Results 1 to 8 of 8
Thread: Welding Expanded Steel
    Jan 2012
    Hey there,
    I was contracted to do some welding. They want a time estimate. Can anyone here help me decide how long this should take? I've never done this type of work.
    Its security for a parkade. They need 26 x 8'x4' sheets of expanded steel welded. and 26 smaller pieces at 48"x30".
    I'm using a MIG welder. I feel like I could weld a full size sheet, tack each little point, in less than an hour. Does this sound right?
    Thanks for the help!!
    Brethren, Mi
    Re: Welding Expanded Steel
    If you think you can do it in an hour give it 1.5 anyway. It isnt welded over paint etc? Test a small one? Did you look at this, dont want to find out its got epoxy paint etc.
    What are welding expanded steel to?
    What Guage is the expanded steel ?
    Do have to weld ever web of the expanded steel or can you skip weld?
    Quote Originally Posted by shasdakota View Post
    Hey there,
    Soda springs,Id
    Pics and the thickness and size of the openings would get you more help on this. It would probably be easier to use some 14 ga X 2" flat bar as a backer and weld the expanded to it. IMO it will be quite a challenge to weld the ends together even with a mig using gas shield. I'm trying to visualize why the 48"x30" pieces have to be joined to the 4x8s. Like I said some pics will help.
    Hobart G-213 portable
    I would buy the expanded steel full size.
    It would give better looking job.
    If I design the job I would use to 2 sizes anger irons for a sandwich. It give a finish look.
    May 2011
    If you are welding flat expanded metal, and welding the 30" to the end of a 96" sheet then that would be very simple as they have flat spots on the ends which make good welding tabs. If your welding raised, well that will probably suck. They dont go well together unless it was cut to do that by an experienced cutter.
    Also, expanded metal doesnt come 4x8 it comes like 49.5" x 98 or even 99".
    Can you weld? You may be asking the wrong querstons? I would say 1.5 hrs, also. Good luck
    Nov 2010
    Mid-East
    Hey there,
    Welded to what? Frames? Each other? Why are you welding every point? Is it galvanized?
Page generated in 1,643,131,189.83032 seconds with 13 queries
