Results 1 to 9 of 9
Thread: What kind of metal?
    Jun 2019
    Atlanta, GA
    What kind of metal?
    It's heavy. Cast iron of some flavor?
    Sep 2012
    Wheatland, Wyoming
    Re: What kind of metal?
    Drill into it with an 1/8" drill bit about an 1/8". If the cuttings are granular it is likely cast iron.
    Chris
    Auction Addict
    Jun 2017
    Quote Originally Posted by tiggen View Post
    It’s a meteorite…worth 100,000
    CT
    Miller Multimatic 255
    What it was part of will often give you clues to the most likely suspected alloy.
    ---Meltedmetal
    Jun 2019
    Atlanta, GA
    It came off a rabbit, the kind of thing my mother in law would have in her garden. It is a solid casting, which I find odd. Most of these lawn ornaments I've seen are hollow. She wanted to know if I could weld it back on. Will do spark and drill test if she brings it back.
    Then if it is iron (magnetic) it is most likely gray iron of whatever grade was in the furnace the day they wanted to get the molds off the pouring floor. Up here it would get o/a brazed and painted. Or if the bronze was going to offend someone maybe welded with cast iron again with o/a.
    ---Meltedmetal
    I'd probably just use an epoxy to repair a lawn ornament. It's has a lot of rough surface area so should work great and keep the existing colour match.
  9. Likes 12V71, wb4rt, CAVEMANN, whtbaron liked this post
  10. #9
    May 2011
    Epoxy
    If you weld it, that kind of stuff is made with pot metal. Like anything around the pot gets dropped into it, steel, other cast, aluminum, the older Chinese guy who wanted a raise.... anything.
  11. Likes 12V71 liked this post
Page generated in 1,643,046,606.46187 seconds with 13 queries
