motor so the machine shop could have a test piece to verify the spline he was cutting on a gearcase mod fit properly. Couldn't fit a cut off wheel in more than 1/3 of the depth, sawzall was only thing that would fit. Ended up having to use a diamond blade made for cutting cast iron.
    If that's the case with your crank, the damage is probably already done to the blade. Doesn't take long. Cut off wheel is the only way to go for that sort of thing.
    Who is John Galt?
  13. Likes Reebz, whtbaron liked this post
  14. #9
    Jul 2021
    Pitman PA
    Plasma cutter if you have one
  15. Likes Reebz, bfjou812 liked this post
Page generated in 1,642,559,785.63384 seconds with 12 queries
