Results 1 to 7 of 7
Thread: welder identifaction
    Nov 2019
    Hello, I am in need of some help to figure out the year of my SA/200. The plate says model sa/ 200. Make is K6090 and ser number is blank. Any help will be greatly appreciated Thank you
    May 2007
    Re: welder identifaction
    6090 is the part number, u need code #, to match chart for yr., serial isnt needed. if no code#on plate, theres one hidden on machine, or , theres probhabaly people here who can tell by lookin at it by u posting pics
    Ceres, California
    look all over the barrel of the generator the code number sometimes stamped there.
    Nov 2019
    Ok I will and thank you
    Nov 2019
    Perfect thank you and im going to go have a look
    Oct 2013
    cntrl FL
    The code is stamped on the generator barrel, starter side of the machine, at about 9 o'clock near the brush cover. Should be a four digit number. Might have to take a wire wheel and remove the paint and rust layers to see it, just don't go to crazy or you could wipe them out if they were not stamped deep enough.
    SA 200s : 1944 1945 1963 1965 1969
    1981 SA 250 D3.152 DC only
    1961 LincWelder DC 180 AS
    2004 Ranger 10,000
    Lincoln Pro Mig 135
    Miller Load Bank
    Hobart GPB 258 Pipeliner
    Hobart GPB 261 Mainliner
    Hobart Airforce 250
    Everlast PA 200st
    Mar 2009
    Quote Originally Posted by WeePup View Post
    That’s a Canadian built sa200.
Page generated in 1,713,254,364.25341 seconds with 18 queries
