Results 1 to 5 of 5
Thread: Need a wiring diagram for SAE generators
    Aug 2021
    Hello everyone,
    I have successfully re-insulated the wiring in my SAE-600. But I'm not sure if it was hooked up right when I bought it plus there's always the chance that I got something wrong. I want to check the current wiring against a wiring diagram for the generator.
    Does anybody have a detailed wiring diagram for an SAE-600? The only ones I've found have been heavy on details for engine wiring and pretty vague about the generator internals
    Re: Need a wiring diagram for SAE generators
    If you can find the serial number and code numbers, call Lincoln they might still be able to send you something. If the serial number/ code plate is gone. check the barrel of the generator is might be stamped on it some where.
    Aug 2021
    Lincoln eventually came through with the right wiring diagram for this machine. It was wired correctly and is now welding again
    You ever turn it up and run some big rod ?
    Aug 2021
    Not yet, unfortunately. I need some very expensive cable, hardware, and electrodes to do that
Page generated in 1,643,251,798.69857 seconds with 13 queries
