Results 1 to 19 of 19
Thread: How much variation in current flow from 14" full rod to a 1" rod nearly used-up?
    Feb 2019
    Portsmouth, NH
    Hi,
    I was a farm machinery repair welder about 45 years ago using a Lincoln AC-225 buzz box.
    I am thinking about getting back into SMAW welding. I got thinking. If one were
    carefully thinking about fine adjustment of current setting, how much does the current flow
    vary from using a new 14" rod to using a 1" rod that is almost used-up? Since the rod
    presents some electrical resistance, there is probably a difference in current flow through a
    new 14" rod vs a nearly used-up 1" rod. Has anyone done testing or some calculations on
    how the current flow increases as the electrode rod becomes shorter?
    I now have a Miller AC/DC 225/140 and an old 1960's Ideal Arc AC/DC 300/250 both which have
    infinite adjustment of the current setting. Stated another way, if I were to set to a
    certain currently when I am starting out with a new 14" rod, how much do I want to decrease
    the current adjustment (of the welder) as the rod shortens down to 1"? Are we talking a
    current difference of 5 to 10 amps for a new 14" rod versus a nearly used-up 1" rod?
    Orson
    Portsmouth, NH
    Lincoln AC/DC 225/125 flat top tombstone buzzbox Mfg. 2018
    Lincoln Idealarc 250 Code 5825-C, Mfg. 1966
    Dayton 240 volt spot welder
    Oxyacetylene torch
    Soda springs,Id
    Re: How much variation in current flow from 14" full rod to a 1" rod nearly used-up?
    I never gave it much thought. I guess with a clampon ammeter you satisfy your curiosity.
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
  3. Likes Orson_Yancey liked this post
    Feb 2016
    Six Mile SC
    All you've got to do is measure the resistance of a new rod and a stub. Should be very low, I doubt if it is significant for welding amperage variation.
    CG
  5. Likes Orson_Yancey liked this post
  6. #4
    May 2018
    the Netherlands
    A stick welder is a CC (Constant Current) machine, so it will do everything to keep the set current the same.
    Arc voltage varies with rod manipulation and arc length and could theoretically vary with rod length, but I doubt that the small resistance difference between a new rod and a stub will make much difference.
    Fronius Transpocket 180
    Kemppi minarc 150
    Esab powercut 400
  7. Likes Orson_Yancey liked this post
  8. #5
    Guys talk about the rod flowing smoother as the rod warms up. Maybe reduced resistance plays into that as well, but it's probably unnoticeable with the other factors at play. For a 1/8" rod, we are talking the difference in resistance between 1 and 14" of steel 1/8" in diameter... neither have a lot of resistance so it's going to be negligible.
    Cut 50 Plasma
  9. Likes Orson_Yancey liked this post
  10. #6
    CT
    The answer is probably close to zero change in current. More than likely the voltage changes while the current stats pretty flat. SMAW welders are designed to deliver constant current.
  11. Likes Oscar, whtbaron, Orson_Yancey liked this post
  12. #7
    May 2021
    Landrum, SC
    I run a lot of 18", 7/32, 7024 rod and I agree with the others. There is no difference except the heat of the rod itself. A cold new rod will be exactly the same as a cold used rod of any length.
    Lincoln 330 MPX
    Modified Tombstone
    Lincoln LN-25X-TVT
    Magnum PRO 250LX GT Spool Gun
    Ton of Torches OFC-A / OFG-A
    SMAW FCAW GMAW
    Air Carbon Arc Gouging
    #Freebird Welds
  13. Likes Orson_Yancey liked this post
  14. #8
    Never found time to worry.
    You find more variation in power company voltage from morning to afternoon. Most welders do notice voltage drop.
    Quote Originally Posted by Orson_Yancey View Post
    Hi,
  15. Likes Orson_Yancey liked this post
  16. #9
    Mount Tabor VT
    A welder produces a series circuit. Power Ac Or DC flows from the welder through the work lead & clamp, through the table, workpiece, across the ionized gas produced by burning flux, & back through the electrode, stinger & its lead. The welder is designed to keep current steady. The rules of electrical theory are that a series circuit shares applied voltage. Resistance in each component of the circuit takes a bit of voltage. Ideally, the arc of ionized gas is the greatest resistor. Very tight arc, voltage decreases at the point of arc. Long arc, voltage increases.
    Heat is measured in watts. Watts are the product of Amperes X Volts. A long arc gives more heat, but that heat isn't where you want it. In comparison, I doubt length of rod will measurably change Amperage. And the machine will modulate to keep it steady.
  17. Likes Orson_Yancey, SweetMK liked this post
  18. #10
    The only reason a rod seems to burn better after an inch or 2 is because the unburned rod is preheated. Same reason rods fresh out of an oven burn nicer on start up. Some large diameter Innershield wires calls for 4 inches or more wire stick out. This is to preheat the wire and gives vastly improved deposition rates.
  19. Likes Orson_Yancey liked this post
  20. #11
    Feb 2019
    Portsmouth, NH
    Thanks for many good replies. I am hoping to provide the needed electrical service
    so that I can get out there and burn some rods--more fun than just thinking about welding.
    Orson
    Portsmouth, NH
    Oxyacetylene torch
  21. #12
    Hook up the Idealarc. It is a superior machine to the others.
  22. Likes Orson_Yancey liked this post
  23. #13
    May 2007
    prorbaly more change due to the way ur leads coil/unravel as u move around
  24. Likes Orson_Yancey liked this post
  25. #14
    Mount Tabor VT
    I've never heard it, but my brain goes there. Evaporation of water has a big cooling effect. Near every electrode is wet in the sense of taking water from the air. Theoretically, "new" 7018 is "sealed" Maine Oxy & Airgas "seal" packages of 7018. The new packages I buy have scotch tape on the joint. No way in Hell that keeps humidity out.
  26. Likes Orson_Yancey liked this post
  27. #15
    I suspect the current stays the same, but the rod "flows" better because it, and the workpiece, are hotter by the time you get to the end of the rod.
  28. Likes Orson_Yancey liked this post
  29. #16
    Mar 2021
    Near Roanoke, VA
    I was taught that the long arc gives more heat when I was in the US Navy,,
    I have always used this fact when welding, if the base metal is getting too hot, cram the rod into the weld, and keep the arc short.
    If the arc is short, the voltage is lower, and, the watts will be lower (the machine is trying to keep constant current)
    Right , or wrong , this short arc, and less base metal heating has always seemed to work ,, for me.
    A short arc, and less heat, seems to be the case, whether the rod is long, or short.
  30. Likes Orson_Yancey liked this post
  31. #17
    Mount Tabor VT
    Less arc length, less resistance, less voltage. Amps should remain the same if the welder functions. End result, fewer watts. And the jetting action of the rod exploding drives the heat deeper into the workpiece, where the transfer of heat causes the molten filler to more quickly freeze.
    Another benefit, less heat input reduces distortion as it cools.
  32. Likes Orson_Yancey liked this post
  33. #18
    Good weldors can vary the arc length to control heat when doing root passes on pipe.
  34. Likes Orson_Yancey liked this post
  35. #19
    Mount Tabor VT
    In theory, hotter metal (rod) would have higher resistance. I doubt the change is going to be significant in measurement of ohms in the rod unless you are talking about 1/16 rod. The hotter rod tip will be more effective at making plasma in the arc. Wild guess here, but I'd say the hotter the rod, the less voltage wasted in the jump from base metal.
  36. Likes Orson_Yancey liked this post
Page generated in 1,642,663,270.19526 seconds with 12 queries
