Results 1 to 13 of 13
Thread: Dialarc
    Dec 2021
    Hey guys. I picked up a dialarc HF from a tech school auction. Machine is clean. So….if my service isn’t up to par is it possible that the machine wouldn’t even power up? No fan… no nothing. I plug it in and get 120v on each of the 2 wires. Before and after switch. Jumpers are per manual for 230v. I normally run my Lincoln 255 mig on this outlet with no issues. Not sure on details about wiring size to outlet but looking into that now. Figured I’d ask here in the meantime. Maybe i got shafted.
    Re: Dialarc
    I don't know what you are plugging it into but if it runs a 255 then the answer to your 1st question is no. Check from hot to hot for 230/240v. Checking 240v circuits against ground/common can read the same 120 v twice rather than 240 volts and can give you a mistaken idea that your power is okay..
    ---Meltedmetal
  3. Likes Oldendum, scsmith42 liked this post
    Jan 2008
    Richmond, Virginia
    Re: Dialarc
    Looks like the PowerMIG 255 is 208/230/60 Hz or 230/460/575/60Hz depending on version. If yours is happy on 230V from that outlet, then the Dialarc should do something.
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
    Jan 2008
    Richmond, Virginia
    Re: Dialarc
    SP-175 +
    Miller spot welder
  6. #5
    Jan 2008
    Richmond, Virginia
    Re: Dialarc
    duplicate post.
    SP-175 +
    Miller spot welder
  7. #6
    May 2010
    ct.
    Re: Dialarc
    If it’s wired correctly and power is good then it seems like
    transformer and fan have both failed(?).
    How about checking fan for continuity?
    Miller a/c-d/c Thunderbolt XL
    Millermatic 180
    Purox O/A
    Smith Littletorch O/A
    Hobart Champion Elite
  8. #7
    Dec 2021
    Re: Dialarc
    I’ll check continuity tomorrow. Just odd has 119-120v on each stud and jumpers are correct. Won’t even spark with 3/32 7018. Name:  C0797FE1-787B-4298-9FAC-E15E376C2EE0.jpg
  9. #8
    Ceres, California
    Re: Dialarc
    when testing a 240 volt welder. Do not measure to the case ground.
    Measure wire to wire. Start at the line cord terminals. you should have 230 to 245 VAC. Then go two the line switch. with switch off find the two hot wires. should read 230 to 245 also. connect to the two dead wires then turn switch on you should get 230 to 245 volts if switch is good. you you get zero switch is bad. If you had measure from ground you can get 120 volts on all 4 terminals with the switch on and have a switch with one contact open. This is because you are reading through the transformer. This also makes it hard to test the switch with an ohmmeter unless you remove at least one wire to the transformer.
    you can also test for a bad line switch by testing at the jumper links just about the line cord terminals. link to link will read 230 to 245 if switch is good.
    230 volt fan motor is across the links when set for 230 volts.
    The line switch is the weakest part on these units. let some one turn off the welder while it is welding a few times and switch may die.
  10. Likes Meltedmetal liked this post
  11. #9
    Big Lake/Monticello MN
    Re: Dialarc
    Dialarc HF is also a tig machine.
    Your amp switch must be set to "local" or "panel", not "remote"
    Take a pic of your switch positions.
    Not sure why your fan doesn't work?
    Syncro 350
  12. #10
    Dec 2021
    Re: Dialarc
Size:  98.2 KBSwitch positions
  13. #11
    May 2010
    ct.
    Re: Dialarc
    Does transformer hum?
    Millermatic 180
    Purox O/A
  14. #12
    Dec 2021
    Re: Dialarc
    did this and found that the switch is bad. Thanks!! Never knew to check it that way. Thanks again!,
  15. Likes whtbaron liked this post
  16. #13
    Brethren, Mi
    Re: Dialarc
    Dandy looking machine. Needs some big ole chunks of lead so you can reach out in the yard.
Page generated in 1,642,861,090.17628 seconds with 13 queries
